Old May 06, 2011, 05:32 PM
fabmic is offline
Find More Posts by fabmic
Joined Jan 2009
Recording out of a HD cam
Hi...
I'm enjoying FPV and would like to record video...
I have a HD camera on the plane but what I get on the ground is far from HD of course... I could record that but...
So I'd love to record locally on the plane, but getting the video from the osd itself, i.e. the same signal which then goes to the video transmitter, including osd info.
Is it just a matter of connecting a wire or...?
Alternatively, I'd have to record on something like Flycamone, but of course I wouldnt get the OSD on it...
fabmic is offline Find More Posts by fabmic
Old May 07, 2011, 12:55 AM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
Not sure exactly what you're getting at here, why do you have an HD camera on the plane unless you planned on recording with it? What kind of camera are you using?
I use a Gopro and it records HD video while I watch its SD output on the ground. I assume this is what you want to do?
Glenstr is offline Find More Posts by Glenstr
Old May 07, 2011, 01:21 PM
fabmic is offline
Joined Jan 2009
It's a Sony Kx171 HQ.
Yes it's what I want to do, but while I can see the video feed on the ground, I really don't know how to simultaneously record it.
I'm not interested in recording what I get on the ground, as of course it won't be HD...
I have an Airwave video tx with EZOsd to superimpose flight data.
Old May 09, 2011, 10:18 AM
fabmic is offline
Joined Jan 2009
I understand I should use a video splitter + some recording device, so the video signal could be sent both to the transmitter AND to the recorder.
Of course I would need something very light and simple, to record video on a memory card...
Discussion On board HD recording m_beeson FPV Talk 13 Mar 19, 2011 02:19 AM
Discussion GoPro HD live video out recording Stunt Double FPV Talk 7 Mar 16, 2011 06:00 PM
Discussion GoPro FPV live out + recording ? quadslo Aerial Photography 4 Mar 14, 2011 03:44 PM
Discussion Point and Shoot camera that outputs video out while recording HD video Xnaron FPV Talk 4 Jan 17, 2010 12:14 PM
