Old Aug 19, 2003, 09:42 AM
Warren Jones is offline
Find More Posts by Warren Jones
Warren Jones's Avatar
Langley,B.C,Canada
Joined Jul 2002
My Scale Revenue Cutter
I started this (early summer). I poke away at on a given Sunday.
Since I`m doing the aircraft thing right now I`m progress has slowed a bit.
The Hull is 6' without the bow sprit. I`m planning on Lateen, square rig (Maybe studs as well) and forward jibs.
It took me years to compile sheer, plans, etc to build the one I want.
Briish Cutter "Comet" 1809
Cheers
Warren
Warren Jones is offline Find More Posts by Warren Jones
Old Aug 19, 2003, 09:48 AM
Langley,B.C,Canada
Joined Jul 2002
Forward 1/4
She is all scratch with solid oak keel. Bass deck,etc. I haven`t decided on the hull planking yet.
Cheers
Warren
Old Sep 17, 2003, 08:18 PM
oilman is offline
Find More Posts by oilman
Powell River BC Canada
Joined Sep 2003
You say youve drawn plans? Will you sell a copy? oilman2@telus.net
oilman is offline Find More Posts by oilman
Old Apr 30, 2004, 08:17 PM
Langley,B.C,Canada
Joined Jul 2002
Back at it again
Well I hauled it out onto the bench. Sheeted most of the deck. Planed the main mast today. Blocks are being cut as well. I`ll posy more picks soon.
Cheers
Warren
Old Apr 30, 2004, 09:19 PM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Warren, Looking good, can't wait to see the progress photos--I love those old boats!
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old Mar 01, 2006, 05:10 PM
Langley,B.C,Canada
Joined Jul 2002
Finally back at it,.......again.
I had her put away for awhile. Decided to start back up again. Between this and my PBY I`m hoping to be on the lake with both this summer.
Warren
Old Mar 01, 2006, 05:16 PM
Langley,B.C,Canada
Joined Jul 2002
Some Pics
I`ll be documenting this one since I have a new camera now.
Old Mar 01, 2006, 05:19 PM
Langley,B.C,Canada
Joined Jul 2002
More Pics
I`ve been planking and working the Mast. I`ll post more pics tonight.
Cheers
Old Mar 01, 2006, 05:53 PM
Langley,B.C,Canada
Joined Jul 2002
Deck Planking
After much thought,.......like 6 months, I decided to mill up 1/8 maple ply for deck planks. The sub deck is 3/16 balsa sealed, sanded and sealed again. The bottom was also drenched in Thompson Water seal as well. Each plank (random stain) is laid up with black hemp (45lb.) for seal. I`m looking forward to the deck now. I almost gave up on this ship. Then I realized all the research and work up to now and decided,......no can do,.......she`ll be worth it.
I`ll post pics of the mast underway later.
Cheers
Old Mar 01, 2006, 07:19 PM
Capt_Christo is offline
Find More Posts by Capt_Christo
Mostly harmless
Capt_Christo's Avatar
Sydney, Australia
Joined Feb 2005
Hi Warren,
This is a really interesting (if lengthy) project. Please keep us informed of your progress, and lots more pics please.
I wonder how much lead you will need for the keel if you intend to put her in the water?
Cheers
Capt_Christo is offline Find More Posts by Capt_Christo
Old Mar 01, 2006, 08:07 PM
Langley,B.C,Canada
Joined Jul 2002
The Keel
Yup,....RC Sailboat she will be. The Keel will have metal extrusions out the bottom so different style and weight can be bolted on. I`ll show you a few pics tonight.
Warren
Old Mar 01, 2006, 08:59 PM
Langley,B.C,Canada
Joined Jul 2002
Lower Hull
I won`t be planking the hull until the end. This way I can resolve radio installation much easier.
I spent some hours building the keel and setting hull formers (shadows). They are locked into the keel as you can see. I set up a Jig to mill the keel in the form of a "key" in order to lock in the formers which are secured with gussets. The metal brackets for the "ballast" keel will mount from a plate that runs on top of the gussets and bolts to sandwich the keel. Hard-wood blocks will pack out the formers where the lateral stress will be apparent. The hull is light at this stage but very solid, (overly) somewhat. The mast stem reciever plate is bullet proof as you can see underneath with stainless hardware.
Old Mar 01, 2006, 09:38 PM
Langley,B.C,Canada
Joined Jul 2002
A little History of this Ship
Well,.....there is none really. British Cutter "Comet" of 1809.
I searched the world over, every book, article and similair reference.
I am so determined to build this ship for those reasons alone. In my eyes she`s a thing of beauty. Good subject for a scale model. Anyway I had to draw up plans from 2-3 others Cutter/Man-O-War,etc. The only glaring difference is the transom which I will have to reduce after building it. The top side is being built from the attached photo. I built a 1/48 model of it some time ago from scratch just to sort out the "left turns".
I`m happy so far. I will be adding a motor/stuffing box as well. The prop will be discreetly stashed in front of the rudder. Never now when one might have to cheat to save.
Cheers
Old Mar 04, 2006, 11:18 AM
Langley,B.C,Canada
Joined Jul 2002
More Pics
Decided to sew up a sail on my 70 year old "Singer".
Old Mar 10, 2006, 11:24 AM
Langley,B.C,Canada
Joined Jul 2002
Dead Eyes and Bow
I started the dead eyes with wooden kitchen knobs. 1/8 brass for upper link. The dead eyes are turned on the drill press for the groove, rear cut off and sanded to shape. The brass is bound with copper wrap and soldered. Finished the cat heads. There is an oak plate under the sub-deck that receives them into a mortised slot. I`ll plant the windlass on the deck when finished. I`m not sure about a capstan yet since these smaller vessels sometimes used the windlass to haul.
I really want to sail this model in the summer, so every minute I get I try to plug in the build.
The colour of the sails seems O.K. but I`m having second thoughts. Maybe I should go white? Any opinions are welcome. Maybe to much "browns" over all. Not sure yet.
Cheers
Question can I use laptop external adaptor for my hot wire cutter? forestsinger Power Systems 5 Jan 12, 2006 02:10 PM
My first foam cutter shakysticks Foamies (Kits) 17 Jan 09, 2006 01:58 PM
My scale zoom/shogun (Jet Ranger) tbitz Mini Helis 4 Oct 16, 2005 02:19 PM
Finally got my scale bird ptlpc Scale Sailplanes 6 Jul 23, 2005 12:09 AM
are is some of my scale airliner plane u.s air Scale Kit/Scratch Built 0 Dec 03, 2002 02:17 AM
