Old Apr 14, 2012, 05:14 PM
clp.eng is offline
Find More Posts by clp.eng
United States, FL, Ocala
Joined Apr 2008
I bought the DX7s three weeks ago. DOA! HH had to replace the antenna & RF module. My DX6i went back 4 times before they replaced it. So 1 down,...
Chuck
clp.eng is offline Find More Posts by clp.eng
Old Apr 14, 2012, 06:32 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
Today I mailed out my sold Dx7s, and picked up an aurora 9 at my lhs. Not dissappointed- a lot more functionality at a marginally higher price
copperbricks is offline Find More Posts by copperbricks
Old Apr 17, 2012, 03:02 PM
Kurpal is offline
Find More Posts by Kurpal
Joined Nov 2006
I went with the original Dx7 manufactured by JR. It wont have all the bells and whistles of the new shiny transmitters but I doubt it will ever fail me either.
Does the Aurora 9 have some clones Rxs out at all? I might look into other brands if there are reasonably priced Rxs, I am way too cheap to pay $60-120 per Rx.
Kurpal is offline Find More Posts by Kurpal
Old Apr 17, 2012, 03:46 PM
freechip is online now
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
Originally Posted by Kurpal View Post
... I doubt it will ever fail me either. ...
Becareful of the BACKUP MEMORY ERROR, it will brick your TX and you will have no choice but to send it in for service.
freechip is online now Find More Posts by freechip
Old Apr 17, 2012, 04:57 PM
Joined Aug 2011
No clones, but full range minima 6s can be had for about $38 a pop. And then full range optima 6s with built in voltage telemetry are only about 48-50, and 130 for a three pack. The other two Optima receivers (more channels) have the same features, plus capabilities for a full house telemetry system, and the price for them goes up in about $15 dollar increments:
Old Apr 17, 2012, 05:54 PM
seefest is offline
Find More Posts by seefest
seefest's Avatar
United States, MA, Bristol
Joined Sep 2009
Go Nitro.com has O6's on e-bay for $42 or so, 3 packs for $108.
I wish HK had a clone out even though the genuine receivers are pretty reasonable.
seefest is offline Find More Posts by seefest
Old Apr 17, 2012, 07:52 PM
Kurpal is offline
Joined Nov 2006
Sending it back once after 5 years is better than sending it in 5 times in less than 1 year .
I have heard of that bug, it seems to be the biggest/worst one of the Tx has suffered.
Old Apr 17, 2012, 08:21 PM
freechip's Avatar
Joined Aug 2008
Hey some people rather drive a mustang that's in the garage once a month then drive a focus.
Old Apr 28, 2012, 04:09 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
Can Someone help me with finding throttle elev Mix with the DX7S
I cannot find it for the life of me
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Apr 28, 2012, 04:17 PM
pach is offline
Find More Posts by pach
United States, FL, Miami
Joined Aug 2009
Custom mix 1 ?
pach is offline Find More Posts by pach
Old Apr 29, 2012, 07:45 PM
sq0nk is offline
Find More Posts by sq0nk
United States, TX, Cedar Park
Joined Oct 2011
I'm finishing up on my Hangar 9 Twin Otter and running into something I can't figure out. While everything seems to work OK the problem is the left elevator. When I make a Mid Flap % change (or Land % change) in the Flap System menu the flaps move as expected but so does left elevator. Nothing has been entered into the Elevator side, everything is 0%
Current config with stock receiver:
Wing Type:
Wing: 1 Aileron 2 Flaps
Tail: Dual Elevator
Throttle: Y-plug to motors
Aileron: Y-plug to Ailerons
ELEV: Left Elevator
Rudder: Y-plug to Rudder and Nose gear
Gear: Right Elevator
Aux 1: Right Flap
Aux 2: Left Flap
Any ideas as to why the left elevator would move when I'm making Flap % changes?
sq0nk is offline Find More Posts by sq0nk
Old Apr 29, 2012, 08:41 PM
freechip's Avatar
Joined Aug 2008
Can you post your SPM file here so we can have a look at it. Pretty sure Andy's going to ask the same thing.
Change the xxxx.SPM to xxxx.TXT and upload here.
Why did you opt to use 1 aileron and 2 flaps? Just curious.
When selecting 1 Aileron and 2 flaps and dual elevator tail
The servo arragement the DX8 selects does not match what you describe.
Throttle
Aileron
Elevator - Right Elevator
Rud
Gear
Aux1 - Right Flap
Aux2 - Left Flap
Aux3 - Left Elevator.
On a fresh new blank model.
1 Aileron and 2 Flap wing type
2 elevator tail type
25% mid flap
50% land flap
No movement on both elevators.
Chances are you have something/programming that you don't see right away that is affecting your elevator/s.
Any chances you have other mixing/programming and are you sure you have the servos connected where the DX8 wants you to connect them? If you look at the servo monitor screen it renames the channels that should be a good indication of where to plug the actual servos.
Old Apr 29, 2012, 10:01 PM
wmcneal is offline
Find More Posts by wmcneal
AMA 125691
wmcneal's Avatar
Jacksonville Florida
Joined Jul 2002
I ran into a similar problem on another twin otter. The pilot had the wrong wing type selected. Just something to double check.
wmcneal is offline Find More Posts by wmcneal
Old Apr 30, 2012, 10:29 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
You created left elevator on Gear by using a mix. That's the problem.
Your elevator > gear mix takes the elevator INPUT (the stick) and connects it to the gear output. What you really want to do is connect the elevator FUNCTION to the gear output, but the DX8 does not provide a was to do that.
To gain access to the flap system functions on the elevator, you need to plug the left elevator into the Aux3 port on the receiver.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Apr 30, 2012, 01:46 PM
SMCLEODVT is offline
Find More Posts by SMCLEODVT
SMCLEODVT's Avatar
United States, VA, Roanoke
Joined Nov 2009
i had same issue - its your wing type selection
SMCLEODVT is offline Find More Posts by SMCLEODVT
Sold Spectrum dx7 like new bhood Aircraft - General - Radio Equipment (FS/W) 14 May 03, 2011 08:51 AM
Sold Spectrum DX7 Like new, Airplane, Mode 2... Joe in Dublin Aircraft - General - Radio Equipment (FS/W) 4 Apr 06, 2011 09:37 PM
Discussion New Spectrum DX8 Registration iwchris Radios 6 Mar 31, 2011 03:10 PM
Sold Brand New DX7s Air Mode 2 190.00 shipped Pri Mail rino Aircraft - General - Radio Equipment (FS/W) 0 Dec 23, 2009 12:26 AM
Question Speculation on new Dx7s? spython Radios 1 Oct 01, 2008 09:34 AM
