Old May 04, 2011, 07:43 AM
mphsjeep is offline
Find More Posts by mphsjeep
mphsjeep's Avatar
United States, TN, Memphis
Joined Dec 2004
Help!
E flite 4 in 1 question(EFLH1024)
I aquired a throw together coax heli with a EFLH1024 4 in 1 on it. Im a newbie and have some questions....please help if you can!!!!
OK, there are 5 plugs and 7 plug labels...bat, thr, ail, ele, rud, ch5, ch6.
I know the first and two last plugs are out of the equation since for battery, channel 5 and 6.
There are two servos hooked up for elevator and aileron control BUT in moving the elevator stick up and down both servos move. Moving the aileron stick left to right only one servo moves as it should.
SOOO.......is this 4 in 1 working properly?
Im thinking it is and made for airplanes but wanting to confirm so I can sell it in good conscience and get what I need. Im thinking the top servo plug is for "THR and AIL" and the one below it for "ELE and RUD".
Thanks in advance!!!
mphsjeep is offline Find More Posts by mphsjeep
Old May 04, 2011, 09:17 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Not 100% familiar with the 4-1 unit but if it was designed for heli use there is a good chance that its normal heli mixing thats moving both channels but not sure why it would not do so with the aileron channel.
Again not 100% try finding manual online.
freechip is offline Find More Posts by freechip
Old May 04, 2011, 09:36 AM
mphsjeep is offline
mphsjeep's Avatar
Joined Dec 2004
Im thinking it was designed for airplanes. I have a stock CX2 and has a total different setup. Im not familar with planes but if two pushrods were needed to be moved equil for each wing flap that would make sence.
Old May 04, 2011, 07:31 PM
mphsjeep is offline
mphsjeep's Avatar
Joined Dec 2004
Ok I figured it out...and now feeling silly.....the TX settings were set to throw both servos....ooooops.
Question thunderpower 4 port 1 cell charger with my e-flite 1.5amp adapter 18t Batteries and Chargers 3 Apr 04, 2011 10:06 AM
Sold E-Flite 4-in-1 Control Unit EFLH1027A Wattsup23 Aircraft - Electric - Helis (FS/W) 4 Mar 29, 2011 01:20 PM
For Sale E-Flite 4-in-1 Control Unit EFLH1027A Greenflash Aircraft - Electric - Helis (FS/W) 0 Mar 20, 2011 03:07 PM
Wanted e-flite 4-in-1 eflh1024 noelgg84 Aircraft - Electric - Helis (FS/W) 0 Dec 21, 2010 01:07 AM
Sold E-flite 4-in-1 (EFLH1024) for Blade CX2 VasMan Aircraft - Electric - Helis (FS/W) 1 Dec 15, 2008 11:16 AM
