Old May 07, 2011, 04:37 AM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
BEST smooth servo for GoPro gimbals?
Hi guys
Can you share your experience about best SMOOOTH rotating micro servos?
I'm testing my gimbal, but I'm not 100% happy with TowerPro servos.
They are working, but not as smooth as I need...
I can pay more, but I need warranty that servos will working smooth,
much better than TowerPro. Can you recomend any?
http://www.youtube.com/watch?v=lo64f6hrUCY
Jakub
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old May 07, 2011, 04:49 AM
IWCoburg is offline
Find More Posts by IWCoburg
Member FPV UK
IWCoburg's Avatar
Isle of Wight, UK
Joined Apr 2010
I have been playing with some one another mount here, the best results I have had are from the HG55. I have found that metal gear servo's tend to be a bit notchy when compare against the direct nylon geared equivilent.
Also helps is you can use a bit of gearing instead of a one to one ratio, so you have more servo movement for a given camera tilt movement.
Mike.
IWCoburg is offline Find More Posts by IWCoburg
Old May 07, 2011, 05:09 AM
jack-frank is offline
Find More Posts by jack-frank
Italian Photographer
jack-frank's Avatar
Italy, Veneto, San Donā di Piave
Joined Mar 2010
hi jakub..
how much cost the quad frame in this video??
complete with gopro mount and shipping to italy.
please sent me a private message..
jack-frank is offline Find More Posts by jack-frank
Old May 07, 2011, 05:21 AM
kristjane is offline
Find More Posts by kristjane
Have a nice day! Kristjan
kristjane's Avatar
Slovenia, Novo mesto, Šentjernej
Joined Jan 2006
Hyperion Atlase servos. They are digital and programable. Also they can move up to 175°
kristjane is offline Find More Posts by kristjane
Old May 07, 2011, 05:41 AM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
a geared setup would be smoother as well
Moe
mkmkmk13 is offline Find More Posts by mkmkmk13
Old May 07, 2011, 08:47 AM
Jakub J is offline
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Originally Posted by IWCoburg View Post
...Also helps is you can use a bit of gearing instead of a one to one ratio, so you have more servo movement for a given camera tilt movement.
In this mount axis are reduced <> 1:1.5 (pitch) and 1:2 (roll).
Source of small vibrations are in servo I think.
I just back from local RC store - I have just bought pairs of servos:
TowerPro SG91R, Hitec HS-55, KDS 9g and I have one Hitec HS-65HB
and EMAX ES08MD.
Tomorrow I'll make some comparision with different pairs of gyros...
Jakub
Site Sponsor
Old Sep 01, 2011, 09:50 AM
bfeist is offline
Find More Posts by bfeist
Toronto Ontario Canada
Joined May 2001
Any update on your findings? I'm using a direct HS55 and find the result very jittery:
GY-20A camera stabilization test (0 min 13 sec)
bfeist is offline Find More Posts by bfeist
Old Sep 01, 2011, 10:18 AM
Jakub J is offline
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Originally Posted by bfeist View Post
Any update on your findings?...
No. Still EMAX is the best. Unfortunately not popular...
I'm thinking about my own servo production but this is madness...
q
Site Sponsor
Old Sep 01, 2011, 10:30 AM
michel pet is offline
Find More Posts by michel pet
michel pet's Avatar
nl
Joined Jan 2005
landing gear servo`s are slo en smooth.
michel pet is offline Find More Posts by michel pet
Old Sep 01, 2011, 10:36 AM
Jakub J is offline
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
We need fast, high resolution, jitter free, and smooth servos
Most servos are fast, low resolution, full of jitter, and not smooth.
q
Site Sponsor
Old Jan 10, 2012, 05:20 PM
peoples is offline
Find More Posts by peoples
United States, CT, Norwalk
Joined Nov 2009
q
all futaba s-series will work perfect... only the price is not so great.
peoples is offline Find More Posts by peoples
Site Sponsor
Old Mar 17, 2016, 11:08 PM
Ron_RC is offline
Find More Posts by Ron_RC
Ron_RC
Joined Nov 2011
Hi, I have worked on using servos for gimbals since the KK2 board had the capability to control them. First I'll show you what I did with HobbyKing's HXT900 servos. These servos were rebuilt from some stripped ones I had. I put them on the home made gimbal and used linkages to control the tilt and roll. Keep in mind the platform this gimbal was extremely stable in the first place. It was a Y-6 with 9x4.7 props and 1200kv motors with 24" booms. This made for an extremely stable platform for shooting video already. Add this cheap servo gimbal and this is what I got.
KK2, Scratch Built Gimbal, and Cheap Servos (3 min 3 sec)
Next up, is an Action Cam Inline Gimbal on my Rudi Quad, a sub 350mm quad with 8x4 props and 1534kv motors controlled again by the KK2 board. the shorter the distance between rotors, the more tricky it gets to make the platform stable. Any oscillation is noticed by the camera and cheap servos doesn't work very well at all. So I did a comparison and here are the results:
Servo Comparison for the ActionCam Inline Gimbal (4 min 0 sec)
This last video is after I got the board dialed in as best as possible so the quad would fly as smooth as I could get it. Then these servos did much better.
KK2 Camera Gimbal, Po Man's Aerial Steady Cam (1 min 26 sec)
My next scratch build gimbal will be a micro built with submicro servos to stabilize my HD keychain camera wired into a micro FPV transmitter. This one will be controlled by the KKmini and I plan to use it on at least two different platforms. One will be a singlecopter and the other a VTOL Plane. Hope you like this and I look forward to see what others post.
Ron_RC is offline Find More Posts by Ron_RC
Discussion Wiring a GoPro for a VTX what is the best way G-unit FPV Talk 30 Apr 15, 2012 06:33 PM
Discussion Best Aerial Video Option for GoPRO or similar (can't figure out what to get!) videoguy916 Aerial Photography 2 Apr 30, 2011 05:35 AM
Discussion Best SMALL servo for mouldie elevator? Crash Prone Slope 5 Apr 07, 2011 09:11 AM
Question Best Hobbyking Servo for Glider ailerons & Rudder..HXT900??? suri0712 Radios 0 Mar 04, 2011 07:20 PM
Discussion Best servos for Pan & Tilt ..smooth, fast, light, etc CATPart FPV Talk 12 May 17, 2008 04:34 PM
