Closed Thread
This thread is privately moderated by sagomon, who may elect to delete unwanted replies.
Old May 04, 2011, 05:45 PM
Joined Oct 2010
Trader Rating: 105
F-86F Sabre/FJ-2/3 Fury by Jet Hangar Hobbies $350
Fan Unit: 5" Turbax Fan System or MW-44
Scale: 1/9
Length: 50.5 inches
Wingspan: 50.5 inches
Utilizes a Turbax 5" fan system or turbine
Flow through inlet design with auxiliary inlet for increased flow - NO CHEATER HOLES!
Convertible to turbine with minor modifications
Modified flat bottom airfoil wing with symmetrical tip for enhanced flight characteristics
Accurate outline and cross sections
Optional flaps and speed brakes
Optional scale oleo landing gear (nose and mains)
Premolded hatch and nose inlet
Wing is removable - Complete jet can be transported in a compact car
Kit supplied with all pre-cut wood, foam wings and lightweight fiberglass parts
This is an older kit with the 1 piece fuselage that you have to cut hte hatch out with a razor saw.has laser cut parts and is complete and have updated instructions from JHH.good candidate for 90mm edf.
Epoxy Fiberglass
1-piece fuselage
Exhaust liner
Preshaped Foam
Wing panels
Wing center section
Precision Cut Wood
Precision cut balsa and plywood parts
Sheeting
Canopy
Comprehensive Full-sized Plans and Photo Instruction Booklet
JHH FJ-3/F-86 90mm Installation!
You can't beat the flying characteristics of the sabre, and with the 90mm installation, it's a treat! The beauty of the 90mm fan in our sabre is that it doesn't require an auxillary inlet, so with the characteristic round sabre inlet lip and a full duct, the fan sees extremely clean airflow. As with the E-Turbax installation, 2 6s batteries easily fit along side the inlet ducting and . In flight, the airplane has been clocked at over 160mph and has a great authoritative climb. Shown below (built by Brent Hecht), the model has been covered in aluminum tape which gives a beautiful natural metal finish. The airplane represents Major James Jabara's sabre from the end of the Korean War. The ready to fly weight is 13.5lbs.
buyer pays actual shiping
pictures will be posted when the rain stops and I can layout the kit outdoors
sagomon is offline Find More Posts by sagomon
Closed Thread
Build Log Twin BVM FJ-2 Fury ARF Build (F-86 Sabre)... jfetter Electric Ducted Fan Jet Talk 277 May 29, 2013 07:03 AM
Build Log Jet Hangar Hobbies (JHH) F-86 Sabre Build Ken Lapointe Electric Ducted Fan Jet Talk 1206 Sep 11, 2012 09:00 AM
Sold Bvm F-86 Sabre/FJ Fury Inline12 Aircraft - Fuel - Jets (FS/W) 12 Dec 05, 2009 06:57 PM
New Product F-86 Saber / FJ-3 Fury Jet by Leading Edge Gliders jcarstan Slope 31 Oct 04, 2008 10:11 PM
