Old Jan 08, 2013, 02:22 AM
emeraldc is offline
Find More Posts by emeraldc
west coast flyer
emeraldc's Avatar
Joined May 2012
That's what I thought, this is a fresh model, no mix's, just the default throttle/pitch, I put in basic dual rates. I checked another model, same thing.
emeraldc is offline Find More Posts by emeraldc
Old Jan 08, 2013, 03:58 AM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
Originally Posted by emeraldc View Post
I'm programming 80% for the whole throttle curve of stunt 1, and when I go to the monitor & hit the fm switch I get 60%. When I put in 100% I get 100. I was going to try 80-85% to start, and I had to put in 93% on stunt 1 to get 86% on the monitor.
This is correct.Stop and think about it for a sec.Its a scaling thing.
The channel output is actually -100%/0/+100% for a total of 200 points.The curve menu is based on 100% of total travel.So every 1% on the curve menu translates to 2% on the monitor/output. 50% on the curve menu would show as 0 on the monitor/output.60%=+20% 70%=+40% etc.
aerocal is offline Find More Posts by aerocal
Old Jan 08, 2013, 09:50 AM
emeraldc is offline
west coast flyer
emeraldc's Avatar
Joined May 2012
I see, so it's important to check the monitor to know what throttle output your getting, since it's not going to be what you program, unless you program 100%. I would have thought they would explain this in the manual,as it seems kind of important.
Old Jan 08, 2013, 08:08 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
No, that would be correct for the pitch curve, but the the throttle curve is a 0-100 scale, if he is programing 80%, the monitor should show 80% in that flight mode.
When you are in the throttle curve menu, does it show an "in" and "out" someplace? I don't have a DX7d, just a DX7, but I think they should be pretty similar.
dacaur is offline Find More Posts by dacaur
Old Jan 08, 2013, 10:01 PM
emeraldc is offline
west coast flyer
emeraldc's Avatar
Joined May 2012
There is no "in" or "out" on the throttle curve menu. It doesn't make sense to me, pitch curve yes -100 to +100 but throttle should be 0 to 100. I wonder if its a glitch in the up-date?
Old Jan 08, 2013, 11:07 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
do you have any way to posts pics? it would be helpfull if you could post a pic of your throttle curve menu....
Old Jan 09, 2013, 12:09 AM
emeraldc is offline
west coast flyer
emeraldc's Avatar
Joined May 2012
Checked the monitor again, the throttle is -100 to +100
Old Jan 09, 2013, 02:30 AM
aerocal is offline
Central California
Joined Dec 2006
Read it again and think about it.The DX7 also doesnt show numerical values on the Monitor/output screen so you cant check what Im saying.Just think abnout it for another minute.Pitch with a normal swash is exactly the same.
Correct.
Throttle curve 0-100 for a total of 100
Monitor/channel output -100 to +100 for a total of 200
Think about what it is doing.If you set the curve at 50 the monitor should read zero.
Im a bit too tired to write out the equation but its not really much more than simple math.Think.
Old Jan 09, 2013, 02:41 AM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
got this done tonight, its awesome
DX7S backlight (15 min 29 sec)
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Jan 09, 2013, 05:47 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
You cut out the best part, getting to the screen. nice vid.
freechip is offline Find More Posts by freechip
Old Jan 09, 2013, 05:33 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
hah yea man i know...sorry...
Old Jan 09, 2013, 06:31 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Correct.
Well, OK if that's how it is, but it doesn't really make an sense to me for the throttle channel to show -100 to +100 since that's not how it works... The other channels yes, but not throttle, that will just cause confusion..... You are right on my DX7 the monitor channel doesn't show numbers, just the position on a scale, but if I set a flat throttle curve at 80%, it shows on my monitor at just over the 3/4 mark, which would of course be 80%, not 60%..... Seems like a silly setup to treat the throttle channel like any other at -100/0/+100, since that's not how it works in real life, at least on an aircraft radio. On a surface radio I guess I can see it since middle stick is zero throttle, but on an airplane or heli, middle stick is never 0 throttle, its always 50% (assuming a linear curve with no expo).
If that's how they set it up on a DX7s, the programmer should be fired....
Old Jan 09, 2013, 10:58 PM
emeraldc is offline
west coast flyer
emeraldc's Avatar
Joined May 2012
Ya!
Good way to confuse a newbie like me instead of keeping it simple stupid!
Old Jan 12, 2013, 08:26 PM
t280708 is offline
Find More Posts by t280708
United States, VA, Blacksburg
Joined May 2012
Question about the charge port in my DX7s: Is there a way I can wire up my transmitter (I am a very competent solderer) to be able to output power through the charge port from the TX battery (like the DX6i can do)?
Why would I want to do this? I've got my eye on a Heli-max 1SQ, which needs an Anylink to work, and to make matters slightly more inconvenient, the Anylink also needs to be powered by an external battery. This seems silly since there's a perfectly good battery already in the TX and it's easy to charge in any AC wall outlet.
Thanks!
t280708 is offline Find More Posts by t280708
Old Jan 13, 2013, 01:34 AM
bkahuna is offline
Find More Posts by bkahuna
The Big Kahuna of Foam.
bkahuna's Avatar
Columbus, OH
Joined Mar 2005
I'm looking to buy a DX7s. Does anyone know who'd got the best deal on them?
Ultimate Hobbies has a really good price, but they're out of stock.
bkahuna is offline Find More Posts by bkahuna
Sold Spectrum dx7 like new bhood Aircraft - General - Radio Equipment (FS/W) 14 May 03, 2011 07:51 AM
Sold Spectrum DX7 Like new, Airplane, Mode 2... Joe in Dublin Aircraft - General - Radio Equipment (FS/W) 4 Apr 06, 2011 08:37 PM
Discussion New Spectrum DX8 Registration iwchris Radios 6 Mar 31, 2011 02:10 PM
Sold Brand New DX7s Air Mode 2 190.00 shipped Pri Mail rino Aircraft - General - Radio Equipment (FS/W) 0 Dec 22, 2009 11:26 PM
Question Speculation on new Dx7s? spython Radios 1 Oct 01, 2008 08:34 AM
