Old Jan 11, 2012, 07:33 AM
scribble79 is offline
Find More Posts by scribble79
The woods
Joined Feb 2011
I really emjoy my DX7S only thing I also found that that 8 has that the 7 doesn't is the 8 has servo speed changing ability.
scribble79 is offline Find More Posts by scribble79
Old Jan 11, 2012, 11:49 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
And backlight, and lots of 3 positions switches and more. But you are kinda wrong. The DX7s does have servo speed reducer, just not on all channels.
Key Features20
Model Memory
Built-In Telemetry
Extensive Airplane and Helicopter Programming
Throttle-Activated Timer Setting
AR8000 High Speed 8 Channel Receiver
LiPo Battery Compatibility
8 Wing Types
5 Tail Types
3-Position Flaps with Delay and Elevator Compensation
Dual Rates and Expo
Differential
5-Point Throttle, Pitch and Tail Curves
6 Swash Plate Types
6 Programmable Mixes
Control Position Warnings
Audio and Vibe Alarm Settings
Large 126 x 64 LCD Screen
Mode Selection (Modes 1, 2, 3, 4)
Language Select (English, Italian, French, Spanish or German)
4.8V 2000mAh NiMH Transmitter Battery
High-speed 11ms frame rate with 2048 resolution
128MB SD Card (included)
Just going by whats on there feature list, I have the DX8 and so can't confirm this on the DX7s
freechip is offline Find More Posts by freechip
Old Jan 11, 2012, 10:38 PM
The woods
Joined Feb 2011
Ok I should have said on all channels. I would think gear would have been one to have speed for also. People don't want there gear slamming up and down.
Old Jan 12, 2012, 04:03 AM
laurentjeuxlille is offline
Find More Posts by laurentjeuxlille
France, Nord-Pas-de-Calais, Croix
Joined Jul 2011
Hi happy owners of dx7s...
Thinking about buying one after the dx6i that i have, i have questions :
- Is it possible to change mode easily like for the dx8 ?
- Is it better to buy a dx8 than à dx7 because dx7 AND telemetry will cost the same as a dx8 ?
Thx to you.
laurentjeuxlille is offline Find More Posts by laurentjeuxlille
Old Jan 12, 2012, 05:54 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
BUT most proper gear servo CAN NOT BE SLOW DOWN and most likely why they did it this way.
Unless you are using standard servo for gear, using a retract servo slowly down the gear channel will only delay the triggering point of the retract and not the actual retract speed.
Old Jan 12, 2012, 05:56 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Thx to you.
Si tu veut toute les accésoires la DX8 est la manetre pour toi, tu peut toujours revendre les items que tu veut pas pour récupérer ton argent.
Old Jan 12, 2012, 08:17 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Yes, in fact since it's the same housing and gimbals, it's exactly the same. You can read the procedure on page 40-ish in the DX8 manual. (I don't have a DX7s manual to compare to).
Buy the level of radio you can afford that delivers the features you desire.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jan 12, 2012, 09:40 PM
johnnyV52 is offline
Find More Posts by johnnyV52
Joined May 2011
Trying to register my radio..... Found the serial number screen but which number is it? Couldn't get the how to find serial number function to work on registration site.
John
johnnyV52 is offline Find More Posts by johnnyV52
Old Jan 13, 2012, 12:09 AM
The woods
Joined Feb 2011
Seirel number is in a settings menu in the tx.
Old Jan 13, 2012, 01:12 AM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
John
Best way to do it is to go to the serial number screen in System Settings.Make sure the SD card is in the radio and click on Export on the same screen.Pull the card out and put it in a PC.You will see a file on the card labeled My DX7s.Open the file and you can copy then paste the serial number onto the registration page.Then theres no chance of missing or getting a character wrong.
aerocal is offline Find More Posts by aerocal
Old Jan 13, 2012, 04:55 PM
Joined May 2011
Thanks.... Just curious, is it that entire series of numbers and letters on that screen?
Old Jan 13, 2012, 05:04 PM
Evan D is online now
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Any 9503's?
Originally Posted by cloudniner View Post
These numbers came from Great Hobbies over the holiday period. Looks like Spektrum is doing just fine thank you. So much for the supposed superiority of the A9.
27 = Dx7s SOLD | 11 = DX8 SOLD | 2 = JR11X SOLD | 2 = A9 SOLD
40 to 2 says it all. Good on you Horizon.
Evan D is online now Find More Posts by Evan D
Old Jan 13, 2012, 05:44 PM
The woods
Joined Feb 2011
Yes that is.
Old Jan 16, 2012, 07:20 PM
brandojs is offline
Find More Posts by brandojs
Joined Apr 2009
System Inactive Warning
I haven't found much luck reading through the manual, but is there a way to change/disable the system inactive warning? Its a bit jolting to be coasting gently when the transmitter starts beeping and vibrating.
brandojs is offline Find More Posts by brandojs
Old Jan 16, 2012, 07:26 PM
Dodge DeBoulet is offline
Find More Posts by Dodge DeBoulet
Dodge DeBoulet's Avatar
Joined Dec 2011
Nope. Same as the DX8.
Dodge DeBoulet is offline Find More Posts by Dodge DeBoulet
Sold Spectrum dx7 like new bhood Aircraft - General - Radio Equipment (FS/W) 14 May 03, 2011 07:51 AM
Sold Spectrum DX7 Like new, Airplane, Mode 2... Joe in Dublin Aircraft - General - Radio Equipment (FS/W) 4 Apr 06, 2011 08:37 PM
Discussion New Spectrum DX8 Registration iwchris Radios 6 Mar 31, 2011 02:10 PM
Sold Brand New DX7s Air Mode 2 190.00 shipped Pri Mail rino Aircraft - General - Radio Equipment (FS/W) 0 Dec 22, 2009 11:26 PM
Question Speculation on new Dx7s? spython Radios 1 Oct 01, 2008 08:34 AM
