Old Aug 03, 2011, 11:34 PM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Originally Posted by gregg f View Post
What, no easy airs?
Jack, I hope you don't plan to connect the airlines manually!
Hey Gregg!
I actually bought a set but then decided with the modified wing mounting I came up with that I should make sure nothing moves before using them. I doubt there is anything to worry about but I want to make sure they don't move (imagine if a slight gap opened up, bye-bye air pressure!)...
Jack
jfetter is offline Find More Posts by jfetter
Old Aug 04, 2011, 12:12 PM
ICRSHLTS is offline
Find More Posts by ICRSHLTS
Two Rivers, WI
Joined Mar 2003
color match
maybe it is some sort of an illusion from the camera then- i paint for a living and see colors everyday- that panel is way "greener" than the boittom of the wing-
just my view on it- great job on the build on your part- can't wait to see it all finished.
Ryan
ICRSHLTS is offline Find More Posts by ICRSHLTS
Old Aug 04, 2011, 12:35 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Ryan
I think it's the angle and/or light, the material IS different too, so that may account for what you are seeing. In person, they look the same.
And BTW, BVM fan or not if they were different, I'd want them the same too!
Jack
Old Aug 04, 2011, 12:59 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
you should find some matching paint for those screw heads
corsair nut is offline Find More Posts by corsair nut
Old Aug 04, 2011, 04:40 PM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Originally Posted by pdawg View Post
Strictlyscale,
Thank you for the compliment! I am in the process of designing the lasercut files for the wing and tails. At that point I might be able to produce a few short kits. Its a small model but it takes more time to produce the glass parts than you'd expect. For that reason I don't think many would be willing to pay for the labor cost.
Keep me on your list (if you start one) to be a home for a potential short kit.
Jack, awesome work!! I'll make sure I don't get any finger prints on this at ejets....although the temptation may be too great!
strictlyscale is offline Find More Posts by strictlyscale
Old Aug 04, 2011, 06:47 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Ryan
The gear doors look like lack of primer or lack of paint coat to match with the wings.
Hope my are not that bad.
Got same color scheme coming.
Tamjets is offline Find More Posts by Tamjets
Old Aug 04, 2011, 07:03 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Well, the material is very different from wings to gear/flap cover plate and strut cover, in person they look the same from any angle IMO. Pdawg is here on Tuesday to take some photos of his mini Electra and mine together, I'll ask him his opinion and ask him to post, in case anyone thinks I can't be impartial...
Jack
Old Aug 05, 2011, 04:42 AM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Jack
Jack,
My background is auto body shop.
I had 10 years experience painting, frame, and body works.
When come to paint.
I can tell how mistake was make.
The wing are paint in the mold.
The guy doing the good job to had proper coats spray in the mold and the color come truth.
The other guy painting door panel, hatch and servo cover.
He didn't follow the formula to had proper coats to match with the wing.
Trust me..when my builder paint.
I breath on his neck all the time and remind him not to screw up.
Once in awhile he did the same things.
Not enough coats one one part and come out different color.
Here is another things about painting.
If parts are spray with light primer. The other parts spray with darker gray primer. That also cause color not truth.
When painting color.
Chose best background primer for best result.
Light gray primer is best for yellow,red, silver, light blue, green.
Dark gray is best for charcal, deep marine blue, black...anything is dark color.
My new Electra will be here monday.
Hope my gear door panel is not bad....
Good things is underneath. If this on top panel and off that much. Someone are fire.
Old Aug 05, 2011, 01:43 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Jack,
My background is auto body shop...
I'm not sure if you want to fight or just want to tell me how it is but it's not an issue. I already said they look the same in-person so just wait and see for yourself, it's all good. There is nothing different about these cover plates and strut covers, they are the same material and use the same paint technique as the bandit and all other BVM planes, relax!
Jack
Old Aug 05, 2011, 01:54 PM
Philadelphia, PA
Don't worry Jack, it will be a yellow blurr, no matter what the shade. Keep at it!
Old Aug 05, 2011, 02:05 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
I don't mind questions and I can take more pictures if necessary in diffrent light, I'm just not sure this is anything to worry about, BV's had a handle on painting techniques for matching parts for a very long time...
Jack
Old Aug 05, 2011, 02:06 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Finishing the wiring now. Last night I glued the wing anti-rotation pins and sockets, on the final stretch now!
Jack
Old Aug 05, 2011, 02:25 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Jack
No fight Jack..
It does look way off in the pictures.
I had built 4 Bandit, 5 Electra...I do run across servos cover are off before.
So hope my are not that bad.
Like you said. It under the wing. No one goes to see it.
Old Aug 05, 2011, 03:08 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
No fight Jack..
I'll take a picture of the completed plane outside today or tomorrow, I think once in natural light you'll see they match. BTW, I have all LED lighting in the room you see in those pictures, it's very harsh...
Jack
Old Aug 05, 2011, 03:39 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Jack
Don't tease me.
The kit be on monday and won't be back to tuesday night to open it.
Discussion BVM Electra ARF Kevin Murray Electric Ducted Fan Jet Talk 26 Jun 12, 2014 08:13 PM
Build Log BVM Electra ARF build and modifications ralf dvorak Electric Ducted Fan Jet Talk 42 Jan 27, 2012 05:52 AM
Discussion BVM electra/Air blue gear. skyhawk Electric Ducted Fan Jet Talk 0 Apr 25, 2011 05:55 PM
For Sale BVM Electra ARF (RTF) - $4200 chw757s6640 Aircraft - Electric - Jets (FS/W) 11 Mar 12, 2011 09:01 PM
For Sale BVM Electra ARF coupon RicVaughn Aircraft - Electric - Jets (FS/W) 0 Oct 09, 2008 08:43 PM
