Old Aug 06, 2012, 07:45 PM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Originally Posted by Husafreak View Post
...the air retracts will probably break the door as the retract with so much force.
If you've got air retracts why not just do what I did and add a small cylinder on the door and a micro switch on the nose gear? It's quite simple to do and rock solid (and strong)!
Jack
jfetter is offline Find More Posts by jfetter
Old Aug 06, 2012, 11:58 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Eric,
Jacks 100% right... you should slap me for not thinking about setting up the air cylinder like my A-4
Tam sells a little bracket that hold a micro air switch (like you have for your brakes) when the nose gear comes up it hits the arm on the bracket which hit the air switch and bam door closes
I had this on my A-4 and it was rock solid every time
good thinking Jack....
Ron101 is offline Find More Posts by Ron101
Old Aug 07, 2012, 09:14 PM
Jack G Diaz is offline
Find More Posts by Jack G Diaz
United States, CA, Berkeley
Joined Apr 2005
Has anyone ever had trouble with the nose gear door spring arrangement on the Electra? I have Tamjets nose gear and strut so I did a one piece nose gear door side hinged with control surface hinges as detailed in the build thread. While it all works and looks perfect when the door is open there is very little spring pressure to hold the door. IMHO it would only be a matter of time until the door will be blown against the retracting strut which will catch the door and destroy it. Ronnie came by to have a look and also believes I gotta put a servo in there to operate the door but I thought I would ask first...
Eric
I did it per instructions and it works flawlessly. just make sure there is enough tension on the spring. Make it following the plans, and use the screw on the block to adjust the tension. 100+ flights plus preflight checks and it has never ever failed. And it wasn't even hard to set up.
Can you post some pictures of your set up so I can help you debug it? you can also email them to me if you prefer
An air cylinder will work too, but it adds complexity. You will need either a sequencer or an extra servo with a micro air switch.
PS: Did some great Enduro back home (Caracas) the past couple of weeks!!!! now I really need a bike here
Jack G Diaz is offline Find More Posts by Jack G Diaz
Old Aug 08, 2012, 12:01 AM
hoser is offline
Find More Posts by hoser
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
the basic set up per manual for the std mech. nose gear works great without issue, never had a single problem
the only kit change suggestions I would make is if you go with the regular mech. retracts (which work perfectly) is
1. use one retract servo for each main cause the "s" shaped rod and the 1 retract servo is a PIA do every time you go fly if you constantly are removing the wings for transport.
2. get rid of the bottom hatch and secure the wing spars from the bottom of the spar channels and not the side
I'm with jack simple is best, but that is just me
hoser is offline Find More Posts by hoser
Old Aug 08, 2012, 12:50 AM
Ron101 is offline
Ron101's Avatar
Joined Jul 2007
What you can't see about Eric's setup is he is running the Tam Jets nose gear and strut...
It has about a 1/2 inch 90 degree turn just above the wheel on the strut... this lip is going to hit the gear door and lock it up for sure
If he just had the straight wire gear it would be fine.... but it's not going to work the way it is now
his build is perfect and the door is setup as BVM states..... needs a little mod for Tams strut
Old Aug 08, 2012, 07:06 AM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Actually you only need a micro switch and cylinder to do it the standard BVM way. The nose strut simply makes contact with the micro switch, closing the door (up) and releases the micro switch, opening the door (down), couldn't be easier. Of course to do it right you should also tap off the grey (down) line only for opening the door, to negate air loss while the gear is retracted but the system is quite simple and works well (and if you already use pneumatic gear, seems a no-brainer to me anyway)...
Jack
Old Aug 08, 2012, 12:23 PM
Husafreak is offline
Find More Posts by Husafreak
Husafreak's Avatar
United States, CA, Livermore
Lots of help here thanks! Does that micro switch really open the door fast enough to not have the gear break it off on the way down? I guess it does... Maybe I will go by Tam's today but I don't know if he's open. He hasn't been around lately.
Husafreak is offline Find More Posts by Husafreak
Old Aug 08, 2012, 12:27 PM
lashmett75 is offline
Find More Posts by lashmett75
Not a Drone pilot
lashmett75's Avatar
United States, CA, Sunnyvale
Joined Jul 2008
He has been there everyday this week.
I will be at the shop tomorrow morning @ 930 or so if you want to come by. I can help you out with the parts or setup.
James
lashmett75 is offline Find More Posts by lashmett75
Old Aug 08, 2012, 12:39 PM
Husafreak's Avatar
I may come by this aft on way to work. I tried to upload a video but my camera records in .mov and I couldn't upload it. I'll have to figure that out sometime.
Old Aug 08, 2012, 05:12 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Oh heck yes! The door opens before the strut even has a chance to touch it again. The best part is (if the cylinder is positioned properly), it opens a little more than 90 degrees AND if you cut a small piece of fuel tubing and put it over the piston, when it closes it butts up against the tubing making for a solid close with no sidewall deformation (from the force of the piston). I love it!
Jack
Old Aug 08, 2012, 05:35 PM
Husafreak's Avatar
Thanks Jack, well Tam had a look at my door and he said, well, I'll paraphrase, he said it is fine and not to worry about it. He said the BVM setup is good and the door will stay open. I asked him about the microswitch/cylinder arrangement and he said don't make it any more complicated than it needs to be, LOL. Guesss i have no more excuses... I will certainly be able to use the air piston type on my next EDF project, an Airworld Me262.
Old Aug 08, 2012, 07:05 PM
Joined Apr 2005
Cool, so what´s next? when are we maidening that baby???? can't wait to have some more electras around
Old Aug 09, 2012, 03:22 AM
Husafreak's Avatar
Whats next? Your KTM350 and my Electra!
Old Aug 12, 2012, 05:21 PM
Husafreak's Avatar
I must be doing something wrong as I cannot get the air lines onto the air tank or the plastic T's. I have Tam's air lines, they went onto the gear cylinders just fine but now I'm breaking T's? Sorry to ask here but figured someone would know.
Old Aug 12, 2012, 05:57 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
take a ballend and allrn driver of the appropriate size put it inside the tubing wait a minute then push on the t
Robert Belluomini is offline Find More Posts by Robert Belluomini
Discussion BVM Electra ARF Kevin Murray Electric Ducted Fan Jet Talk 26 Jun 12, 2014 08:13 PM
Build Log BVM Electra ARF build and modifications ralf dvorak Electric Ducted Fan Jet Talk 42 Jan 27, 2012 05:52 AM
Discussion BVM electra/Air blue gear. skyhawk Electric Ducted Fan Jet Talk 0 Apr 25, 2011 05:55 PM
For Sale BVM Electra ARF (RTF) - $4200 chw757s6640 Aircraft - Electric - Jets (FS/W) 11 Mar 12, 2011 09:01 PM
For Sale BVM Electra ARF coupon RicVaughn Aircraft - Electric - Jets (FS/W) 0 Oct 09, 2008 08:43 PM
