Old May 12, 2011, 04:02 AM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Clean Sweep - a 48" sportster with a swept forward wing!
Mornin' all!
I just thought I'd post a few pics of the latest proposed project - featuring a swept froward wing and T-tail. Just to be different really......
I've yet to cut any balsa, but the plans are well advanced.
tim
tim hooper is offline Find More Posts by tim hooper
Old May 12, 2011, 08:19 AM
JRuggiero is online now
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
Tim,
Good on you! The late, great American model designer, writer and editor, William Winter, published a swept-forward wing design in Radio Control Modeler about 15 years ago. That design was also tailless, IIRC. I don't have the article. I'm sorry I can't help more.
Jim R.
JRuggiero is online now Find More Posts by JRuggiero
Old May 12, 2011, 11:36 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Yo Tim
You're coming along nicely as head designer of the off-beat, and this is a fine sports model example. Good luck with the project.
Looks an interesting mix of small racer cum small sporting aircraft for those whose bank managers are fussing at for not spending on a new hobby this month
Wing's interesting - I lean to 12% - 14% percent on account of thinner tends to demand going much faster throughout the envelope.
Also lean to D box sections - as stiff as fully sheeted, but quicker, lighter and, most important to a Yorkshireman - cheaper.
D
Dereck is offline Find More Posts by Dereck
Old May 12, 2011, 01:03 PM
MustangAce17 is offline
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
Tim,absolutely love that design,perfect for what i like to fly,any chance the plans will be available?
MustangAce17 is offline Find More Posts by MustangAce17
Old May 13, 2011, 04:01 AM
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Cheers lads!
Dereck, I'm also an advocate of the 12% aerofoil, but I wanted something a little bit thinner for this one, not only to reduce drag, but also for appearances sake. The price of aesthetics, eh?
Must17, glad you like it! If it flies as it should, then it'll probably be submitted for publication. Let's hope so anyway!
tim
Old May 13, 2011, 07:31 PM
Dereck is offline
Joined Dec 1996
She has a good mix of 'different', to which we all should strive, and 'if it looks right, it should fly right'.
The 10% wing is watched with nearly bated breath
D
Old May 13, 2011, 07:42 PM
Danjuan is offline
Find More Posts by Danjuan
Huh?! well waddayouknow!?
Slackramento ,CA
Joined Jul 2006
subscribed
Danjuan is offline Find More Posts by Danjuan
Old May 14, 2011, 04:17 AM
ChrisS is offline
Find More Posts by ChrisS
Really?!?
ChrisS's Avatar
Lost ...on the 3rd rock out
Joined Sep 2001
"The late, great American model designer, writer and editor, William Winter, published a swept-forward wing design in Radio Control Modeler about 15 years ago. "
Bill must have liked forward swept planes. I built one of his designs, called a Goblin. Also had a forward swept wing. And a huge V tail. Ugliest plane I ever made, built it "because I could" really. Turns out that it flew really well.
Looking good Tim. I like the mix of conventional with subtle "not so conventional" thrown in. I bet it will fly well.
Chris
ChrisS is offline Find More Posts by ChrisS
Old May 14, 2011, 09:06 AM
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Cheers Guys!
Some more progress this morning, in that I've got the ribs and spars glued to the bottom skins, following which we had a re-think about the slightly-tubby fuselage, and slimmed it down a tad. Look any better?
tim
Old May 14, 2011, 10:14 AM
Dereck is offline
Joined Dec 1996
Can't beat a curvy rear end
(Ducks...)
Dereck
Old May 14, 2011, 11:12 AM
tim hooper's Avatar
Telford, UK
Joined Feb 2000
(Ducks...)
Dereck
Don't call me 'ducks'........
tim
Old May 14, 2011, 08:59 PM
Dereck is offline
Joined Dec 1996
Quack, quack
D
Old May 15, 2011, 04:59 AM
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Back to our scheduled programming.....
I've joined the wing panels (20mm dihedral under each tip) with braces cut from 1.2mm aluminium sheet - both of which have slightly bent in the middle to allow for the sweep.
Good, eh?
tim
Old May 18, 2011, 01:03 PM
EDF Addicted
Joined Sep 2005
Thanks Tim,looking forward to it,very racy!
Old May 18, 2011, 04:44 PM
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Let's not count our chickens before they're hatched, eh?
More progress today; now that the wings are skinned, I've been able to cut the ailerons free and set about shaping the tips.
Then this evening saw the start of the fuselage sides.
tim
Build Log B-Rang; Single Sheet KFm2 Far Swept Wing - With Video and plans Quick61 Foamies (Scratchbuilt) 48 Nov 17, 2011 10:02 AM
Question Tapered wing tip sweep- forward or back advantages/disadvantages??? Pauliwog Thermal 21 Jul 26, 2011 11:24 AM
Rave The Golden wing is a 60" forward swept wing for thermal/light air slope. kylekroker Flying Wings 47 Oct 17, 2008 11:37 PM
Build Log Forward Swept Wing with functional canard project BlueFielder Foamies (Scratchbuilt) 12 Jan 04, 2008 01:56 PM
Need help with airfoil design on forward swept wing... kalare Electric Ducted Fan Jet Talk 2 Dec 31, 2005 04:05 PM
