Old May 11, 2011, 12:13 PM
brawl100 is offline
Find More Posts by brawl100
United Kingdom, England, North York
Joined May 2011
Nine Eagles Sky Runner Trimming
Hi
Just got Nine Eagles Sky Runner electric powered glider. Only flown free flight gliders (30 years ago) RC planes, boats and cars. The plane porposies when under power the more the power the bigger they get. Glides OK when not under power. Think it is just the trim but with both weight and elevators not sure were to start. In the past the balsa modles I built had c/of/g marked on the plans, no marks on plane and no real instruction. Under very low power I have kept it in the air for 20 min so getting hang of it.
brawl100 is offline Find More Posts by brawl100
Old May 11, 2011, 01:23 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Sounds like the COG is a bit too far back. But then again, if it glides nicely, then it's not far out.
It really depends what you want. If you're mostly climbing under power and gliding down, then leave it and see if just trimming will work. But if you're mostly under power, then move it back a few mm and see what happens.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old May 11, 2011, 06:00 PM
brawl100 is offline
Joined May 2011
Thank you got it a bit better tonight glide near perfect under low power fine but on full power bad. Mansged to have a single flight of 30 min so not doing to bad. I will play around ith cog in the morning
Old May 12, 2011, 07:55 AM
PinkYakRC is offline
Find More Posts by PinkYakRC
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Yep, CG must be too rearward.
PinkYakRC is offline Find More Posts by PinkYakRC
Old May 15, 2011, 10:25 AM
brawl100 is offline
Joined May 2011
Hi
Yes cpg wrong to far back put penny on and porposing nearly gone, glide very good still so very happy. Just want air time then on to one with areolons
Old May 29, 2011, 09:52 AM
GertvZ is offline
Find More Posts by GertvZ
GertvZ's Avatar
Netherlands
Joined Dec 2009
Did you put the penny in the nose of the sky runner? So this means the CG has been moved forward. What's the position of your CG now at this moment?
Regards Gert
GertvZ is offline Find More Posts by GertvZ
New Product Nine Eagles Sky Runner deadduck Foamies (Kits) 163 Nov 08, 2014 02:51 AM
Discussion Nine Eagles Sky Eagle chris_wade Beginner Training Area (Aircraft-Electric) 3 Apr 28, 2011 03:50 PM
For Sale Nine Eagles Sky Eagle RTF - $65.00 paulhlee Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Feb 15, 2011 11:23 PM
Wanted Nine Eagles Sky Eagle RTF with aluminium case aidilsyukri98 Aircraft - Electric - Airplanes (FS/W) 0 Dec 06, 2010 07:20 AM
Discussion Difficulty trimming Nine Eagles Solo Pro Single Rotor Tobiah Micro Helis 6 Sep 12, 2010 05:44 AM
