Old Dec 27, 2011, 08:49 PM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
Originally Posted by copperbricks View Post
Quick question- in wing types, if I select 2 aileron and 2 flap servos will it bump one of the ailerons into the gear channel?
thanks
btw, love the dual flap option-helped with a plane where the flaps were extending unevenly.
Yes.With 2 ail and 2 flp your out of channels.The other 3 are needed for thr ele rud.
aerocal is offline Find More Posts by aerocal
Old Dec 28, 2011, 07:39 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Actually the left aileron goes to Aux1 and Gear becomes Left Flap.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Dec 28, 2011, 09:26 AM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
oh, okay, thanks
copperbricks is offline Find More Posts by copperbricks
Old Dec 29, 2011, 08:36 AM
ldely is offline
Find More Posts by ldely
Joined Dec 2011
I've just bought this radio
if i buy the USB cable can i use the dx7s with realflight g 4,5?
ldely is offline Find More Posts by ldely
Old Dec 29, 2011, 08:44 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
If RF 4,5 does not require to see its own TX. Last time I play with my brother RF G4.5 it needed to see the stock TX connected in order to start.
I think you can connect real TX in the SIM TX. Would need to confirm with BRO first.
freechip is offline Find More Posts by freechip
Old Dec 29, 2011, 08:46 AM
H.D. is offline
Find More Posts by H.D.
ride hard and fly low
H.D.'s Avatar
Joined Aug 2011
Andy,
I went over the owners manual before trying to tighten the throttle stick, got several turns on the adjustment scew with no results to the throttle stick. What am I doing wrong?
Thanks.
H.D. is offline Find More Posts by H.D.
Old Dec 29, 2011, 09:06 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
I don't know, but if you call Support they can actually do it with you on the line. I'm going to be offline most of today.
Andy
Site Sponsor
Old Dec 29, 2011, 09:44 PM
Kurpal is offline
Find More Posts by Kurpal
Joined Nov 2006
Andy
Woah is there an extra hourly fee they charge for that? Surely not all the people in this hobby are that lonely...
Sorry, couldn't resist.
Kurpal is offline Find More Posts by Kurpal
Old Dec 30, 2011, 03:59 AM
aerocal is offline
Central California
Joined Dec 2006
No comment.
Old Dec 30, 2011, 09:50 AM
soarak is offline
Find More Posts by soarak
Joined Dec 2011
DX7s and USB cable issue
Did any of you guys test the DX7s with a USB simulator cable that you previously used with another spectrum radio and if so does it work?
I noticed that many of the usb cables do not support DX7se because it is faster radio (most likely reason). Based on what I read the DX7s is as fast as the DX7se so it is likely that the existing USB simulator cables will not work. I actually tried one and it did not work (tomsrc.com for JR).
I wonder if anyone got lucky with their old cables.
soarak is offline Find More Posts by soarak
Old Dec 30, 2011, 10:24 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
The DX7s trainer system works fine with simulators. It is identical to the DX8, which matches the JR standard.
The ability to get the DX7SE's latency in the DX7s and DX8 has to with a decade-ish newer design and chips. The DX7SE had no trainer capability - that was what you had to give up in order to get the speed.
Andy
Site Sponsor
Old Dec 30, 2011, 11:35 AM
soarak is offline
Joined Dec 2011
Thank you for the explanation
Thank you a lot!
Andy
Old Dec 30, 2011, 01:02 PM
soarak is offline
Joined Dec 2011
How to set up the DX7s with USB simulator cable
Could anyone please tell me how to set up the DX7s with the USB simulator cable. Do I need to program the transmitter with special trainer setting to get signal output on training port. I noticed the trainer configuration has four choices Inhibit, Programmable, Pilot Link Master and Slave. I am not sure if any of these play any role when DX7s is connected to a PC. My issue is the USB cable registers fine with the windows 7 as game controller but I get no signal to the PC.
Is using the USB simulator cable connection as simple as plugging it into the transmitter and selecting the right model? Are my issues related to the cable connector and not the trasmitter?
Andy
Old Dec 30, 2011, 01:42 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Inhibit mode is a Normal Slave. In this mode, the PPM is what you would be sending to the airplane if you were flying a model. If you change wing type, the PPM will be different accordingly. You can use the trims, etc. just as if you were flying. With this mode, the programming in BOTH radio needs to match!
In Slave mode, the signals going out on the 4 primary channels are stick positions only. This would be what you would likely use with a P-Link Master transmitter.
The mode named Programmable is a standard master mode. You specify which channels are used in the PPM stream from the slave. The data is sent unmodified directly to the airplane. Remember, this mode requires both Master and Slave radios to be programmed the same.
The P-Link Master takes the first four channels from the slave and acts as if they were the sticks on the master. With this mode, only the master radio needs to have appropriate programming for the airplane.
I suspect you want to have the transmitter in Inhibit mode. This will allow your trims to work (they don't in Slave mode).
Also, you want your transmitter OFF!!! If you turn the transmitter on, it won't generate the signals on the trainer port! When you plug the cable into the radio, it will turn on in slave mode. When you use the front switch it turns on in Master mode.
I'll bet that's where you went wrong. I've done it myself more than once.
Andy
Site Sponsor
Old Dec 30, 2011, 02:25 PM
soarak is offline
Joined Dec 2011
Unfortunately that is not the case I had the Tx off. Could you tell me what the specification for the trainer port is, is it stereo or mono type? I noticed the Phoenix cable is stereo, but other cables available are mostly mono. What is the DX7s requirement? Will it send signal through mono connector or does it need a stereo connector?
Andy
Sold Spectrum dx7 like new bhood Aircraft - General - Radio Equipment (FS/W) 14 May 03, 2011 07:51 AM
Sold Spectrum DX7 Like new, Airplane, Mode 2... Joe in Dublin Aircraft - General - Radio Equipment (FS/W) 4 Apr 06, 2011 08:37 PM
Discussion New Spectrum DX8 Registration iwchris Radios 6 Mar 31, 2011 02:10 PM
Sold Brand New DX7s Air Mode 2 190.00 shipped Pri Mail rino Aircraft - General - Radio Equipment (FS/W) 0 Dec 22, 2009 11:26 PM
Question Speculation on new Dx7s? spython Radios 1 Oct 01, 2008 08:34 AM
