Old May 12, 2011, 02:39 PM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
Quadrino Multiwii Flight controller
UPDATE THE QUADRINO is now upgraded with; The Evolution of MEGA. Now with 4-serial outputs, 4-Three way AUX channels .WOW!, sonar, all the pins for MegaPirateNG More memory for all the features, future proofing for all the amazing new software updates. like way-points, GPS, LED RING, OSD, RTH autoland failsafe, and more
Get all the updated hardware here:
http://www.readytoflyquads.com/fligh...rs/flip-series
QUADRINO - Ready-to-Fly Flight Controller - Arduino Compatible with 10-DOF IM
The Quadrino Flight Controller is a ready - to- fly alternative to the complicated process of gathering the many separate pieces required to make a MultiWii multi-rotorcopter
The Quadrino includes the Arduino micro-controller, Gyro, Accelerometer, Barometer, Magnetometer and on-board usb interface. Plugin your radio receiver channels and ESC motor wires and you are ready-to- fly.(1)
The Quadrino supports all MultiWii features such as auto-level mode (acc mode), heading hold (mag mode), and altitude hold (baro). There is a cheaper alternative that removes the magnetometer and barometer.
Feature & Benefits
  • 100% fully arduino compatible. (based on Arduino Nano v3)
  • Uses stock MultiWii source code requiring only a few #define parameters to be set based on your setup.
  • Contains ITG3200 Gyro.
  • BMA180 Accelerometer.
  • 400KHz I2C bus supported.
  • Servo ports for camera mounts (SRV1 & SRV2). For camera stabilization.
  • Works in Quad+, QuadX and also Tri or Hex/Y6 copters.
  • Mini-USB connector on board - direct connection!
  • Protection diode prevents USB from powering ESCs/motors, but powers receiver
  • Forget the datasheet at home, all headers, signals, and diagrams are labeled on the PCB!
  • 62mil PCB is strong and sturdy to survive hard crashes or rough landings.
  • 8 mounting holes support most standard mounts.
  • Lower control-loop cycle time than popular Wii/nunchuk units translates to more stable flight . (avg. 2500 versus 4500.)
  • Wiring can be pulled up through the center of the PCB for less wire mess
WIRING THE QUADRINO
The following icons are used on the PCB to indicate the type of signal. These icons make wiring in the field simple even without this datasheet.
THE RECEIVER
The Quadrino YPTR header is used to connect to the radio receiver.
If a PPM decoder is used, the THROTTLE pin become the PPM input
If you have a 5 or more channel receiver you should wire one AUX channel to the mode pin. This allows the control of flying mode via the transmitter. You can use a 2 or 3 position toggle on the transmitter to switch between acrobatic mode accelerometer mode, and enabling of the barometer and magnetometer sensors for heading and/or altitude hold.
MultiWii copters can change into various flight modes. The activation of each sensor determines how the MultiWii will fly.
ACCELEROMETER Provides auto-level flight. The copter will maintain a level pitch and roll when the transmitter controls are in their default position. Before use, the accelerometer must be properly calibrated.
MAGNOMETER Maintains the same heading counteracting any yaw drift. This is a nice feature for beginners who are busy concentrating on controlling the pitch and roll of the copter. The mag sensor will keep the copter pointed in the same direction from takeoff to landing.
BAROMETER When activated this sensor will keep the copter at the same altitude within a small amount of error. This works best in low wind conditions. Activating the barometer close to the ground can cause greater error as the backwash from the rotors contribute to the pressure on the sensor
CONFIGURING THE MODE SELECTOR
The picture shows the controls within the MultiWii config program
that configure how the mode switch (the AUX1 or AUX2 channels) map to the various flight modes. By toggling the state of the white squares you can map the state of the AUX pin (Low, Mid, or High) to which sensors are made active
everything is labeled on the PCB
Download the code here:
http://code.google.com/p/multiwii/so...se/#svn%2Ftags
Here is a 1.7 file with all the code changes ( the one shipped with the board)
http://hotfile.com/dl/119662624/27f1...iV1_7.pde.html
You will see mac and windows folders.
drivers are here.
http://www.ftdichip.com/Drivers/VCP.htm
datasheet here:
https://docs.google.com/viewer?a=v&p..._74YC&hl=en_US
Supply voltage is 5v-6v maximum. NEVER attach 12v power to any part of the board. Use Nylon screws. Metal screws and posts will effect sensors especially magnetic based devices.
Quadrino Basic
- Includes ITG3200 Gyro and BMA180 Accelerometer
- Accelerometer provides auto level features
- 95$ USD
Quadrino ADV
- Quadrino Basic plus BMP085 Barometer and HMC5883 Magnetometer
- Baro and Mag provides altitude and heading hold features
- 145$ USD
Shipping is via USPS Flat Rate Small Box. Shipping rates are per shipment, not per unit, so pay shipping only once.
- 5.20$ USD within mainland United States
- 11.95$ USD to Canada
- 13.95$ USD to anywhere else
Now shipping.. PM me to order.
Picture (pins installed on all board unless requested) :
NOTE : You can also buy this board in a ready to fly quad!!!
Features:
Quadrino ADV with Baro and Mag provides altitude and heading hold features
450MM motor to motor for extra stably, Super power-full keda motors ,Adjustable landing gear. Easy to find parts. Built in lipo alarm, and auxiliary power hook-up. protective Cover dome, Orange propellers and ball ring to aid in orientation , sleek mesh covering.
PM me for pricing...
http://www.rcgroups.com/forums/showthread.php?t=1416168
Settings information:
The following steps were made to prepare the stock MultiWii code for the Quadrino ADV board:
1. Define your appropriate MINTHROTTLE depending on your ESCs
2. Choose multicopter mode: TRI, QUADP, QUADX, Y4, Y6, HEX6, HEX6X
3. Enable 400kHz i2c mode (I2C_SPEED = 4000000L)
4. Enable the following config defines:
ITG3200
BMA180
BMP085
HMC5883
5. Uncomment MOTOR_STOP. (This is our recommended setting.)
Connections examples:
(1) Firmware upload may be required if your setup differs from the default settings.
here come the Videos: (please send me yours if you have any )
MultiWii Altitude Hold (4 min 8 sec)
MultiWii Compass Recovery (2 min 8 sec)
MultiWii Stability Recovery (2 min 32 sec)
Multiwii Quadrino Acro-Flight (3 min 12 sec)
quadrino (3 min 0 sec)
witespy Vic450 quad
witespy quad 450 (2 min 36 sec)
Fun sport frame..
FILE0004 (5 min 45 sec)
quadrino's X2
FILE0017 (2 min 37 sec)
witespy is offline Find More Posts by witespy
witespy is offline
Joined Sep 2009
radio Settings :
Setup video:
How to set your radio for witespy quad/quadrino. (7 min 11 sec)
radio pictures Dx7
YAW
ROLL
pictures of board installed in a quad:
pictures of board installed in a Y6:
Old May 12, 2011, 02:45 PM
easystall is offline
Find More Posts by easystall
Joined May 2008
The only thing that i`m missing is the 4 bl ctrl on the back side....its enough space on it.
To make a small one with some extensions to mount a small motor with 4x2.5 on it.
That would be perfect...
michael
easystall is offline Find More Posts by easystall
Old May 12, 2011, 03:12 PM
witespy is offline
Joined Sep 2009
You can also buy this board in a ready TO fly quad!!!
info here, or PM me for special pricing...
Easy to find parts.
Orange propellers and ball ring to aid in orientation .
videos from other users
Test Quadrino Multiwii (1 min 39 sec)
Lunar Lander 4 + Quadrino (2 min 31 sec)
Quadrino/witespy quad open field flying! (2 min 57 sec)
custom y-6 built by me for badbill
Quadrino MultiWii Y-6 (2 min 33 sec)
seadog Frist quad (good for frist timers)
Colins New Quadrino Board. (3 min 21 sec)
Quadrino test1.mpg (2 min 24 sec)
Pics
FOR FUTABA ONLY
GUI explained :
The Quadrino AVD will have all the sensors neat and clean on the board.
Here is a "basic" quadrino . (older picture too . all printing is white on the basic boards now.) ...with do IT YOURSELF upgrade with compass and barometer . This can be done one sensor at a time as you feel like you want to add more . PLEASE NOTE!!! the advance option has all the sensors flat and neat from the factory! These extra boards showen in this picture are only needed for basic boards that are to be upgraded at home!
more custom quad options : here are ones built and flying.:
Old May 12, 2011, 04:00 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
This looks very sweet, I am considering a purchase.
Questions...What do you do for sensor vibration?? Are you mounting the board solid on your quad? Can we see a flight test clip?
Thanks!
power is offline Find More Posts by power
Old May 12, 2011, 04:11 PM
witespy is offline
Joined Sep 2009
These sensors can take some vibration.
Just make sure your props are balanced and motors shafts are not bent, and you should be good to go.
you can add some Rubber Grommets if wanted, But should not be necessary. Mounting the board solid on your quad is ok, I am using super simple stand-offs.
http://www.horizonhobby.com/Products...odId=JRP960072
Or get the mac daddy of anti-vibration standoffs, and never worry about it again.
https://www.mikrokopter.us/shop/inde...&product_id=77
Old May 12, 2011, 07:28 PM
nicnaimless is offline
Find More Posts by nicnaimless
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
Very enticing.
nicnaimless is offline Find More Posts by nicnaimless
Old May 12, 2011, 07:58 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
I have the new Quadrino board on my quad, and it works as advertised. it is a night and day change from the old Wiiadrino boards. and very easy to setup. I will be posting videos this weekend.
tc3wins is offline Find More Posts by tc3wins
Old May 12, 2011, 09:48 PM
ddmt is offline
Find More Posts by ddmt
Gravity sucks :)
Indonesia
Joined Jul 2005
witespy, that's a really clean quad you have there
BTW have you try the magnetometer? Some (not all) users (mine works OK) for the Jussi's FFIMU (which has the HMC5883L) have problems with the magnetometer. Could you please try it with multiwii dev0508? Don't fly it, just look at the value of the mags, if there are constant 500 or -500 then the mags are not OK. Thx.
ddmt is offline Find More Posts by ddmt
Old May 12, 2011, 10:03 PM
cactus is offline
Find More Posts by cactus
United States, CO, Durango
Joined Sep 2001
Mine should be here tomorrow. So it looks like all the ESC's are only signal wires and one or more of the board to ESC connections are signal pin only?
cactus is offline Find More Posts by cactus
Old May 12, 2011, 10:09 PM
aerorotor is offline
Find More Posts by aerorotor
Joined Oct 2009
What do you charge to build a quad?
aerorotor is offline Find More Posts by aerorotor
Old May 12, 2011, 10:48 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
Any hook ups for Camera control
NaterPin is offline Find More Posts by NaterPin
Old May 13, 2011, 11:29 AM
witespy is offline
Joined Sep 2009
The all the mags I have tested work very well, the value changes and look very smooth on the GUI. Will post a clip.
PM me
Yes. there are servo1 servo2 Outputs for camera control
Not understanding 100%. Each speed controller has there own Pin. You only need the signal wire if your powering the board with a BEC .
Old May 13, 2011, 11:41 AM
witespy is offline
Joined Sep 2009
I do not power the board with all my ESC's, but you can no worries.
I power all my FC's with one BEC.
BUt you can just plug in all you ESC into those pins, No problem
no ground loops this way..
Old May 13, 2011, 12:09 PM
witespy is offline
Joined Sep 2009
The pins can also be connected at the bottom of the board if you wish.
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
