Old Sep 05, 2011, 09:38 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I have never try a tri.
Is the Yaw effective all the time, or only when motors are armed?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Sep 05, 2011, 09:41 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
Hawaii
Joined Feb 2003
Originally Posted by Flying-Monkey View Post
Ok, turns out I had things where they were supposed to be, from the sounds of it.
I am just getting no response from the tail servo.
Are you putting a separate power source to the servo?
SeismicCWave is offline Find More Posts by SeismicCWave
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
On my tri (not QuadRino controlled) the yaw servo is always active. When I arm/disarm the board the servo moves along with the rudder stick. I'd assume this is standard behavior on other boards too.
Vantasstic is offline Find More Posts by Vantasstic
Hawaii
Joined Feb 2003
The servo is active as long as the board has power and the servo has power. The motors do not need to be armed.
Old Sep 05, 2011, 09:47 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Too bad... that was not the problem.
Do you have a spare servo or esc you can plug there to validate the signal?
Old Sep 05, 2011, 09:53 PM
Hawaii
Joined Feb 2003
Are you putting separate power to the servo? The servo is not getting power from the flight controller.
Old Sep 05, 2011, 09:55 PM
Flying-Monkey is offline
Find More Posts by Flying-Monkey
Did you get it on video?
Flying-Monkey's Avatar
USA, FL, Miramar Beach
Joined Nov 2005
Ahhh
let me go fix that.
Flying-Monkey is offline Find More Posts by Flying-Monkey
Old Sep 05, 2011, 10:15 PM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Originally Posted by Vantasstic View Post
For those having Auto-Level 'drift' problems with the QuadRino and v1.8, give the 1.8dev code a try (Alex posted a link to it several posts back). I've tried it on my quad over the last couple of days and it seems to act just fine. I flew forward in Acro and switched to Autolevel and the nose would tilt up to stop the forward flight and then drift back a little, then it would level out and hold pretty well. Same results with sideways flight. Let Alex know your results. Probably the more folks who can test/verify this will help Alex pinpoint the issue in 1.8. Oh, for the dev code, you do need to uncomment the line about v1.7 stabilization and I recommend removing the 2* out of the 2*rcCommand line...both in the main PDE file...as well as set the other configs properly for the QuadRino board.
I'm confused, when you uncomment the line aren't going back to 1.7 version of auto level? Why run 1.8 if you are using 1.7's code for autolevel (or is 1.8 normal mode much better also?)?
vic20owner is offline Find More Posts by vic20owner
Old Sep 05, 2011, 10:37 PM
Joined Nov 2005
Power to the servo seems to make a difference.
Got a couple test hops in the living room. The wife wasn't happy, until she noticed it was blowing the hard to reach dog hair out from under the couch and recliner.
Old Sep 06, 2011, 01:53 AM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
yes
witespy is offline Find More Posts by witespy
Old Sep 06, 2011, 01:58 AM
Hawaii
Joined Feb 2003
The V1.8 software seems to be much more stable with the ITG3200 gyros in acro mode. So far I have no major problem with the V1.8 patch 1 auto level but the V1.7 auto level is very smooth.
Old Sep 06, 2011, 01:59 AM
Hawaii
Joined Feb 2003
Exactly, tell her you are cleaning her house.
Old Sep 06, 2011, 08:34 AM
Joined Nov 2005
Alright, update time.
Did a test flight outside with my quadrino basic set to tri, on a RadicalRC stinger tricopter frame.
I am VERY impressed. It needs some tweaking, but other than that, I liked it better than my quad I think.
Old Sep 06, 2011, 09:32 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Yeah, I think other's already answered. Evidently there's a little 'best in both worlds' here. The 1.8 has some improvements, but many reported weird drift issues when in going into auto level after forward flight. The 1.7 auto level didn't seen to suffer from this same drift. I'm forcing myself to learn to fly in Acro mode for 95%+ on my flight and am getting more and more comfortable with it so I don't recall much drift issues with the 1.8 fw. The 'experimenting' I have done with it over the last couple of days doesn't seem to cause me to notice any weirdness, so I'll assume its working fine. Alex was looking for feedback so he can look into the 1.8 code to see why the auto level mode (reportadly) reacts different on some boards.
Old Sep 06, 2011, 11:35 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Small Quadrino based Quadcopter on it's way..
Problem with vibration right now, i will correct that and give it a first flight..
HighResolution Here
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 05:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 10:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 01:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 09:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 11:44 AM
