Old Jun 18, 2012, 08:07 PM
Buschbarber is offline
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
Originally Posted by dacaur View Post
Ah thats too bad, with all the hubub that caused with DSM/DSM2, I would have thought spektrum would find away around that.... Which one does it default too? I know my DX7 defaults to DSM, so if I initiate a bind on the TX and not the reciver, my DX7 will still work with my AR6000, but not my AR500, since it defaults to DSM until it hears back from a DSM2 reciver.....
If you have a DSM2 receiver, it Binds as DSM2. If you have a DSMX receiver, it Binds to DSMX. You can force a DSMX receiver back to DSM2, in the transmitter. Then you must reBind.
Buschbarber is offline Find More Posts by Buschbarber
Old Jun 23, 2012, 09:04 AM
DS NZ is offline
Find More Posts by DS NZ
AUCKLAND NZ
Joined Jul 2010
Hi just want set up for crow flaps mixs for gliders on dx7s seems like lots of mixs to get these remote to get the job done .i have 4 servo wing rudder elevator on my caracho cheers
DS NZ is offline Find More Posts by DS NZ
Old Jun 23, 2012, 09:19 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Very easy!
Use 2-ail/1- or 2-flap wing type.
Assuming you want throttle stick to give crow,, mix THR > LAL, offset 100%. Use 0% for the top rate and -50% for the bottom rate (you will need to modify the value to get the deflection you want).
To get the flaps to move, mix THR > RFL (if 2-flap or just to FLP is 1). Set the offset to 100%. Again, use 0% for the top Rate (it's not used because of the 100% offset) and the bottom Rate to -50%. You need to adjust the sign of the lower Rate to get the flaps to go in the right direction.
Now as you pull the stick to you, flaps will go down and ailerons up.
If you fly with the stick forward, you can still use Flap System to provide preset values for speed, launch, etc.
You probably don't want those mixes active all the time. Be sure to assign a switch properly (the same to both mixes).
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jun 23, 2012, 09:49 AM
DS NZ is offline
AUCKLAND NZ
Joined Jul 2010
U the man andy will give that a go have you got any more tips for mixs ,ive got ar8000 rx i cant get any travel adjustment on elevator can you please tell me what im doing wrong ,finding it a misson flaps working with ailerons cant get settings right eg flaps up 12mm aileron up 14mm and flaps down 9mm and aileron down 8mm .also want camber ,snapflap, how and what mixs do i need cheers glenn
Old Jun 28, 2012, 06:22 AM
Nerm is offline
Find More Posts by Nerm
Quads Helis Planes Cars
Nerm's Avatar
Canada, ON, Brampton
Joined Aug 2009
I don't know if this has been asked before but what should the voltage read on the DX7S screen when the 4.8v battery pack is fully charged?
Nerm is offline Find More Posts by Nerm
Old Jun 28, 2012, 07:06 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
5.5 give or take.
It has been ask numerous times.
There is also a Viltage difference between what is displayed and the actual battery voltage.
freechip is offline Find More Posts by freechip
Old Jun 28, 2012, 07:38 AM
Telrin is offline
Find More Posts by Telrin
Dallas, TX
Joined Jan 2010
True for a DX7S, but the original post mentioned binding to a DSM receiver so he is talking about a DX7 capable of DSM/DSM2, not DSMX.
It will of course still bind to a DSMX receiver, but only in DSM2 mode.
Telrin is offline Find More Posts by Telrin
Old Jun 28, 2012, 09:20 AM
garryk is online now
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
I tried exporting a model into the same memory slot it originated from and still had to re-bind. What could I have done wrong?
Garry K.
garryk is online now Find More Posts by garryk
Old Jun 28, 2012, 10:09 AM
Nerm is offline
Nerm's Avatar
Joined Aug 2009
Originally Posted by freechip View Post
5.5 give or take.
Thanks Freechip
I really like the DX7S, I just upgraded from 2 DX6I I just sold.
It would have been nice if they made it so that the light goes out when fully charged. My only complaint so far with this radio.
Old Jun 28, 2012, 10:22 AM
Joined Apr 2004
Originally Posted by Nerm View Post
Thanks Freechip
Get the LiPo Tx battery and your wish will come true.
Old Jun 28, 2012, 10:42 AM
Nerm is offline
Nerm's Avatar
Joined Aug 2009
I'd like to but the price is a burn.
Any aftermaket that are a good fit?
Old Jun 28, 2012, 10:51 AM
craig01 is offline
Find More Posts by craig01
craig01's Avatar
Australia, NSW, Leura
Joined Jan 2012
http://www.ebay.com.au/itm/Lectron-P...item5894628d7c
Have one coming...so can't comment...yet.
craig01 is offline Find More Posts by craig01
Old Jun 28, 2012, 10:52 AM
Joined Apr 2004
I have the Hobby King DX8 LiPo. $17
4000mah
Old Jun 28, 2012, 10:59 AM
Nerm is offline
Nerm's Avatar
Joined Aug 2009
4000mah
Ya, that's more like it.
They are b/o right now. Might just order one.
Old Jun 28, 2012, 09:39 PM
propwash17 is offline
Find More Posts by propwash17
propwash17's Avatar
United States, NJ, Bergenfield
Joined Jun 2004
HK Lipo
4000mah
I also have been using the HK Turnigy DX8 4000mah Lipo for the last 3 months, couldn't be happier with it, and at $17 dollars, you can't go wrong.
I fly about 3 days a week, weather permitting, and charge about once a month.
Ron
propwash17 is offline Find More Posts by propwash17
Sold Spectrum dx7 like new bhood Aircraft - General - Radio Equipment (FS/W) 14 May 03, 2011 07:51 AM
Sold Spectrum DX7 Like new, Airplane, Mode 2... Joe in Dublin Aircraft - General - Radio Equipment (FS/W) 4 Apr 06, 2011 08:37 PM
Discussion New Spectrum DX8 Registration iwchris Radios 6 Mar 31, 2011 02:10 PM
Sold Brand New DX7s Air Mode 2 190.00 shipped Pri Mail rino Aircraft - General - Radio Equipment (FS/W) 0 Dec 22, 2009 11:26 PM
Question Speculation on new Dx7s? spython Radios 1 Oct 01, 2008 08:34 AM
