This thread is privately moderated by c2po, who may elect to delete unwanted replies.
Old May 10, 2011, 03:22 PM
c2po is offline
Find More Posts by c2po
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
Build Log
ITG3205 plus BMA180
I thought that blue Wii Motion+ board with ITG3205 gyro on it is too big for me so decided to cut off unneeded parts.
And also mated it with the Sparkfun BMA180 accelerometer breakout board.
Works good and it's really tiny...
c2po is offline Find More Posts by c2po
Old Aug 11, 2011, 06:12 AM
iancl is offline
Find More Posts by iancl
Joined Aug 2011
Hey c2po,
What language and micro are you using to connect to the gyro? I've got a teensy and I've successfully read the WHOAMI register off the ITG3205, but I can't get proper data from other registers. In fact, the only registers which give non-zero data (seemingly random data) aren't those expected from the datasheet. Does the ITG3205 behave the same way (interface-wise) as the ITG3200?
iancl is offline Find More Posts by iancl
Old Aug 11, 2011, 11:11 PM
c2po is offline
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
Hey iancl,
Welcome to the forums!
I use Arduino boards, which uses Arduino language, it is based on Processing and very close to C/C++ but simplified a little bit for beginners.
Mainly that project is for the MultiWiiCopter initially based on cheap Wii Motion+ boards as a gyro, and Wii Nunchuk boards as an accelerometer. You can find more information in the thread about MultiWiiCopter.
From what I experienced that ITG3205 has exactly all the same specs as ITG3200 and I used ITG3200 specification from Invensense, and I was able to read all the registers I needed, including 3 axis gyro data, temperature, and whoami.
Let me know if you need any samples of the code for Arduino, I can post it here, I borrowed it from other project and just modified a little bit.
For Sale TRex 600 & TRex 450 plus DX7 bnty22 Aircraft - Fuel - Helis (FS/W) 2 Mar 10, 2011 05:31 PM
Off Site tmaxx 2.5 3.3 complete cvd upgrade center and axle drives plus more ZEROSKIN76 Cars - Trucks and Parts (FS/W) 0 Mar 05, 2011 07:30 PM
For Sale Smart Plus 3E LPC1080 2-5s Lipo Balance Charger SkyHigh3d Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 03, 2011 12:24 PM
For Sale Jeti 30 Plus, 18 Plus, and 12 Plus ESCs Rob02Aggie Aircraft - Electric - Power Systems (FS/W) 2 Nov 20, 2010 01:13 PM
