Old May 08, 2011, 02:34 PM
webgeek is offline
Find More Posts by webgeek
Joined Sep 2004
Will this work for an octocopter frame design?
Stupid question, but will a frame like this work for an octocopter? I ask because the arms don't go straight into the center of the frame as is typical. The lines in the picture represent the arms, the circles are the rotor blades movement. I'd be using the Hoverfly Pro board as controller. Thanks!
-Mike
webgeek is offline Find More Posts by webgeek
Old May 09, 2011, 12:43 AM
eLviSH is offline
Find More Posts by eLviSH
Joined Mar 2006
yes it will work, and has been done before
eLviSH is offline Find More Posts by eLviSH
Old May 09, 2011, 01:31 AM
Centurian is online now
Find More Posts by Centurian
MultiWiiHead
Centurian's Avatar
Corvallis OR
Joined Apr 2004
just remember that there will be some torque on the long arms... I wouldn't do them in wood, use alum or composite
Centurian is online now Find More Posts by Centurian
Old May 13, 2011, 12:59 PM
jes1111 is offline
Find More Posts by jes1111
United Kingdom, England, Weston-super-Mare
Joined Jul 2010
Yes, of course it will work - but beware of having the blades as close to each other as your diagram represents: the airflows off the tips of adjacent props will interfere with each other and cause potential problems.
A wiser, more experienced builder than me reckons the rule-of-thumb should be to have one propeller diameter of space between adjacent propellers.
jes1111 is offline Find More Posts by jes1111
Old May 13, 2011, 01:40 PM
kosins is offline
Find More Posts by kosins
Consistently Inconsistent
United States, OH, Dayton
Joined Feb 2011
I don't think that part highlighted in red is correct.
My MK Okto has less than an inch between blade tips.
For the "diameter" of the blade pattern to a have prop's length between blades, the arms would have to be very long.
kosins is offline Find More Posts by kosins
Old May 13, 2011, 02:16 PM
jes1111 is offline
Joined Jul 2010
That's why I attributed it to someone else - unfortunately cannot find the reference - he's on of the best acrobatic flyers I've seen . It makes sense to me, though - and just because many craft break the "rule" doesn't make it invalid.
Old May 13, 2011, 03:44 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
if you're building an Octo with 12" props and place a foot of space between the 8 props you would have a gigantic Octo
about 5 feet across
from my experience bigger MRs are more stable, but if you go too big you'll lose yaw authority.
i don't have any experience with the Hoverfly board so i can't judge but some boards are just fine with just 1-3 inches between props
Moe
mkmkmk13 is offline Find More Posts by mkmkmk13
Discussion Will this Wing work for flying electric kallie20 Flying Wings 7 May 09, 2011 04:23 AM
Discussion Will this battery work for a V450D01 PRO ? Apphoard Electric Heli Talk 2 Mar 19, 2011 02:59 PM
Question will/should this work kraft61 Batteries and Chargers 1 Mar 06, 2011 06:42 PM
Help! will this work kraft61 DIY Electronics 0 Mar 06, 2011 04:43 PM
Discussion will this Gearbox work with this motor falcbenry Power Systems 11 Mar 05, 2011 05:07 PM
