Old Oct 17, 2001, 09:34 AM
RookieOne is offline
Find More Posts by RookieOne
Michele Somaschini, Spain
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
Some mistakes with FMS
Hi to all.
I've just finished my serial interface to control FMS with my Futaba FF6 but the software doesn't accepts any signal.
I've tested several times the scheme and all connections and seems to be OK.
In the configuration window there must be selected the I/O Port and Interrupt. Which ones must be selected? Default in my FMS is 03BC and 07 respectively.
When I push "Calibrate" I get the next message: "Can't calibrate a transmitter without signal"
Heeeeeelp.
Thanks in advance
NOTE: I've Windows 95 operating system and two free serial ports. Maybe I've to reboot my PC with the cable plugged in.
RookieOne is offline Find More Posts by RookieOne
Old Oct 17, 2001, 11:51 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
The standard values for COM1 are 03F8, IRQ 4
If that doesn't work have a look in Control Panel, System I think. Certainly your actual settings are in there somewhere (Sorry I can't be more definite, I don't have Win 95).
Steve
steve lewin is offline Find More Posts by steve lewin
Old Oct 17, 2001, 02:01 PM
The_Giver is offline
Find More Posts by The_Giver
Master Nursery Builder
The_Giver's Avatar
Canton, GA
Joined Jan 2001
Steve's right.
You can find your settings in Win95 by doing:
Control Panel
System
Ports
(Select the port that you are hooked to)Properties
Click on the Resources tab.
It should display the I/O range and the IRQ
-O Geoffrey
The_Giver is offline Find More Posts by The_Giver
Old Oct 17, 2001, 02:36 PM
PunkerTFC is offline
Find More Posts by PunkerTFC
Old school newb
PunkerTFC's Avatar
Iraq
Joined Feb 2001
If you are using the same interface I am (and there is a good chance that you are), try 378 and 7. usually the defaults on FMS won't work.
Punker
PunkerTFC is offline Find More Posts by PunkerTFC
Old Oct 17, 2001, 03:28 PM
N. Staffs, UK
Joined Jan 1997
0378 and IRQ 7 are actually for the parallel/printer port. RookieOne specifically said he was using a serial interface which is why I gave him the values for the serial port.
Steve
Old Oct 17, 2001, 03:48 PM
Old school newb
PunkerTFC's Avatar
Iraq
Joined Feb 2001
Oh, ok. I thought they were the same thing. Point well taken
Old Oct 21, 2001, 03:05 PM
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
Hi guys!
Now it's all OK. Transistors were mounted wrong!!!
OK, I'm not an electronics geek but at least I was able to discover the mistake.
What can be expected from a 4 Dollars homemade interface?
Hang in!!
Old Oct 25, 2001, 11:22 AM
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
SLEWIN is right: the right configuration for COM1 is 03F8 and 4.
Interface seems to be OK now but I got problems to calibrate the transmitter.
Graph bars jump up&down madly and when I go to fly, the model simply goes everywhere randomly.
Anyone has tryed this with a FUTABA TX6 (FF&) transmitter??
Old Oct 25, 2001, 01:40 PM
N. Staffs, UK
Joined Jan 1997
The graph bars always jump up and down when you first go in to calibrate but usually they settle down after you move the controls to the full extent a few times. You will still get a little jerkiness but only a little. The next version of FMS will get rid of all that (trust me on this ).
If it's still bad, it helps to have the lead between Tx and interface screened and also the interface to computer socket "lead" should be as short as possible. I build mine on veroboard mounted direct on the D-type socket and they have all been o.k. with lots of different Txs (Futaba/Hitec/JR etc).
Steve
Old Oct 25, 2001, 01:53 PM
Old school newb
PunkerTFC's Avatar
Iraq
Joined Feb 2001
I back up slewin's statement that the new FMS fixes that jumpiness . Don't ask me how I know that, or I'd have to kill you.
Old Oct 26, 2001, 02:33 AM
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
SLEWIN,
The lead I used is screened and I mounted the interface so small that it could be mounted into the D socket.
I used those metalized sockets to avoid interferences.
Anyway, graph bars are still jumping. Do you think the mistake is my Tx?
Maybe the FUTABA TX6 uses different pins than nr 4 and ground.
Old Oct 26, 2001, 04:07 AM
N. Staffs, UK
Joined Jan 1997
Try connecting ground to pin 6 (centre pin) as well as the plug screen. The Futaba encoder connection is actually Pin number 2 (it should be embossed in the plug but very small) but you're probably using the right one because there's no signal at all on Pin4.
Steve
Old Oct 26, 2001, 11:14 AM
JoeR is offline
Find More Posts by JoeR
USA, NY, Jamestown
Joined Jun 2000
when?
So if FMS were to come out with a new version, when might this be? Thanks, Joe
JoeR is offline Find More Posts by JoeR
Old Oct 27, 2001, 03:22 AM
N. Staffs, UK
Joined Jan 1997
Re: when?
It's right there on the FMS website main page (http://simulator.home.pages.de). Beta 7 might be out around Nov 1. This year I believe.
Steve
Need some help with my Starlite. Lucas in Alaska Parkflyers 10 Jan 30, 2002 10:45 AM
Yippee! Hey Guys I Need some advice with trans and rec jayboy Parkflyers 6 Jan 17, 2002 03:14 PM
Need help with FMS to Hitec Fash 5 interface cord? Signal but no channel input. erashby Beginner Training Area (Aircraft-Electric) 9 Sep 15, 2001 11:49 PM
Need some help with my latest plane wim5150 Electric Plane Talk 2 Aug 08, 2001 04:29 AM
Using my controller with FMS spy0o7 Power Systems 4 Jun 30, 2001 08:43 AM
