Old Aug 19, 2003, 04:03 AM
Christer Lagerstedt is offline
Find More Posts by Christer Lagerstedt
Stockholm Bromma, Sweden
Joined Mar 2000
How to make a model roll better
My KZ II sport (a 1938 Klemm-like two-holer) is a nice flyer but is hard to roll. I might have the Center of Gravity to near the nose. I know there is a "Diving test" to check the CG on a model but I cannot find how to do it now.
Please advice.
Christer Lagerstedt
Haninge MFC, Sweden
Christer Lagerstedt is offline Find More Posts by Christer Lagerstedt
Old Aug 19, 2003, 05:29 AM
Goodychrischild is offline
Find More Posts by Goodychrischild
Goodychrischild's Avatar
Bristol, UK
Joined Oct 2002
Hi Christer,
Nice looking plane!
The following was posted in one of my threads and I think it is what you are refering to:
"If you can, get some alltitude, fly straight and level at cruise speed, then push the nose down into a 45 degree dive and let go of the stick. If she pulls up sharply, it`s nose heavy. This effect should minimize as you move your pack further back to a more balanced CG (weight towards tail end)."
You can also read further discussions on the subject within the thread (pages 5 & 6) here:
http://www.rcgroups.com/forums/showt...4&pagenumber=5
Chris
Goodychrischild is offline Find More Posts by Goodychrischild
Old Aug 19, 2003, 05:58 AM
Joined Mar 2000
Thank You, Just what I was looking for.
Christer
Old Aug 19, 2003, 09:41 AM
Captain Ed is offline
Find More Posts by Captain Ed
Aging Busdriver
Captain Ed's Avatar
Florida Keys
Joined May 2003
An important factor in roll rate is aileron travel. The "up" aileron is the primary roll control. The "down" aileron, even though it contributes to the roll can cause the plane to resist rolling by creating too much drag on the opposite side from the "up" aileron. For good roll response the controls should be set up so the "up" aileron travel is greater than the "down" aileron.
Captain Ed is offline Find More Posts by Captain Ed
Old Aug 19, 2003, 12:00 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
I've had success mixing a little rudder with the aileon.
If your radio won't do it you can use your left thumb.
Right rudder with right aileron, etc.
feathermerchant is offline Find More Posts by feathermerchant
Old Aug 19, 2003, 01:46 PM
Paul Willenborg is offline
Find More Posts by Paul Willenborg
Registered Lifeform
Paul Willenborg's Avatar
Little Rock,AR,USA
Joined Jun 1999
Uhm, actually the last two reponses will give you better turning response, but may hurt rolling ability. Both aileron differential and mixed rudder will cause the plane to yaw in the same direction as the roll- good for turning, bad for rolling. For best rolls you'd like no yaw whatsoever from the ailerons.
If you've got a lot of aileron differential try reducing it. Seal aileron/wing gaps if there are any. Moving the CG back does more to help pitch authority but can't hurt within reason. No need to dive at 45 degrees to test! A shallow, sustained dive is just as good.
Paul
Paul Willenborg is offline Find More Posts by Paul Willenborg
Old Aug 19, 2003, 02:17 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Re: How to make a model roll better
Beautiful model, Christer.
Keep in mind that roll rate is a directly related to how effective the ailerons are and that there will be some cases where you will not be able to increase the roll rate beyond a certain speed.
Since this is a trainer, I would expect that the roll control would be slower than an aerobatic design.
I personally don't think that CG is going to have any effect on roll rate, but I've been wrong before.
Dan
DanSavage is offline Find More Posts by DanSavage
Old Aug 19, 2003, 02:24 PM
rwlewis is offline
Find More Posts by rwlewis
Tomball, Texas
Joined Nov 2002
Can't see them in the pic, but if you have any gap at the aileron hinges, try sealing it with tape. Some planes benefit greatly from this simple fix.
rwlewis is offline Find More Posts by rwlewis
Old Aug 20, 2003, 01:40 AM
Joined Mar 2000
Thank you all.
I usually fly CAR (coupled aileron and rudder) but always disconnect it for rolling maneuvers. My ailerons are sealed and I use around 2 to 1 differential. Will try other settings.
If I remember correctly the model was nose heavy when first built. I think I added a lump of lead under the elevator, have to check.
I was flying in a scale competition last Sunday and my rolls were quite bad. Halfrolls like in Immelmanns and Split-s are usually OK.
Have to do a series of test flights.
Christer
Old Aug 20, 2003, 02:34 AM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
Hi Christer
Beautiful model you have there.
If the KZ is like the Klemm, it will have long-span wings. Such high-aspect ratio wings naturally roll more slowly than fighter-type low aspect ratio ones. It's very likely that the real KZ II and Klemms rolled very poorly.
Recognising that you've applied just about every practical fix to get the model rolling better, I'd guess that the only other thing left is to increase the airflow over the ailerons. In other words, precede the roll manoeuvre with a long shallow dive to build up the airspeed, level off, and then roll.
What's puzzling me, however, is that the model seems to roll from erect to to inverted OK (Split-S) and also to roll from inverted to erect (Immelmann) as well. Somehow, it's not doing a joined-up roll
Best regards
Gordon
Gordon is offline Find More Posts by Gordon
SWAC 2006-How to make this event better than 2005 Thomas B The Southwestern Aeromodeling Conference (SWAC) 2005 60 Apr 19, 2007 11:26 PM
Question how to make my rustler better?? Nick S Electric Power Cars 4 Feb 28, 2006 12:53 PM
Question how to make a model for aerofly pro deluxe ??? ATARI-2600 Simulators 0 Jan 03, 2006 02:06 AM
Estarter--How to make it roll caddy28 Beginner Training Area (Aircraft-Electric) 10 Jun 29, 2005 07:20 PM
