Got a bit of it put together over the weekend, but I have a problem with my hand. About a month ago I had a Phoenix palm branch come down and a spike go deep into my wrist. They took it out at the time, but it appears that they left some of the spike in there, so I'm getting operated on again this Wednesday. Hopefully after that I'll be 100% again.
The long range weather forecast isn't looking too good and winter is fast approaching, but I can pick and choose my flying days, so we'll see. You guys who've been helping, you'd better get your accommodation bookings in in-case it fills up!!! Thanks Mark
Yes, the cross shaped G-10 part was in the older kits. It was originally for HS-55 servos WAY back years ago when they were about the only suitable servos out there. The reason for the cross shaped piece was because HS-55 horns were only single or double armed and you need 4 points for the O-rings to attach to. When the HS-56 and HS-65 servo came out, they had a nice sturdy cross shaped nylon horn so this eliminated the need for the G-10 part. That is still the case, but now some of the generic servos have that diamond shaped horn and that works but definitely needs a nylon tie strap to hold the O-rings on the small side arms.
Sorry about the dated manual. I did have an updated SH-4 manual but it was in my computer that crashed so I have to update it all over again. Sorry to hear about your hand. Good luck with your maiden. |
Hi Guys,
Thanks you all for the help and sympathy, at least someone cares.... I understood from the instructions that the horn needed to be fixed to the servo before the tail was attached with o rings, I just attached it like that as a dry run to photograph..honest. Sean, if you just updated the SH3 instuctions with a new title if would give us newbies something to work with. Also Sean, India to here is just under 8000 miles. You're welcome to come. Also Sean, don't you think that if you are going to get the ornithopters built cheaply offshore you'd be better looking at China ![]() Thanks again, I'll keep you updated. |
Hi,
Is there a way of checking the COG is approx correct? I'm sort of thinking about resting the underneath of the bird on a pivot point on a table to see where it balances. Understand? I'm not quite at that point yet, but it might be useful to prevent a nose plant on the maiden. Thanks |
| Thread Tools | |
| Build Log My new frame from(My RC build.com)! Pics added!!! | tc3wins | Multirotor Talk | 30 | Apr 25, 2011 01:38 PM |
| Build Log My Sylvan Aircraft Goliath 16" 4s Build | typhoonmaster | Flying Wings | 14 | Mar 29, 2011 01:13 AM |
| Build Log The "foamyak" My 1st Build finally documented. With Pics and vids and some night fpv! | handyfella | Foamies (Scratchbuilt) | 2 | Mar 15, 2011 02:44 PM |
| Discussion My First Scratch build How did I do? | hotdog1 | Foamies (Scratchbuilt) | 11 | Mar 10, 2011 04:46 PM |
