View Poll Results: Would you like plans for this foamy?
Yes please 24 96.00%
No thanks 1 4.00%
Voters: 25. You may not vote on this poll
Old May 10, 2011, 03:41 PM
demonGti is offline
Find More Posts by demonGti
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
Build Log
Full fuse 3D foamy (with video.. plans now FREE)
Hi gents, its been a while since my last foamy build
But here are the beginnings of my latest full fuse foamy. I'm building it for a mate.
Its not based on anything really, and all of it has been directly drawn onto the foam so there are no plans yet, but I will make up a set of plans and build guide if she flies as expected.
dG
I was asking for a small donation. But this just wasn't working.
There are not enough of these being built and it is such a fun little plane to fly that I am making the plans
available for free here.
Thank you to those who did donate 99c
Now I hope to see many more builds being posted in this thread
Video of the maiden:
Scratchbuild 3D foamy Eratix - Maiden flight (8 min 21 sec)
demonGti is offline Find More Posts by demonGti
Old May 10, 2011, 04:06 PM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
The wingspan is 910mm. I am building with my usual 10mm EPS sheet.. because its cheap and easy to repair the usual damage.
Some more pics...
Old May 10, 2011, 07:56 PM
EZglider is offline
Find More Posts by EZglider
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
Looks Sweet! Nice paint scheme,too. Can't wait for plans, you always do a GREAT job.
EZglider is offline Find More Posts by EZglider
Old May 10, 2011, 11:54 PM
RCSquale is offline
Find More Posts by RCSquale
Sometimes it work some don't
RCSquale's Avatar
Émirats arabes unis, Ras el Khaïmah, Ras Al-Khaimah
Joined Oct 2010
Very nice plane buddy... awaiting too for plan.
Keep it up!
RCSquale is offline Find More Posts by RCSquale
Old May 11, 2011, 12:12 PM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
Thanks guys, well lets hope its a good performer then
I've just added a locating lip and magnets to the canopy for easy battery changes.
I first recess and epoxy one in place in the canopy and cover it with clear tape and let it set keeping it nice and flush with the surface of the foam. Once its set I recess the mating magnet in the plane but make the hole a tiny bit larger. Then epoxy inside the recess, drop the magnet in and cover with a film of epoxy (allows magnet to slide a little). Then place a piece of clear tape over the lot and fit the canopy in place. The slightly bigger hole (but only just bigger) allows you to jiggle the canopy to get a perfect fit... and when the epoxy sets the canopy sits nice and straight.
Old May 11, 2011, 12:50 PM
jholen is offline
Find More Posts by jholen
Ride Blue
jholen's Avatar
United States, WA, Sammamish
Joined Aug 2006
Looks great!
jholen is offline Find More Posts by jholen
Old May 11, 2011, 01:57 PM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
This Plane is LOUD
looks awsome and can't wait to see it in the sky.....and fly it gents this baby is for me.sure to be a cracker.welldone Demon
chop stiX is offline Find More Posts by chop stiX
Old May 11, 2011, 02:25 PM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
Hey.. Welcome to RCG mate!
Old May 11, 2011, 03:47 PM
Nigels_world is offline
Find More Posts by Nigels_world
USA, ME, Ellsworth
Joined May 2010
Looks great... I still want to build your edge 540 except use all epp for the construction.
Nigels_world is offline Find More Posts by Nigels_world
Old May 11, 2011, 04:48 PM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
EPP would be great, you can then get away with a thinner sheet for the wings, EPS gets quite weak in anything under 10mm for large panels.
If you do eventually build one please share your progress in the Edge thread.
Old May 14, 2011, 04:57 AM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
A box of tongue depressors is cheap and they are light and come in very handy for all sorts of things. I've laminated two pairs together with wood glue to make a base to screw the landing gear to. Recess where you want the wood to go and glue it in place. !00mm or so should fine to adequately spread the load so the gear doesn't rip off too easily... Painted over with red to "hide" the wood.
Next up will be to reinforce the rudder to accept the tail wheel...
Old May 14, 2011, 10:25 AM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
OK, the rudder needs to be reinforced for a wire tail wheel assembly.
Cut three equal pieces ±40mm long of wood (i used tongue depressor again)
Glue together with CA leaving a "groove" to accept the wire for the wheel.
Mark the location in the centre of the rudder and remove enough material for the wood to fit in nice and snug.. then glue into place.
Old May 14, 2011, 10:35 AM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
I fabricated landing gear out of a piece of ally plate. Mark, cut, file and bend.... simple really. But CF landing gear could be nice too.
I wasn't going to make wheel pants for this plane, but I gave it a second thought and decided it would look way better with a pair of pants on
They're just two cut pieces of foam glued together. I'll sand some roundness into them and slap on some paint as soon as the glue dries.
Old May 14, 2011, 11:00 AM
chop stiX's Avatar
Joined May 2011
Ahhhhhhh I like lookin awsome.can't wait to see it fly lovin the wheelpants
Old May 14, 2011, 11:40 AM
100mph is offline
Find More Posts by 100mph
Our God's Alive
100mph's Avatar
United States, NE, Bennet
Joined Mar 2011
Looks great, I wonder what the weight is going to be?
100mph is offline Find More Posts by 100mph
Build Log Full fuse Sukhoi SU-26MX based on the 3D Foamy Profile ukdalai Foamies (Scratchbuilt) 4 Nov 29, 2010 07:32 AM
Full Fuse 3D Foamy Extra Fly-n-3D 3D Flying 9 May 18, 2008 10:53 PM
My second full fuse 3d foamy... Picoflyer 3D Flying 5 May 29, 2005 10:15 PM
Anomaly 3d - Room for 1 more full fuse foamy?! ryanl2006 3D Flying 54 Apr 25, 2005 11:00 PM
3d foamy / The winds of change... Full fuse kits??? Ben-Rod 3D Flying 7 Apr 03, 2005 03:09 PM
