Old Apr 07, 2012, 05:01 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Congratulations! Looking forward to some video!
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Apr 14, 2012, 01:22 PM
rjrobbin is offline
Find More Posts by rjrobbin
United States, OH, Powell
Joined Dec 2006
Video
I managed to get the video off the camera and uploaded to youtube:
Skybench Merlyn (4 min 3 sec)
Two flights. I really like the sun coming through the monokote on the wings.
rjrobbin is offline Find More Posts by rjrobbin
Old Apr 15, 2012, 08:56 AM
skye8070 is offline
Find More Posts by skye8070
Skye Malcolm, LSF Secretary
skye8070's Avatar
Upper Arlington, OH
Joined Mar 2009
Dick,
I always love to see your planes out at the field, I aspire to that level of finish get on your planes. Heck you even made that Vista look pretty!
Another absolutely gorgeous plane, sorry I couldn't make it to the field on a weekday, things are busy at work for sure.
-Skye
skye8070 is offline Find More Posts by skye8070
Old Apr 15, 2012, 04:50 PM
rjrobbin is offline
Joined Dec 2006
Originally Posted by skye8070 View Post
Dick,
-Skye
You'll get another opportunity to see it. One thing that I hadn't mentioned before, was the wing joiner rod took a bend....Jay said I had built dyhedryal into the rod. I need to replace it we a harder rod....3/8 inch drill rod was not strong enough.
Old Apr 15, 2012, 06:53 PM
jswain is online now
Find More Posts by jswain
Gasbags & Gussets
jswain's Avatar
Riverside, Ca
Joined Feb 2009
two ?
Now that you have walked the walk, do you think there is enough room to put two rods in or is it pretty much limited to a single bigger or stronger rod ?
thanks for looking and congradulations again, john s.
jswain is online now Find More Posts by jswain
Old Apr 15, 2012, 07:12 PM
rjrobbin is offline
Joined Dec 2006
I am trying to get a hardened rod from Dixie Pins. Bigger or multiple rods would require major wing surgery. Not likely to happen.
Old Apr 16, 2012, 10:56 AM
rev.iain is offline
Find More Posts by rev.iain
Mesa AZ, it's a dry heat!
USA, AZ, Mesa
wing rods
I built a Merlyn back in 1982, not electric of course. I never did manage to bend the wing rod, but then there were no 'gorrila' winches, so it was a case of 'easy does it'.
I believe I used a "Squires" wing rod in those days. I don't believe Dave Squires is still in bussiness. His rods were excellent.
Be careful with very hard rods, they may be brittle. I used to be able to calculate the requred modulus and all that stuff, but I am retired now and my brain is contracting!
Beautiful bird by the way, I might be tempted to build another for e-power.
Iain
rev.iain is offline Find More Posts by rev.iain
Old Apr 16, 2012, 12:53 PM
rjrobbin is offline
Joined Dec 2006
Iain
This is what I found:
1 6061K325 Hardened Precision Steel Shaft, 3/8" Diameter, 15" Length
from McMaster-Car. they said the rocwell was equiv to a 60....
Old Apr 16, 2012, 02:48 PM
rev.iain is offline
USA, AZ, Mesa
Wing rods
I would be tempted to buy one, and do a bend test to make sure it will bend rather than break. If it does not break then get another to use in the model.
Better to find out on the ground than at 500'!
Iain
Old Apr 16, 2012, 03:33 PM
Joined Dec 2005
Iain
Yes. Bending rather than breaking any day. The bend is a good way to absorb the excess energy there. It's also easier to straighten a bendy rod than a brittle one: I use a rubber mallet judiciously applied to the top of the bend...
Old Apr 16, 2012, 06:12 PM
rjrobbin is offline
Joined Dec 2006
Iain
Ordered 2
Old Apr 16, 2012, 06:13 PM
rjrobbin is offline
Joined Dec 2006
Interesting....
Old Apr 17, 2012, 05:37 AM
skye8070 is offline
skye8070's Avatar
Upper Arlington, OH
Joined Mar 2009
Ordered 2
Now the really scientific way would be to get the old rod and the extra new rod and do a bend test in an Instron machine. We could plot the Force vs stroke and see how much stiffer this new rod is compared to the old one.
But barring that a big vice and a pipe as a breaker bar might be strong enough to bend each of these. Then just use your calibrated oomph-meter to determine how much stronger the new one is compared to the old one.
Old Apr 17, 2012, 06:53 AM
rjrobbin is offline
Joined Dec 2006
ok...I am reluctant to start this discussion...I have never used a 'oomph-meter'. Is it calibrated in ergs?
for the uniformed... "An erg is the unit of energy and mechanical work in the centimetre-gram-second (CGS) system of units"
after all this is just an airplane made out of wood held together with glue.....
Old Apr 17, 2012, 12:40 PM
skye8070 is offline
skye8070's Avatar
Upper Arlington, OH
Joined Mar 2009
If we do the simple bend test with a breaker bar I would suggest the universal plumber/auto mechanic's unit of measure of torque: grunts. But you can always skip the component spec and go straight to the flight test to check for brittle failure mode.
Again, if an instron is available we would be able to measure a force in N or lb off a load cell.
Discussion Sky Bench Merlyn jwhitacre Thermal 102 Aug 18, 2011 09:22 PM
Wanted Mini Sagitta from Skybench-Plans or kit lenci1938e Aircraft - Sailplanes (FS/W) 2 Mar 24, 2011 04:49 PM
Off Site Skybench Legion Air Kit 140 inch wing span Left Hand Slicer Aircraft - Sailplanes (FS/W) 0 Aug 07, 2006 08:17 PM
Help! Sunbird kit of skybench vicente_martins Sailplane Talk 5 May 31, 2006 03:28 PM
Sold SkyBench LilBird 2 Fuse, Tail & Plans Kit Gregg28 Aircraft - Sailplanes (FS/W) 1 Feb 12, 2006 11:41 AM
