Old May 07, 2011, 04:20 PM
deegola is offline
Find More Posts by deegola
~Lookout below!~
deegola's Avatar
Las Vegas, Nevada
Joined Jul 2004
Help!
New Optic 6 - Optima 7 RX Range issues
I bought a new Optic 6, with (2) Optima 7 Rx's. I installed each RX in (2) different planes and got everything programmed.
I binded the radio to both planes using the recommended standard binding.
Once I got to the field range check proved that I only was able to walk about 75 feet from the plane before contact was lost.....
This was the identical case with plane #2.
My friend uses an Aurora 9, so we bound a plane to his TX. We even tried it in the alternate binding mode....however, the range issue happened in about the same exact spot.
I can assure you the rx is mounted correctly, and there are no obstructions to the rx antenna(s).
Does anyone have any suggestions as to what may be wrong?
DJ
deegola is offline Find More Posts by deegola
Old May 08, 2011, 01:39 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Once I got to the field range check proved that I only was able to walk about 75 feet from the plane before contact was lost.....This was the identical case with plane #2. My friend uses an Aurora 9, so we bound a plane to his TX. We even tried it in the alternate binding mode....however, the range issue happened in about the same exact spot.I can assure you the rx is mounted correctly, and there are no obstructions to the rx antenna(s).Does anyone have any suggestions as to what may be wrong?Thanks,DJ
Crosspost Answered - Manufacturer's Forum.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Sold NIB Hitec Optic 6 2.4 GHz with 2 Optima 7 receivers - $175 shipped!! rud-elev Aircraft - General - Radio Equipment (FS/W) 2 May 10, 2011 08:57 PM
For Sale Hitec Optic 6 TX with 2.4GHz module and Optima 7 RX Sky_Dancer Aircraft - General - Radio Equipment (FS/W) 7 May 01, 2011 10:44 PM
Sold Optima 9, Optima 7, Optima 6, Optima 6 Lite stickybeatz Aircraft - General - Radio Equipment (FS/W) 2 Apr 13, 2011 02:38 PM
Sold Like NEW Hitec Optic 6 2.4 TX with Optima 7 RX JavaScript Aircraft - General - Radio Equipment (FS/W) 3 Apr 12, 2011 01:13 AM
Sold Optic 6 tx with 2 optima 7 rx, nib sparx22 Aircraft - General - Radio Equipment (FS/W) 1 May 08, 2010 03:52 PM
