This thread is privately moderated by boingk, who may elect to delete unwanted replies.
Old Oct 19, 2011, 03:37 PM
Snoggle is offline
Find More Posts by Snoggle
Snoggle's Avatar
Deutschland, NDS, Oldenburg (Oldenburg)
Joined Aug 2011
HobbyKing Decathlon Brushless Plug-n-Fly --> 4
Eflite Mini-Pulse XT --> 7
Snoggle is offline Find More Posts by Snoggle
Old Oct 19, 2011, 09:09 PM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Thanks Snoggle, they seem like appropriate ratings and I've inserted them into the list.
In other news, I've gotten a small hand-launch glider - the HobbyKing Canary, otherwise known as the Kyosho Swing. 1100mm span, 290g AUW, preassembled balsa wings and glassed fuse with carbon boom tail.
Once assembled and set up correctly this is a peach of a plane to fly. I would go as far as to say it would make a very good flight trainer for new fliers, with the emphasis on smooth control inputs and following a glidepath. It is also very durable, even surviving a low nose-in (elevator jam {stiff surface + linkage slop} caused stall) without any significant damage.
Keeping this in mind I would give the HobbyKing Canary a solid 4, mainly because you are at the mercy of the wind and can't power yourself out of trouble.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Oct 20, 2011, 12:07 AM
Snoggle is offline
Snoggle's Avatar
Joined Aug 2011
you made a little mistake, the eflite mini pulse is already in the list with a value of 6.25, you should merge my value into the existing value.
and i got another one:
Hype (Kyosho) ASW-17 --> 3
Old Oct 21, 2011, 01:21 PM
binaryclock is offline
Find More Posts by binaryclock
I hate winter!
binaryclock's Avatar
Canada, ON, Barrie
Joined Jul 2011
Original E-Flite UMX Beast --> 9
Good third plane, with sim experience or instruction. Most people get this as their third plane and wreck it so I can't say it's a 8.
Maybe the new 3D Beast will be a 8... we'll see in December.
You can probably put the E-Flite UMX Sbach in at --> 9 as well unless someone thinks it may be 9.5 because it is much quicker than the beast as it doesn't have the drag on the airframe and it has a higher kv motor.
binaryclock is offline Find More Posts by binaryclock
Old Dec 30, 2011, 06:03 PM
CF105 is offline
Find More Posts by CF105
Arrowhead
Joined Dec 2010
Bump! This thread is far too valuable to get buried so deep.
Mods - please, please PLEASE! Sticky this thread, and perhaps un-sticky the old, obsolete one.
CF105 is offline Find More Posts by CF105
Old Dec 30, 2011, 07:49 PM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Electrifly Rifle - 10. Maybe a 9 but very tricky to launch and landings requires lots of space for bleeding speed off. Very fast and very small.
I'd be curious what ratings might be for the Electrifly Evador or the F-16.
cjbucher is offline Find More Posts by cjbucher
Old Dec 30, 2011, 08:21 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Originally Posted by gulio View Post
I have very little experience , but the Great Planes Flylite has to be a 2. Nice thread btw.
A bit more experience now.
All Hobbico made (GP , Flyzone, Hobbico, ect)
GP flylite 3
Flyzone Sensei 4
CG Falcon 5
Skyfly Max 5
Flyzone Switch (high wing) 5
Flyzone Piper Cub 4
Flyzone Albatross 3
gulio is offline Find More Posts by gulio
Old Dec 31, 2011, 06:36 AM
Snoggle is offline
Snoggle's Avatar
Joined Aug 2011
Hobbyking Rarebear Funfighter 8 on 3s 9 on 4s Setup...
Old Jan 01, 2012, 01:19 AM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
Dynam Grand Cruiser (Cessna 310) 6 or 7. it is touchy and fast. i put a rate gyro on aileron to help in wind.
http://www.youtube.com/watch?feature...&v=yuf0lSSogSc
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Feb 02, 2012, 06:55 PM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Updated with most new ratings, thanks guys! Have been busy of late with commercial pilot school and working nights so have not had much time to fly models... only the real stuff!
Cheers - boingk
Old Feb 02, 2012, 07:30 PM
roo_ster is offline
Find More Posts by roo_ster
Standing Athwart History
roo_ster's Avatar
United States, TX, Dallas
Joined Mar 2011
Techone EPP Funflyer, 3ch: 2.5
When balanced, flies much like a larger scale Champ.
Tuffwing: 9.5-10
Fast, twitchy 24" WS flying wing. It needs to go fast or it will fall out of the sky. Combine that with its size and it is a real handful.
roo_ster is offline Find More Posts by roo_ster
Old Feb 03, 2012, 10:55 AM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
Well i haven't seen any plantraco planes on here so i will put in my two cents (literally, it might not be worth that much seeing as i am a beginner)
I have a shoestring racer, 3ch. And this is my first "real" plane apart from an air hogs xtwin or whatever they are called. I am able to fly it with no problems now. I have put about 7 flights on it. I had a small amount of flight sim practice, but not much at all.
So, Plantraco Shoestring Racer: 3.
nightfox7 is offline Find More Posts by nightfox7
Old Feb 03, 2012, 05:14 PM
CF105 is offline
Arrowhead
Joined Dec 2010
Yeah, I'd put the Hobbico Albatros at a 3. It's no more difficult than my UM J-3 Cub.
Steven's Aero DH.53 Hummingbird... I'd say 4. It's pretty mellow, but definitely faster than most of the 3's.
Old Feb 03, 2012, 05:21 PM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Hobbyking Coota (amphibious) - 8
Its stall speed is like 80% of WOT (), and it has a tendency to tipstall quite viciously. It's also made of plain ol' EPS foam, and not EPO, so hard landings are more likely to result in damage.
H2SO4 is online now Find More Posts by H2SO4
Old Feb 04, 2012, 02:54 AM
Elios000 is offline
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
why is the Long EZ still at 10 its easly a 4 or 5 at best
they are not fast dont tip stall and forward stalls recover be for you even notice them
Elios000 is offline Find More Posts by Elios000
Discussion Difficulty to Build Rating System jpwkeeper Beginner Training Area (Aircraft-Electric) 7 Oct 19, 2014 01:10 AM
Discussion Difficulty to Fly Rating System jpwkeeper Beginner Training Area (Aircraft-Electric) 629 Feb 29, 2012 11:57 PM
Poll Difficulty to fly rating system going4speed Foamies (Scratchbuilt) 14 Feb 18, 2010 03:39 AM
Discussion difficulty rating comanche100 Micro Helis 7 Dec 07, 2008 02:50 PM
Discussion Difficulty rating of a flying wing buurin Flying Wings 11 Apr 07, 2007 11:44 AM
