Old Jun 15, 2012, 05:26 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
They look a lot like what they used on the DX18
freechip is offline Find More Posts by freechip
Old Jun 17, 2012, 01:39 AM
garryk is online now
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
Well I found out today that if you save your model memory into the sim card that when you import it to the active list that you have to re-bind it. That totally sucks man. Even though it's better than reprogramming the whole plan, it's still a bitc#....!!!!!!!!!!! As one of the planes takes up all the slots on the RX and they're a real bitc# to unplug and plug in again. Guess that will remain one of the active ones. Oh well.... better than no option, but would have been so easy for them to change this simple thing with an amateur programmer doing the code for this TX. Maybe it could be a simple download to address this issue??? I'm sure it could, but the Q? is will it be done?????? SO easy to do!!!! So Do IT Please!!!????????????
Garry K.
Garry K.
garryk is online now Find More Posts by garryk
Old Jun 17, 2012, 02:13 AM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
If you import it to the same memory position(number) that you exported it from
the bind information should remain intact.
aerocal is offline Find More Posts by aerocal
Old Jun 17, 2012, 02:28 AM
Corsair Captain
Joined Oct 2010
That may be true,,but my brain can't keep track of all that.
Garry K.
Old Jun 17, 2012, 02:47 AM
Rayne is offline
Find More Posts by Rayne
"Landing" in a tree somewhere
Rochester, NY
Joined Sep 2009
One feature of the DX7s is being able to transfer model memories from one radio to another. Say you share one of your setup files with a buddy to use as a guide in order to help him with programming his plane. If he turns on his transmitter with that model memory and the bind is saved in it then he could accidentally interfere or take control of your plane. By not saving the bind settings it ensures that a receiver is only bound to a single radio at any given time.
Rayne is offline Find More Posts by Rayne
Old Jun 17, 2012, 05:18 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Each Spektrum radio has a unique code that only your radio has, and transfered to your rcvr. One in a million has that code, so not much chance that there will be interference.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jun 17, 2012, 07:54 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Garry K.
It doesn't have to. The first two digits of the filename are the model number.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jun 17, 2012, 07:56 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by flypaper 2 View Post
Each Spektrum radio has a unique code that only your radio has, and transfered to your rcvr. One in a million has that code, so not much chance that there will be interference..
No, it's one in 4,294,967,295. Even though we've made a LOT of radios, we haven't quite crossed the 32-bit boundary...
...Yet.
Andy
Site Sponsor
Old Jun 17, 2012, 09:14 AM
Buschbarber is offline
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
Garry K.
Garry K.
If you use a Switch Harness to connect your RX battery to your Rx, you can use a 3 wire DSC type Switch Harness and Bind through the Charging Jack. If you do not use a Switch Harness, you can connect a Y Harness to the Bind Port and run an extension to the side of the fuselage. Either way, it is easy to Bind quickly without unplugging anything from the Rx.
Buschbarber is offline Find More Posts by Buschbarber
Old Jun 17, 2012, 12:21 PM
Corsair Captain
Joined Oct 2010
OK,,, I'll figure this out some how. So long as I use the same model number memory as before, the original binding will survive the transfer?
Does this mean that if I export a model to the same model memory slot that it could control the receiver that was previously bound to that memory slot also?
Garry K.
Old Jun 17, 2012, 12:53 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Garry K.
When you bind a model, you arent actualy doing anything on the transmitter end, You are simply teaching the reciver the GUID of the transmitter. Since each slot has a different GUID, keeping the model in the same slot should keep your bind.
I say should because I only have a DX7 so cant actualy test that, The only problem I can see is if the DX7S is like the DX7 in that it defaults to either DSM2 or DSMX and the reciver you are using is the opposite. A DX7 defaults to DSM mode when you initate a bind. If you are binding it to a DSM2 reciver, the reciver actualy tells the transmitter that, and it will transmit in DSM2 mode. Later if you accidentally initiate a bind on the transmitter (somehow hold the bind button on power up) without realising it, since the reciver isnt in bind mode it cant tell the transmitter its in DSM2, so the transmitter defaults to DSM..... So even though the reciver still has the right GUID, the transmitter is transmitting in a language the reciver cannot understand.... It was kind of a problem for people using transmitter trays back in the day, so hopefully spektrum has figured out how to do it without requiring the input from the reciver as to weather its DSM2 or DSMX.....
dacaur is offline Find More Posts by dacaur
Old Jun 18, 2012, 08:10 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Not true. The transmitter also learns the type of receiver so it can talk to it properly.
Andy
Site Sponsor
Old Jun 18, 2012, 08:45 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Remember, receiver talk back to the radio during binding.
Hello, anybody home?
Yes, it's me AR6200.
Old Jun 18, 2012, 04:36 PM
clp.eng is offline
Find More Posts by clp.eng
United States, FL, Ocala
Joined Apr 2008
Anybody figure out how to adjust the neck strap that came with the DX7S? My 1st strap & it doesn't make any sense, e.g. one of the buckles is on a single strap & just slides up & down?!? The other buckle seems to have all the straps jammed into it. Thanks.
Chuck
clp.eng is offline Find More Posts by clp.eng
Old Jun 18, 2012, 06:15 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Andy
Ah thats too bad, with all the hubub that caused with DSM/DSM2, I would have thought spektrum would find away around that.... Which one does it default too? I know my DX7 defaults to DSM, so if I initiate a bind on the TX and not the reciver, my DX7 will still work with my AR6000, but not my AR500, since it defaults to DSM until it hears back from a DSM2 reciver.....
EDIT - 4-29-2013 - I have learned that a DSMX tarnsmitter doesnt "default" to either DSMx or DSM2. It stays on whatever protocal it was last bound on.... If you have 2 DSM2 recivers bound to one slot, then you bind a DSMX reciver, the DSM2 recivers will stop working. If you then bind a third DSM2 reciver to the same slot, the first two DSM2 recivers will work again, but the DSMX reciver will stop working, becuase it was taught on binding to listed for DSMX, so isnt listening for DSM2......
Sold Spectrum dx7 like new bhood Aircraft - General - Radio Equipment (FS/W) 14 May 03, 2011 07:51 AM
Sold Spectrum DX7 Like new, Airplane, Mode 2... Joe in Dublin Aircraft - General - Radio Equipment (FS/W) 4 Apr 06, 2011 08:37 PM
Discussion New Spectrum DX8 Registration iwchris Radios 6 Mar 31, 2011 02:10 PM
Sold Brand New DX7s Air Mode 2 190.00 shipped Pri Mail rino Aircraft - General - Radio Equipment (FS/W) 0 Dec 22, 2009 11:26 PM
Question Speculation on new Dx7s? spython Radios 1 Oct 01, 2008 08:34 AM
