Old May 06, 2011, 09:54 AM
davekeck's Avatar
Joined Dec 2004
Wicked 60mm EDF Fan Unit Shaft adapter
Hi Don,
I bought the Wicked 60mm EDF Fan Unit for my Alfa Mig-15.
The 3mm hole in the shaft adapter is a really tight fit past the other side of the grub screws. I ordered a 3mm drill bit and was getting ready to drill it out, but then I thought perhaps the motor shaft is designed to be press fit into the adapter past the grub screw holes, but if I did that, I would never get it off again.
So the question is should I drill out the hole so it will fit all the way down the motor shaft? I'm thinking it's either intentional for a press fit, or the drilling and tapping of the grub screw holes caused the tight fit.
Dave
davekeck is offline Find More Posts by davekeck
Last edited by davekeck; May 06, 2011 at 09:55 AM. Reason: Question not discussion
Old May 06, 2011, 04:58 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Sometimes they come tight from the factory. You can drill it. You might just be able to spin the drill bit with your fingers as sometimes it is just a burr from the cross holes for the setscrew.
Don
The Don is offline Find More Posts by The Don
Discussion Wicked 5400 with Wicked 60mm fan unit drumbum Don's RC 7 May 09, 2010 12:31 AM
Sold Don's Wicked 5400kv in a Balanced 60mm wicked fan OCLightning Aircraft - Electric - Jets (FS/W) 0 Apr 16, 2010 03:35 AM
Question Wicked 60mm EDF fan thrust tube DIA mvortex Don's RC 1 Dec 24, 2009 11:27 AM
Sold Wicked 4800 motor and Wicked 60mm Fan TreeFlyer Aircraft - Electric - Jets (FS/W) 2 Aug 12, 2009 11:38 PM
Mini-HowTo Installing the Wicked EDF motor into the Wicked EDF fan unit The Don Don's RC 3 Jun 30, 2009 08:09 PM
