Old May 06, 2011, 02:40 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Is it possible to change the ratio of a KPG25 gearbox.
Im wondering if its possible to convert a 5.2 to a 4.2 by simply swapping out the pinion and planetary gears. Is the outer ring gear the same in both ratios?
jackosmeister is online now Find More Posts by jackosmeister
Old May 15, 2011, 08:48 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
You have to change the pinion,planets and gear carrier to change a ratio in a planetary drive.
Steve Neu
sneu is offline Find More Posts by sneu
Old May 15, 2011, 01:01 PM
Auckland NZ
Joined Aug 2007
Thanks Steve!
Sold KONTRONIK KPG25 Planetary Gearbox; KONTRONIK Adapters for KPG27 & KPG25 GB old_dude Aircraft - Electric - Power Systems (FS/W) 6 Jan 17, 2011 03:39 PM
Sold KONTRONIK KPG25 Planetary Gearbox; KONTRONIK Adapters for KPG27 & KPG25 GB old_dude Aircraft - Sailplanes (FS/W) 1 Jan 17, 2011 03:24 PM
Ok to change gearbox ratio in GWS bruched setup? rkhoo Power Systems 6 Aug 25, 2005 11:08 AM
"NEW" Kontronik 480-33 Brushless motor with KPG25 4,3 Gearbox & BEAT 40-6-18, --SOLD rck Aircraft - Electric - Airplanes (FS/W) 0 Jul 16, 2002 09:59 PM
"NEW" Kontronik 480-33 Brushless motor with KPG25 4,3 Gearbox & BEAT 40-6-18 (eBay) rck Aircraft - Electric - Airplanes (FS/W) 2 Jul 14, 2002 02:32 PM
