Old May 10, 2011, 06:31 AM
tdriver is offline
Find More Posts by tdriver
tdriver's Avatar
Athens GR
Joined May 2003
26cc zenoah PUM convert to RC version?
hi
can anyone confirm if the marine engines are convertable to RC engines just by changing the crank case flywheel and ignition coils?
the parts look similar and interchangeable but i would like to know for sure.
tdriver is offline Find More Posts by tdriver
Old May 10, 2011, 07:04 AM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
The marine engines are set up for water cooling and would also need a new air cooled cylinder. A good source for all the parts is www.whobbies.com
pmpjohn is offline Find More Posts by pmpjohn
Old May 10, 2011, 07:40 AM
sleepwalker is online now
Find More Posts by sleepwalker
sleepwalker's Avatar
United States, PA, Clearfield
Joined Jan 2007
I was going to do that to a G260 PUM and was told that I would just need an air cylinder and prop hub.You would have to take off the pull start,but unless you wanted to go with an electronic ignition, you would leave the existing ignition on the engine. http://www.advantagehobby.com/produc...=74943&cat=375
sleepwalker is online now Find More Posts by sleepwalker
Old May 10, 2011, 10:04 AM
tdriver is offline
tdriver's Avatar
Athens GR
Joined May 2003
i'm more concerned about the crankshaft, the RC crankshaft is a full circle crankshaft the marine not.
and i'm not sure if it would fit in a "marine" crank case (and vice versa).
....and if it would fit, would it be balanced correctly with the "other" flywheel?
i was told the rc crankshaft is a bit wider,but where exactly i don't know.
is the shaft longer? are the counterweights wider?.....i have no idea....
Old May 11, 2011, 08:46 AM
Joined Jan 2007
From what I can find from places that sell the parts the crankcase and crankshaft are the same for a G260 air,marine or heli engine and the crank isn't a full circle crank.In the marine version there was some guys who converted it to a full circle but I think they had to do some work to the crankcase to get some extra clearence for the full circle crank.
http://www.advantagehobby.com/produc...roductid=74950
Old May 11, 2011, 05:58 PM
Tonystott is offline
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
There cannot be any need to change clearances to fit a full-circle crank (these are more commonly referred to as "stuffed" cranks) as there must already be room for the part which uses the full diameter already. Check out the engine section of Dave's Motors for more info.
http://www.davesmotors.com/site/index.html
Tonystott is offline Find More Posts by Tonystott
Old May 11, 2011, 07:27 PM
txt killer is offline
Find More Posts by txt killer
Joined Apr 2008
Originally Posted by tdriver View Post
hi
All parts are interchable, but the cost of the parts and time to change one over is not worth the effort. Your better off buying another engine.
txt killer is offline Find More Posts by txt killer
Old May 12, 2011, 06:14 AM
Joined Jan 2007
Here's some pics of the inside of a Zen G26 air http://tech.flygsw.org/g26anatomy.htm
Old May 13, 2011, 08:21 AM
Joined Jan 2007
The info on Daves Motors also states that a modification to the case has to be done. http://www.davesmotors.com/s.nl/c.88...t.A/id.1296/.f Also according to engine builders/modifiers on Jim's Boat Dock, a kit is needed to fit the crank in because of a difference in the shape of the crankshaft.
Wanted Parts to convert a Zenoah 80 to electronic ign. sodbuster 1 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 20, 2011 05:37 PM
Help! Build boat with Zenoah 26cc boatrc Racing Boats - Internal Combustion 9 Mar 24, 2011 03:42 PM
Discussion Zenoah 26cc magnito problem and question Disarray Engines 2 Mar 19, 2011 05:07 AM
Discussion Engine Wont Start - Please Help (urgent) Petrol 26cc G260 PUM richclausen Racing Boats - Internal Combustion 4 Dec 16, 2008 07:41 PM
Off Site Win a Zenoah 260 PUM engine sleepwalker Boats (FS/W) 0 Apr 10, 2008 08:39 PM
