Old May 11, 2011, 09:56 PM
MNDUCKHUNTER is offline
Find More Posts by MNDUCKHUNTER
I can fly
MNDUCKHUNTER's Avatar
United States, MN, St Paul
Joined Sep 2007
arc motor bent shaft
powered up my ARC 28mm MOTOR ARC-28-58-1 3180Kv
with 4.75 4.75 prop with amp meter 70 amps shaft bentalmost 90 degrees how can this do this
MNDUCKHUNTER is offline Find More Posts by MNDUCKHUNTER
Old May 12, 2011, 07:42 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
What happened? You powered up a motor and it bent the shaft 90 degrees? It is not clear what happened.
Jack
jackerbes is offline Find More Posts by jackerbes
Old May 12, 2011, 09:25 AM
crypto666 is offline
Find More Posts by crypto666
USA, NV, Caliente
Joined Mar 2009
Did you balance your prop?
crypto666 is offline Find More Posts by crypto666
Old May 12, 2011, 09:59 AM
Jack
USA, ME, Ellsworth
Joined May 2008
OK, I think I get it now. That must have been pretty exciting until you got it shut down.
What was the battery voltage or RPM? Any idea?
Jack
Old May 12, 2011, 04:52 PM
I can fly
Joined Sep 2007
i was flying my fun jet on 4 cell 26.50 i decided to try 5 cell 3.000 i put amp and wat meter to check amp draw i got to 80 amps and it bent and stop scary and yes prop balance had 10 flight s on it i hope this help i hoping this was a fluke i wood like to stay with the same motor as it performed well but i dont no if shaft are weak not harden thanks for the help chris
Old May 12, 2011, 05:00 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Could you tell if the prop had lost a blade under power? That could throw it badly out of balance.
The prop should have been mounted as close to the motor as possible, if there was quite a bit of distance between the back of the prop and the motor, that also makes the shaft easier for it to get bent.
And the bend happened during a run up? Not in flight.
Tell us the motor you were using and we can tell if you were exceeding the RPM limits for the prop.
Jack
Old May 12, 2011, 05:10 PM
USA, NV, Caliente
Joined Mar 2009
I experience this same thing once with a 28mm Ammo and a balanced edf rotor. It was primarily due to the flat cut halfway through the shaft; poor engineering.
I only have one Arc (36mm, love it) and it doesn't have a flat cut into the shaft, so I assume yours doesn't either?
Jack has a good point about how far out on the shaft the prop is sitting; closer is stronger.
Old May 12, 2011, 05:13 PM
Jack
USA, ME, Ellsworth
Joined May 2008
I looked at the Multiplex Fun Jet to see what it is, it is a pusher with a small prop in the back. So I am assuming he has an inrunner with a small prop on it.
Jack
Old May 12, 2011, 06:03 PM
I can fly
Joined Sep 2007
motor
prop is still fine happened during a run up
Old May 12, 2011, 06:05 PM
Jack
USA, ME, Ellsworth
Joined May 2008
And how far away from motor is it when mounted and how is it mounted?
I ask that because if there is just a little imbalance and prop is mounted some distance from the motor it can do what happened to you.
Jack
Old May 12, 2011, 06:11 PM
I can fly
Joined Sep 2007
about
1/4 inch
Old May 12, 2011, 06:12 PM
I can fly
Joined Sep 2007
thanks for all the help
jackerbes
Video Example: Bent feathering shaft. Hegemone Fuel Heli Talk 1 Jun 19, 2011 03:14 PM
Sold Align Faigao Clone KV? Used in TM400, broken gearbox, BB shaft not bent Blue Heat Snk sa-10 Aircraft - Electric - Power Systems (FS/W) 2 Apr 19, 2011 05:30 PM
Discussion Microdan bent shaft - anybody replaced one Tom Harper Power Systems 3 Mar 28, 2011 06:52 AM
Sold arc 28-47-2 turn motor bent shaft f4addict Aircraft - Electric - Power Systems (FS/W) 1 Mar 16, 2011 07:30 AM
Video Example: Bent feathering shaft. Hegemone Electric Heli Talk 0 Mar 04, 2011 09:52 PM
