Old Sep 24, 2012, 11:10 PM
midnite is offline
Find More Posts by midnite
Joined Feb 2012
Originally Posted by UNGN View Post
A lipo is the best thing you can buy for these radios. You will never worry about the battery again and fly for days without charging (not days between charging but actually FLYING for days without charging).
HK has a Dx8/7S 4K lipo for $18.
I haven't worried about my battery in a year. I think I worried every day about the NiMH battery. It was like watching the gas gage on a big block muscle car.
Yes indeed! That's the conclusion I quickly came to as well.
Spectrum did a poor job of including those NiMH packs with an internal charger that doesn't automatically shut down at peak charge. A bit puzzling really.
The LiPO pack should have been in the kit instead, cost notwithstanding.
But since that's what I now have and still using - I need to know how to effectively deal with that NIMH pack.
midnite is offline Find More Posts by midnite
Old Sep 24, 2012, 11:16 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
That's easy. Take it out of your radio and throw it in the recycle bin.
Buy a 4.0 mAh Lipo from HK for $23 shipped.
Problem solved.
You probably have more important things to worry about. Don't spend another minute on this one.
You are stressing over 2003 technology in 2012. Embrace 2006 technology and get on with your life.
UNGN is offline Find More Posts by UNGN
Old Sep 25, 2012, 12:00 AM
krazyman is online now
Find More Posts by krazyman
krazyman's Avatar
United States, AZ, Camp Verde
Joined Jan 2007
Loss of signal
Has anyone had signal problems with their DX7s? I have lost 4 planes lately, two of them were definite signal loss, the other two I thought were battery problems, but now I am beginng to wonder if they went down because of the TX not sending a signal. This has happened on 1 orange RX, 1 AR6110e, and 2 AR7000 Spektrum receivers. On my old DX7 you could tell if the the radio was transmitting by the green lite on the bind button. The DX7s doesn't have this feature. I don't know if I should get a different radio or what to do.
Terry
krazyman is online now Find More Posts by krazyman
Old Sep 25, 2012, 04:58 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
My DX8 NIMH batt took a dump after 2 months of use. I put the HK lipo in it and never looked back. Runs for an average of 2 months between charges using the charger in the trans.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Sep 25, 2012, 05:26 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by krazyman View Post
... two of them were definite signal loss, the other two I thought were battery problems, ... Terry
Can I ask how you know "definite" it was signal loss?
freechip is offline Find More Posts by freechip
Old Sep 25, 2012, 08:40 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Terry
Yes it does have that feature. The orange LED under the logo is what tells you it's transmitting. Go into System mode sometime and see it's off. Then watch it turn on when you go into Normal mode.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Sep 25, 2012, 09:00 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
... On my old DX7 you could tell if the the radio was transmitting by the green lite on the bind button. The DX7s doesn't have this feature. I don't know if I should get a different radio or what to do.
Terry
Originally Posted by AndyKunz View Post
Yes it does have that feature. The orange LED under the logo is what tells you it's transmitting. Go into System mode sometime and see it's off. Then watch it turn on when you go into Normal mode. Andy
DX6i, DX7s,DX8,DX10t and DX18 all have this feature.
Old Sep 25, 2012, 09:06 AM
clp.eng is offline
Find More Posts by clp.eng
United States, FL, Ocala
Joined Apr 2008
krazyman - my DX7s was not transmitting out of the box. HH replaced the ant & RF module. Maybe yours is going bad. Call them as they are usually very helpful.
My HK Tx LiPo should be here soon (after waiting 3 weeks for delivery!).
Chuck
clp.eng is offline Find More Posts by clp.eng
Old Sep 25, 2012, 12:55 PM
Krycek W is offline
Find More Posts by Krycek W
Krycek W's Avatar
Canada, QC, Montreal
Joined Jun 2012
Terry
Has a IT worker, first thing I will suggest you to do is to make a firmware update of the DX7s. 2 new versions since the start up of the DX7s.
I had mine since last March and no signal lost problem. I had use the AR8000 (DSMX mode), AR6310(DSMX mode), Orange R610(DSM2 mode) and the DSM2 Rx in 2 UM from Parkzone.
Krycek W is offline Find More Posts by Krycek W
Old Sep 25, 2012, 03:48 PM
krazyman's Avatar
Joined Jan 2007
I found the problem that I thought was just signal loss. The connector for the SBEC that plugs in to the RX had a loose prong and was not making good contact. This is the SBEC that I was using in both planes that had no control. I guess the other two planes went down because of bad batteries. They just lost power and stalled.
Where do you get Firmware updates? And how do you load them?
Terry
Old Sep 25, 2012, 04:12 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
You register your radio on the Spektrum websitee Once registered you can check for update and download them onto the radio's SD card. Then install in the radio and power on the radio and let it do it's thing.
Tips: Eject or Safely Remove the SD card from the PC, most SD card and update issues relate to improper removal of SD card from PC.
Old Sep 25, 2012, 04:31 PM
krazyman's Avatar
Joined Jan 2007
Thanks, I will do that now.
Terry
Old Sep 25, 2012, 10:03 PM
midnite is offline
Joined Feb 2012
Problem solved.
I fully intend to do just that - but since I'm flying with it now, if anyone has been using that NiMH pack with any success, I'd appreciate some answers to the questions in post #794. Also, even after using a LiPO pack the NiMH will still be used as a backup.
No stress, just need information. Thanks.
Old Sep 25, 2012, 10:33 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Good luck in your quest. I'm afraid no one has the answers you seek.
The Charger in the radio is not made for NiMH batteries, it is made for lipo batteries. There are "Smart chargers" and there are "dumb chargers". it is a Dumber charger.
HH sees Lipo batteries as a profit center. It's always been part of their business model. It's why they didn't spend one extra buck making a smart NiMH charger, knowing eventually everyone who purchases a TX will give up on the NiMH battery and buy a Lipo.
A bit of forshadowing:
When you purchase a Lipo battery, the NiMH will go into a box some where, never to be heard from or seen again. It won't be a "backup" for anything, except maybe a table with a short leg.
Old Sep 25, 2012, 10:58 PM
midnite is offline
Joined Feb 2012
OK, thanks.
And you very well might be right about not using the NiMH pack as a backup.
They should sell the radio without batteries - maybe that's essentially what's happening anyway and the NiMH pack is just to allow immediate initial use. I suppose it's like those minimal memory cards that are/were supplied with cameras.
The DX6i - 4 single AA cells, no built-in charger, is a better arrangement in my opinion. Is there really a need for a charger to be built into the 7s or any other transmitter for that matter?
Sold Spectrum dx7 like new bhood Aircraft - General - Radio Equipment (FS/W) 14 May 03, 2011 07:51 AM
Sold Spectrum DX7 Like new, Airplane, Mode 2... Joe in Dublin Aircraft - General - Radio Equipment (FS/W) 4 Apr 06, 2011 08:37 PM
Discussion New Spectrum DX8 Registration iwchris Radios 6 Mar 31, 2011 02:10 PM
Sold Brand New DX7s Air Mode 2 190.00 shipped Pri Mail rino Aircraft - General - Radio Equipment (FS/W) 0 Dec 22, 2009 11:26 PM
Question Speculation on new Dx7s? spython Radios 1 Oct 01, 2008 08:34 AM
