Scratchbuild (STOL) Carbon Cub SS - built with carbon fibre tubes
After scratchbuilding a balsa Super Cub, it's time for the next one. A Carbon Cub SS. Also based on Ed Westwood plans which are slightly modified for the occasion.
Characteristics, general:
Characteristics, fuse:
Characteristics, wings:
Setup:
To be continued... ![]() Yvo . |
First tryout
A little work done to see how those little tubes handle.
The base plate (ply with two corresponding cf tubes) was done quickly. Glued the "V" together, bent two pieces of pianowire and put things together.
(Oh, and we didn't maiden the red SC yesterday, will be somewhere next week now) ![]() Yvo .
Couldn't resist
Vertical stabilo:
- 2mm cf tube as outline - 1mm cf tube in between - pianowire in the joints And it is very (very) rigid, perfectly flat, perfect fit and very light. And to be honest, so far it is more fun to work with than balsa... The challenge was to get the Dubro hinge through. I tried to dremel a slot first, but that didn't work. Next was a razor blade, cf is fibres after all. That worked. Two cuts and the hinges were in. This whole "structure" is below one gram. Promising... That's it for now. Mold first. ![]() Yvo . |
Even worse, I did this wearing white pants and a white T-shirt. And everything is still white ![]() ![]() Yvo |
Rudder
Quicky during lunchtime...
Took me half an hour.
The first strip got 1mm holes in it to get the 1mm cf rod through (very delicate process, the strips may not break). The second strip is added for strength. We call it laminating, Dijko's technique. And this whole thing is 2 gram... ![]() Yvo . |
| Thread Tools | |
| Build Log Winter project - Piper PA-18 Super Cub - Ed Westwood plans - Scratchbuild | Phaeton | Parkflyers | 152 | Apr 13, 2013 01:31 PM |
| Discussion 6-foot scale INDOOR Piper Cub scratchbuild | Michael in Toronto | Indoor and Micro Models | 69 | Jan 27, 2012 08:10 AM |
| Discussion STOL Super Cub | HUMPHREY1957 | Scale Fuel Planes | 9 | Jun 22, 2011 08:25 AM |
| Question Carbon wing strut construction (HZ Super Cub) | themicahmachine | Beginner Training Area (Aircraft-Electric) | 3 | May 12, 2011 06:16 PM |
| Discussion new puppy in the kennel: aeroworks 165" span carbon cub | balsabozo | Scale Sailplanes | 15 | Mar 18, 2011 08:40 AM |
