UK, Buckinghamshire, High Wycombe
Joined Feb 2007
1/ shopping for plug n play boards (so far bought a pipo imu and 2 kk black boards) 2/ having a go at knocking up my own flight controller slowly while i wait for these new boards to arrive ![]() once i have a good selection working on my latest quad in the videos (925kv) i will try them all on 600kv motors and see what is most stable at low kv once ive sorted that i will start building a new quad and tri with dt700 kv motors and be a happy chappy
Joined Feb 2007
this was the 1st board on my list and i was going to buy it and pipo imu then try others later but a mix up in my emails left me thinking it wasnt plug n play so i bought other boards instead bit gutted actually witespy ithink you thought i meant your flyduino? and not this board from my 1st email?
Joined Feb 2007
my dilemma right now is this, im all spent out for the next few weeks and not sure i can raise the money in time to still get in on the 1st batch definitely want one though
Denmark, Capital Region of Denmark, Copenhagen
Joined May 2010
![]() But yeah, I guess we are far away from both rtf/plug-n-play and the 100 usd. But the wobble/vibration would be history, because you have so many parameters to tune, that (almost) no matter what config you throw at it, you'll get it to fly as it should
NW England
Joined Jul 2005
Hey Nem.
Seems from this picture: ![]() You have the wm+ plugged in correctly (if white is +ve, black is GND, green is SDA and blue is SCL) ![]() Motors into Digital 3, 9, 10 and 11, and RX into 2,4,5,6,7 (see picture below). Remember to only plug in power from 1 of the ESC becs ... i think people pull the red wire out of the esc plug by pulling the little plastic clip forward, then they tape/shrink wrap it to the cable. GVS on the board marks the Ground, VCC (5v) and Signal pins. Although I'm not actually sure if you can put power from one of the ESCs directly into VCC? Is there a voltage regulator on the Arudino 2009? Not sure how it all works. Can someone with more knowledge then me chip in? Ben. |
Can yours fly others than tri or quads? Have a flight video? What's the price?
Joined Feb 2007
understood instantly and yes you are correct about the colour scheme and chance you could label the four wires as well for future reference please? saying where they should connect to the wm+? t,ia
NW England
Joined Jul 2005
Hi Nem.
No Probs ![]() The motors connect the same for both X and +. Just the arrangement differs like this : + : ![]() x : ![]() You can see all the configurations here : http://www.multiwii.com/?page_id=103 From looking at other peoples Ardunio 2009 setups I think you have to put the power from your ESC bec into the 5v and GND pins right next to where I've marked "WM+ GND" on the sensor shield picture above ![]() Ben. |
Joined Feb 2007
TY
This is all you have to wire up yourself.
![]() The Flyduino is modular and will allow future sensor upgrades and of course the CPU is more capable regarding the ins and outs. The Flyduino is a pretty well tested unit. A very simple and nice and very cheap build (WMP only) with the very stiff Flyduspider frame.
| Thread Tools | |
| Discussion PARIS Aerial Photography Plug-n-Play boards for MultiWiiCopters | AlouetteIII | Multirotor Electronics | 3522 | Today 06:59 AM |
| Discussion warthox FPV Plug-n-Play boards for MultiWiiCopters | AlouetteIII | Multirotor Talk | 22 | Jan 31, 2012 02:45 AM |
| Sold warthox FPV - MultiWiiCopter board - v2.0 Plug-n-play | Huskiemuskie | Aircraft - Electric - Multirotor (FS/W) | 1 | May 05, 2011 07:08 AM |
| Discussion Air Hogs Plug n'Play Flight Deck Simulator | trust416 | Micro RTF | 14 | Aug 05, 2007 10:44 AM |
| Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review | tailskid2 | Scale Fuel Planes | 6 | Dec 02, 2006 12:34 AM |
