Old May 07, 2011, 03:50 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
1) To interface with the Arduino MultiWii setup you will need the Arduino 0022 software and this:
http://www.sparkfun.com/products/9716
You can find the GUI and multiwii software here:
http://code.google.com/p/multiwii/so...se/#svn%2Ftags
You don't control the gain on the MultiWii controller like the Gaui GU344. You play with the GUI software and the PID settings.
For a good explanation of the PID control:
http://en.wikipedia.org/wiki/PID_con...iew_of_methods
2) To interface with the KK controller you need to check out Minsoo Kim's website:
He has all the firmware there including his lastest V1.6.
http://www.kkmulticopter.kr/
To upload the firmware into the KK controller you will need this gadget:
http://www.kkmulticopter.kr/index.ht...m_isp&id_no=79
You get the AVR Studio 4 here:
This program is the software interface for the KK controller.
http://www.atmel.com/dyn/products/to...p?tool_id=2725
You also do not control the gain of the KK controller from the transmitter. You adjust three potentiometers on the board for the gain on the roll, nick and yaw axis.
SeismicCWave is offline Find More Posts by SeismicCWave
Old May 07, 2011, 05:17 PM
ben123 is offline
Find More Posts by ben123
NW England
Joined Jul 2005
Don't think he needs the FTDI breakout with the Arduino 2009. It has one built in.
Ben.
ben123 is offline Find More Posts by ben123
Old May 07, 2011, 05:55 PM
AMA 46133
Hawaii
Joined Feb 2003
Ben.
Thank you. I have no clue which Arduino he has. I use it on my Arduino Pro and Pro mini.
Old May 07, 2011, 06:06 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Originally Posted by n3m1s1s View Post
oh well in that case whats my next arduino step please??
side note again so far i have ordered 1x pipo controller 2x kk black boards and 2 arduino v4 sheilds
i did email witespy about his board but think he thought i meant his flyduino? as he emailed back saying it wasnt plug n play gutted but still looking for more options so keep em coming while i fiddle with the arduino stuff ( i need to learn how to at least flash new firmwares onto the board and to me it looks like the kk and arduino boards are perfect teachers)
You say you want plug 'n play but have two kk boards coming. If you want to take the next step then put Mike Barton's xx14 code on one of them. You will not be disappointed once you get the PID settings tuned. Sadly the $25 serial lcd that lets you see the settings is currently out of stock everywhere but that should change.
pug398 is offline Find More Posts by pug398
Old May 07, 2011, 07:14 PM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
i got the arduino 2009 bruv usb is onboard
TY
yes i think i might be coming very unstuck when i get to here you lot please stick around yea?
ok will do
naa i got 2 of these instead http://www.protostack.com/accessorie...avr-programmer with postage it worked out cheaper to buy 2 of those than one of minsoo kims cut the 10wire lead in half and use one half to make kk 10pin to 6pin adaptor and the other half to make a cable for pipo the second one is backup for if anything goes wrong
naa i used this instead much more noob friendly
http://lazyzero.de/en/modellbau/kkmulticopterflashtool
erm im a little bit past that stage bruv i mixed a minsoo kim board with a helicommand 3d for auto leveling and position hold many weeks ago i also did the same with a flymentor but the results were not so good
heres what my minsoo kim setup flies like
N-DROID ELG Repaired 1st actual flight tests flies very nice N3M1S1S (5 min 45 sec)
i consider that to be flying CRAP and endeavor to build something that flies much better!
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old May 07, 2011, 07:43 PM
n3m1s1s is offline
Joined Feb 2007
ok will do or at least try lol sounds like a nice easy step into p i d tuning and if i fail i just flash back to minsoo like that idea
Old May 08, 2011, 02:29 AM
AMA 46133
Hawaii
Joined Feb 2003
http://vimeo.com/23325369
Sorry, that was a generic response to your generic question of "what next to do with an arduino".
So I linked you everything that you need for the MultiWii board using Arduino Processor. I also linked you the KK minsoo kim site because you mentioned KK boards.
I can't tell what stage who is in by just reading posts on the internet.
I shouldn't have wasted my time.
Old May 08, 2011, 06:50 AM
n3m1s1s is offline
Joined Feb 2007
no bruv you didnt waste your time at all and what you posted was actually perfect for anyone reading this thread in the future
my reply was just to update you on where i am personally so you can reply with more info
the kk controller im fine with till i run the xx software then i will be lost for a while
the arduino is totally new to me so will need as much help as possible
the pipo i have absolutely no clue about right now but hope i will by time arduino is up and running
and it looks like i could be in line for one of witespys new boards now he knows which board im on about lol
so please dont get offended btw the quad in the vid dont look poo but thats coz theres less than 5mph wind
at 10mph wind it looks like this
N-DROID PHEONIX ELG wind tests 10+mph nonHD camera Positioning test N3M1S1S (7 min 13 sec)
this needs to be sorted out
Old May 08, 2011, 07:57 AM
ben123 is offline
NW England
Joined Jul 2005
Where are you up to with your Arduino Nem? You should be able to get it in the air today with what you have
Ben.
Old May 08, 2011, 06:23 PM
Av8Chuck is offline
Find More Posts by Av8Chuck
Av8Chuck's Avatar
USA, CA, Thousand Oaks
Joined Feb 2010
This thread started out as "Plug-N-Play" then there was mention of two KK boards, plug this into that, upgrade the firmware to this, build this cable to plug in that, what part of this is "Plug-N-Play?"
So I guess the only Plug-N-Play controller is the GU344?
I would think someone would make a killing if they could build a true Plug-N-Play solution that was stable with altitude/position and hold or auto level.
Av8Chuck is offline Find More Posts by Av8Chuck
Old May 08, 2011, 07:30 PM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
The Quadrino is close to plug and play like the gu344.
Just a couple if settings on the radio and your in the air.
10 min max. I should post a video. Plus All the screen and motor layout is printed on the board. So the board is the manual. Yay!
witespy is offline Find More Posts by witespy
Old May 08, 2011, 07:39 PM
Flyingfool is offline
Find More Posts by Flyingfool
Flyingfool's Avatar
Belle Chasse Southern, Louisiana, United States
Joined Apr 2002
Witespy,
Have any video of one of the Quadrinos in action?
Any plans of coming out with a board with the same features but will handle a Y6 without a ppm encoder?
Randy
Flyingfool is offline Find More Posts by Flyingfool
Old May 08, 2011, 10:23 PM
witespy is offline
Joined Sep 2009
this is what I was talking about, pictured without pins, they all come with pins installed..
Old May 09, 2011, 02:57 AM
LokeyFPV is offline
Find More Posts by LokeyFPV
FPV = Fun Powered Vehicle
LokeyFPV's Avatar
United States, CO, Denver
Joined Apr 2011
SeismicCWave-I shouldn't have wasted my time.
You definitely didn't waste your time. The MultiWii software and PID links were exactly what I was looking for. Even if nem didn't need them. I sure did.
Thanks a lot for taking the time to list all those. You def helped me out. Thanks Seismic!!
Cheers
LokeyFPV is offline Find More Posts by LokeyFPV
Old May 09, 2011, 03:16 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Cheers
Yes indeed, I learned a lot too... thanks!!
marhar is offline Find More Posts by marhar
Discussion PARIS Aerial Photography Plug-n-Play boards for MultiWiiCopters AlouetteIII Multirotor Electronics 4653 Sep 20, 2016 06:23 PM
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Discussion warthox FPV Plug-n-Play boards for MultiWiiCopters AlouetteIII Multirotor Talk 22 Jan 31, 2012 02:45 AM
Sold warthox FPV - MultiWiiCopter board - v2.0 Plug-n-play Huskiemuskie Aircraft - Electric - Multirotor (FS/W) 1 May 05, 2011 07:08 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
