Old May 08, 2011, 08:58 AM
kallie20 is offline
Find More Posts by kallie20
Always wondering...
South Africa, GP, Pretoria
Joined May 2011
Will this Wing work for flying electric
hi all
I need some advise on my Wing that i'm building,
1. What type of motor should i use
2. What type of batteries,ESC.
3. What type of Propeller
4.Should I use and elevator on this plane?
kallie20 is offline Find More Posts by kallie20
Old May 08, 2011, 10:38 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Yes, it can work. Does your wing have a symmetrical airfoil? Your model could be configured like some of the Plank type flying wings from Radical RC.
http://www.radicalrc.com/category/Radical-RC-E-Kits-190
You might also take a look at the RAZZOR 400 from K&A Models for one approach. It has a fixed horizontal stab and uses elevons for pitch control. Also notable is the tractor powerplant installation.
http://www.kamodels.com/
There is also the Spinsation from Morris Hobbies that flew very well with a thick symmetrical airfoil.
DT56 is offline Find More Posts by DT56
Old May 08, 2011, 11:39 AM
kallie20 is offline
Always wondering...
Joined May 2011
thanx for the info!
I get the picture now of what you actually can do if u just let your imagination flow!
I see that the black and yellow and red plane's elevators and rudder is connected together? How can that then work?
Old May 08, 2011, 12:22 PM
DT56 is offline
Joined Aug 2005
Originally Posted by kallie20 View Post
thanx for the info!
Elevons. The vertical stabs on the Quick Wing are fixed surfaces, not rudders.
http://en.wikipedia.org/wiki/Elevon
Most computer radios have an elevon mix as one of the program features. For radios without that capability, there are add-on mixers available.
http://www3.towerhobbies.com/cgi-bin...&I=LXELT4&P=FR
Though not a wing in a technical sense, you could always build something along the lines of the Sig Wonder. That model uses a standard control arrangement.
Name: Sig Wonder.gif
Description: Name: Sig Wonder 2.jpg
Description:
http://www.sigmfg.com/cgi-bin/dpsmar...FV5.html?E+Sig
You might want to check your CG position with this calculator.
http://fwcg.3dzone.dk/?wing_span=55&...ow_mac_lines=0
Here's an article on airfoils for Planks you might be interested in.
87-Zero-CM-sections
Good luck and welcome aboard RC Groups!!!
Old May 08, 2011, 02:10 PM
fmkit is online now
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
it's harder if your plank configured as pusher
my wing in the video needs half size elevons
I used standard 48" mwcores wing but built sweepless
http://www.youtube.com/watch?v=p7KkqOQBENU
fmkit is online now Find More Posts by fmkit
Old May 08, 2011, 04:59 PM
kallie20 is offline
Always wondering...
Joined May 2011
and the motor? Can you classify the weight according to the motor? I think it wil way about 800grams when finished
Old May 08, 2011, 06:16 PM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
the wing in video: 24g 1500kv motor, gws8040 prop, 3S 3300mAh LiPo
AUW 600g
Old May 09, 2011, 04:23 AM
kallie20 is offline
Always wondering...
Joined May 2011
will that motor carry the weight?
Help! Will this transmitter work with this r/c car? Kingston542 Electric Power Cars 4 May 05, 2011 12:27 AM
Discussion Will this battery work for a V450D01 PRO ? Apphoard Electric Heli Talk 2 Mar 19, 2011 02:59 PM
Help! will this work kraft61 DIY Electronics 0 Mar 06, 2011 04:43 PM
Discussion will this Gearbox work with this motor falcbenry Power Systems 11 Mar 05, 2011 05:07 PM
Discussion Will this motor work for a flying wing? Mike4192 Power Systems 6 Jul 09, 2009 09:21 PM
