Old May 05, 2011, 04:56 PM
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
need new flight controller recommendations
title says it all but i have changed it to include the not so plug and play boards out there do you have any suggestions please?
forget the buying bit and price now as i have a selection of boards right here but info on more would be great for future choices so far i have
kk black board v5.5 with flymentor
minsoo kin blue board with helicommand 3d
fy90q (in the post)
homebrew shi lankan shield with 2009 chip clone wm+ and clone nunchuk
arduino 2009 with v4.1 shield official wm+ and nunchuk
jussi 1.0 shield with pro mini official wm+ an bma020
v2 alex/warthox board with ffimu gyro acc and baro
custom muitiwii With built in PPM encoder bluetooth ITG3200 gyro acc baro mag and USB on board
flyduino mega black with sensor bob and ffimu
uavx erm looks complete with gyros mag baro and gps? plus spaghetti lol
arduino mega 2560 and proto shield?
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old May 05, 2011, 07:23 PM
Joined Oct 2005
Not sure how plug n play you are after. will some soldering of cable consider plug and play?
I still see the KK board is a relatively simple board to start the quad. and with the new software that I tested lately, it is very stable and not even wobble.
It only has 3 pot to play with so as long as you done the initial few step, it is almost no more work needed.
dt8666 is offline Find More Posts by dt8666
Old May 05, 2011, 10:22 PM
Hawaii
Joined Feb 2003
I will try a MultiWii. A bit involved but the potential is there.
SeismicCWave is offline Find More Posts by SeismicCWave
Old May 06, 2011, 04:26 AM
NW England
Joined Jul 2005
Ello Nem
How about Witespy's Quadrino?
http://www.rcgroups.com/forums/showt...6#post18157136
Quadrino Basic
- Includes ITG3200 Gyro and BMA180 Accelerometer
- Accelerometer provides auto level features
- Ready-to-fly
- 95$ USD
Quadrino ADV
- Quadrino Basic plus BMP085 Barometer and HMC5883 Magnetometer
- Baro and Mag provides altitude and heading hold features
- 145$ USD
Shipping is via USPS Flat Rate Small Box. Shipping rates are per shipment, not per unit, so pay shipping only once.
- 5.20$ USD within mainland United States
- 11.95$ USD to Canada
- 13.95$ USD to anywhere else
Looks good to me but I've never tried it
Ben
ben123 is offline Find More Posts by ben123
Old May 06, 2011, 04:58 AM
NW England
Joined Jul 2005
Or maybe Goofy's Flyduino?
http://www.rcgroups.com/forums/showthread.php?t=1381577
It's kind of more future proof in that it'll take a serial GPS if multiwii software ever takes one. It's about 40 euros according to here :
http://www.rcgroups.com/forums/showp...&postcount=375
He also does a power distro board and sensor bobs for around 6 euros each:
http://www.rcgroups.com/forums/showp...&postcount=346
So you can either use a wm+ and bma020 (Kinderkram is selling them again in the swarm thread for 8 euros ) or maybe the ALLINONE sensor board for around £65 :
http://cgi.ebay.co.uk/HMC5883L-BMA18...b#ht_899wt_905
http://www.rcgroups.com/forums/showthread.php?t=1413106
Goofy has an order enquiry page here :
http://flyduino.jossyrc.com/
So for this option it's ~£41 (46euros) for the Flyduino + sensor BOB, and around £15 for a wm+ and ~£7 (8 euro) for a BMA020, or £65 for the ALLINONE.
Ben.
Old May 06, 2011, 05:03 AM
I'm new here
timecop's Avatar
Joined Dec 2010
I don't think flyfuino counts as plug n play.
Witespy board ftw
timecop is offline Find More Posts by timecop
Old May 06, 2011, 05:12 AM
NW England
Joined Jul 2005
True
Ben.
Old May 06, 2011, 07:19 AM
Joined Feb 2007
cheers guys liking all options so far ive never programmed a FC but i am getting an annoying tiny wobble with my minsoo kim and helicommand combo i know its just a matter of changing the gyro settings ( updating to the newest software needs doing too as i think that will sort it as well) but i feel its time to broaden my knowledge database with some of the new toys out there
on a side note i have an arduino 2009 here, a wii+ and a cheap nun-chuck on order from dealextreme if i crack open the wii+ and take a few pix can someone please tell me the simplest way to link them together?
Old May 06, 2011, 08:45 AM
NW England
Joined Jul 2005
Hi Nem.
The easiest way to find out how to connect your wm+ is to check which colour wire goes to which connector on the plug :
I'm not too familiar with Arduinos... is your arduino this one?
http://www.arduino.cc/en/Main/ArduinoBoardDuemilanove
If so I think it has to have the ATmega328 version rather than the 168 to use MultiWii as it is.
If its the right one the yellow "Clock" on the wm+ picture above is SCL and connects to analog pin A5 on your board, and green "data" is SDA and connects to A4
Rather than getting a random clone nunchuck you could use KinderKrams ELV BMA020 breakout in the swarm thread. It's only 8 euros and it'll definitely work (and has built in level convertor so you can run it ok on 5v) rather than the pot luck of clone nks.
Good luck and I'll be happy to try to help if you have any problems
Ben.
EDIT: Kinderkram seems to have sold out of the BMA020 already
Old May 06, 2011, 09:55 AM
Joined Feb 2007
sweet ok heres what i have so far
also sent Witespy a PM
Old May 06, 2011, 10:22 AM
NW England
Joined Jul 2005
Looking at that using the connector in this pic :
http://imageshack.us/photo/my-images/560/dscf3141q.jpg/
I think blue is GND, red is scl, black is +ve and green is sda. Do you agree using my previous pic?
Attached is a picture from the multiwii thread I've modified for you. I believe those are the connections you're looking for? Remember to connect the 5v and ground up to the rx as well and connect the esc bec grounds up as well I believe.
Ben.
Old May 06, 2011, 10:28 AM
Joined Feb 2007
Ben.
TYVM Ben i will look over the pic you uploaded and shout again if/when i get stuck btw i was thinking just what you said in your last reply about wire but wanted to be sure
erm theres a nunchuck around ere somewhere an original one should i kind of borrow it till the new ones come? and how would i link to it please? beginner here
Old May 06, 2011, 10:45 AM
NW England
Joined Jul 2005
No problems
"kind of borrow" heheh
You're Wii motion plus is the same one as here :
So using the connections on the left you know what to connect to your nunchuk (the two connections marked as "3v3 Vcc" separated by the SCL should be connected together, it lets the WM+ know a nunchuck is connected).
Now the order of the connections might differ on your nunchuck. Looking at this diagram from www.multiwii.com, if Alex is using an original nunchuck too, should help
Good luck!
Ben.
Old May 06, 2011, 12:50 PM
LoS sUAS AP/V is not a crime.
W,,,,,,,,,,,,,,,,,,,,'s Avatar
Grass Valley, CA
Joined Feb 2008
By far the easiest way to hook up Wii is to buy a Paris or Warthox board.
If your able to solder for about $80.00 you can have this:
And do yourself a favor and get an original set of wii, I have 3 NK, 2 clones and only the one original works right.
W,,,,,,,,,,,,,,,,,,,, is offline Find More Posts by W,,,,,,,,,,,,,,,,,,,,
Old May 06, 2011, 05:45 PM
Joined Feb 2007
erm plug n play bruv? the rtf version is permanently out of stock
Discussion PARIS Aerial Photography Plug-n-Play boards for MultiWiiCopters AlouetteIII Multirotor Electronics 3445 May 09, 2013 06:57 PM
Discussion warthox FPV Plug-n-Play boards for MultiWiiCopters AlouetteIII Multirotor Talk 22 Jan 31, 2012 02:45 AM
Sold warthox FPV - MultiWiiCopter board - v2.0 Plug-n-play Huskiemuskie Aircraft - Electric - Multirotor (FS/W) 1 May 05, 2011 07:08 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro RTF 14 Aug 05, 2007 10:44 AM
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 6 Dec 02, 2006 12:34 AM
