Old May 05, 2011, 04:51 AM
loony979 is offline
Find More Posts by loony979
Australia, NSW, Doonside
Joined Apr 2011
32.3" EP Fibreglass RC Godspeed-U Catamaran Hull Boat
Hey every 1 just wanted to know what is the flex cable size i will need for this boat. also this is what i am hooking it up to.
1. 38mm x 1.4 metal prop 4mm REVERSE
2. ORION Votrex Pro Stock 10.5 T motor
more or less what i need is all the goodies that go from the motor to the prop.
my old oat is a solid shaft easy to use now i got this HULL on order , i want to be ahead of the these little things that mite slow me down .
thanks there should be pics aswell.
loony979 is offline Find More Posts by loony979
Old May 05, 2011, 05:12 AM
loony979 is offline
Joined Apr 2011
also just noticed i need a motor mount
Motor size is :
length 51.1 mm
diameter 35.8 mm
shaft length 15.2 mm
shaft diameter 3.14 mm
thaks again. & P.S. im hoping i can reach 100km/h with this boat.hahaha ill try.
Old May 05, 2011, 05:56 AM
Rusty Old Fart is offline
Find More Posts by Rusty Old Fart
Zombie Apocalypse
Rusty Old Fart's Avatar
Newcastle, Australia
Joined Nov 2010
Welcome loony....
That motor kv is way to high buddy. That boat will run perfect on 4S and motor around the 2000kv.
The 4S setup you can run a 4mm flex drive system. Although 3/16 is much much better. You won't get close to 100km/hr with that motor you have selected.
Swordfish 200A ESC from OSE.
Where are you by the way? recommendations on where to buy can help you.
Whats your price limits you want to spend and whats your expectations, racing, general use ??
Rusty Old Fart is offline Find More Posts by Rusty Old Fart
Old May 05, 2011, 06:16 AM
loony979 is offline
Joined Apr 2011
Heya old fart. im in Sydney be using it for fun on the Woodcroft lake out in blacktown way .always smooth there.& ohhh i realy liked that motor ,guess ill have to keep using it .
hahaha for now ill upgrade it to the leopard l8tr.
I buy & Rc boat bits ponti is good.Im @ Doonside blacktown way.ive already got the 120a Swordfish ESC 7 the usb link. im using that with the motor & seems to be fine.
i also have the FLYSKY 2.4gh.z transmitter /receiver. works like wonders.
But hey this will be my 1st build so i kinda wanna do it right .but not spend to much $$$
1 upgrade @ a time .Now im an intersested on getting the Flex cable shaft set up
DONE RIGHT. you mentioned 3/16 is realy good .
Id like if you could link me to rcboatbits the stuff i need for it to be a kit sorta hhaha.
i know thats a lot to ask but i know for a fact you on this forum all the time hahaha.
Thanks rusty ...
Old May 05, 2011, 06:33 AM
Flying Barry is offline
Find More Posts by Flying Barry
Australia, NSW, Sydney
Joined Jan 2007
I have one find a better boat as there is not much room inside my one sits on the shelve now collecting dust and that motor is way to high KV for a boat you need around 2000kv on 4S lets say.
Barry
Flying Barry is offline Find More Posts by Flying Barry
Old May 05, 2011, 06:34 AM
Zombie Apocalypse
Joined Nov 2010
aaahhhhh my old stomping ground many years ago.
I don't know how your going to use that motor. 2S will be your only option and you are only going to crack 30,400 rpm unloaded. So that's around 26,000 loaded.
LBP3674 1900kv will pull around 80A
3674 1900kv
4074 2000kv 4074 2000kv is the pic in leopard but it will pull 120A so that will kill ya esc
I would look for a a rudder strut set with the 3/16 flex included. RCBoat bits doesn't have anything quite like it. They sell all the bits individual.
Old May 05, 2011, 06:35 AM
Zombie Apocalypse
Joined Nov 2010
Yer baz my Misstaken is tight fit. similar hull
Old May 05, 2011, 07:00 AM
loony979 is offline
Joined Apr 2011
ok the esc im using now the 120a swordfish, should be ok for 100km/h mark im looking for right only with the right set up of course. or did i bye the wrong 1 ?
And still that flex cable set up .is a must to start of for now ,even if i have to set the throttle low on my flysky no problem that will only make me get that leopard sooner.
Damn i payed $100 for that orion motor the other week.
but i do understand what your getting @ .
the baterires i just got are the (2200mAh 3s 11.1v Lipo Battery XT60 Deans T Plug EC3)
@ the moment i have been using the good old 7.2v nicad's.
Old May 05, 2011, 07:06 AM
loony979 is offline
Joined Apr 2011
& not to mention this is an upgrade from this boat !!!
Old May 05, 2011, 07:15 AM
Zombie Apocalypse
Joined Nov 2010
You will be struggling with that esc for 100km/hr. Any motor big enough and powerful enough will be pushing too close for comfort to the 120A mark. There is a massive difference between 70 to 80km/hr and a build that will hit the 100km/hr mark.
There are perfect you cut them down to size. But its everything you need
Rudder strut flex combo
Ditch the deans straight away and fit some 5.5mm bullets. And so if you have bought some 3S batteries then you need a different motor all together. Something around the 2700kv will punch nicely. But your won't hit the 100km/hr.
PS try a refund or swap from who ever you bought the motor from. Say to em I purchased in error
Old May 05, 2011, 07:31 AM
loony979 is offline
Joined Apr 2011
i actauly had the option for conections for the 2 batteries i whent for tamiya .
But what can i say . i come from the 1:10 scale car scene. but im sure that again is a fast fix np @ all
Old May 05, 2011, 07:33 AM
loony979 is offline
Joined Apr 2011
so the flex cable i can cut down to size is that what you meant b4 ?
Old May 05, 2011, 07:40 AM
wparsons is online now
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Hold on a second... 3s2200mah packs will not suffice for a boat this size unless you plan to run four of them in a 6s2p setup. You need to have at least 4000mah, preferably 5000mah plus.
Those 2200mah packs are probably only good for about 50-60a (assuming 30C) alone, and won't last long at all under that kind of load.
To have a reliable and safe setup, you want 4s5000mah (30c) total and around 2000kv motor. That'll give you a motor that will give power under 120a, and batteries that will happily supply 120a constant so no parts are worked too hard.
wparsons is online now Find More Posts by wparsons
Old May 05, 2011, 07:56 AM
loony979 is offline
Joined Apr 2011
Are, these lipo's kill my brain cells Jedi Masters. not to mention when i got the esc it didnt tell me what voltage i could run .P.S. with that NQD PX16 i used that esc with that motor & 2x7.2v batteries positive to the negetive ,if ya get my drift there .
Old May 05, 2011, 08:12 AM
Zombie Apocalypse
Joined Nov 2010
my son runs 2 x 2200mah in parallel in his Prince he gets about 4 to 5 minutes. In this hull you will get about 2 to 3 min if ya lucky.
3S 5000mah 40C is best. in parallel gives you 10000mah and about 6 to 7 minutes maybe a little longer, depends how you run it
thats a series run
Discussion Godspeed-u- Cat....Any good? themightysmiff Racing Boats - Electric 8 Mar 16, 2011 11:47 AM
Sold 32 in Catamaran Hull Only with motor mount!!!! tc3wins Boats (FS/W) 7 Oct 14, 2010 04:14 PM
For Sale R/C Fibreglass Custom Boat Hull Painted Fast Strong!!!! Air-Wolf Boats (FS/W) 0 Feb 18, 2010 09:07 AM
Sold 32" fibreglass catamaran hull bustitup Boats (FS/W) 0 Sep 24, 2009 09:14 AM
Sold 1/20 Fibreglass PT Boat hull and plans CMurphy Boats (FS/W) 0 Jul 24, 2007 12:33 AM
