Old May 03, 2011, 05:05 PM
Mechnan is offline
Find More Posts by Mechnan
Schweiz, BE, Neuenegg
Joined Apr 2011
Help please something is not working
I finanly got all my fpv stuff together but now it isnt working at all i get a blue screen with a litle interfearence in the fashark but nothing more.
GoPro
ImmersionRC 5.8GHz transmitter
5.8GHz airwave reciver
Stock wip antennas
If you ned to know anything else just ask, i hope you can help me.
Mechnan is offline Find More Posts by Mechnan
Old May 03, 2011, 07:17 PM
Flightbox is offline
Find More Posts by Flightbox
Flightbox's Avatar
United States, OR
Joined Jan 2010
shoot a couple of photo's so people can see the set up.
Flightbox is offline Find More Posts by Flightbox
Old May 05, 2011, 12:45 PM
Mechnan is offline
Joined Apr 2011
ok so i tested all the components seperatly
i can see de video feed from the gopro if i connect it directly to the googles
it seems something with the 5.8 ghz sistem is not working properly just cant find out what
Old May 05, 2011, 12:55 PM
Mechnan is offline
Joined Apr 2011
here the pics you asked for
Old May 05, 2011, 01:00 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Damn, that's a pretty pro set up for a first FPV rig. Very nice.
airbagit13 is offline Find More Posts by airbagit13
Old May 05, 2011, 01:27 PM
Mechnan is offline
Joined Apr 2011
thanks man but does still nobody have a clue where the problem could be?
Old May 05, 2011, 01:37 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
Is it all "plug and play" or did you have to make up some wiring yourself?
If so is it possible to post a sketch of how you wired everything up?
NDw is offline Find More Posts by NDw
Old May 05, 2011, 01:49 PM
Mechnan is offline
Joined Apr 2011
sure i'll make one
Old May 05, 2011, 02:36 PM
Mechnan is offline
Joined Apr 2011
top is the tricopter and bottom is the ground station
Old May 05, 2011, 03:51 PM
Mechnan is offline
Joined Apr 2011
is anything rong with this layout?
Old May 05, 2011, 03:55 PM
Mechnan is offline
Joined Apr 2011
more accurat list of what i have used
Motor Scorpion SII2212-885KV
ESC ePower 18A Regler für 2-3S LiPos mit 2A L-BEC
Servo MKS-Servo-DS470
Battery ePower EXP eco-20C 2200mAh 3S1P 11.1V
RX Futaba Empfänger R617FS 2.4GHz FASST 7 Kanal
CPU KKmulticontroller SMD v5.5 Blackboard
Propeller GWS 9x4.7" SF
Chassis 1mm CFK
Tubes 11x10mm Länge 280mm
Weight ∼700g
Max Thrust ∼1800g
Endurance 13:30min (Schweben 15min)
Spez. Efficency 12.57mA/g (9x4.7“)
FPV
Camera GoPro Hero HD mit LVF
A/V Tx ImmersionsRc 5.8GHz 600mW (200mA)
Weight ∼900g
Endurance ∼10:30min (Schweben 11:30min)
Ground Station
Battery Zippy 2200mAh 20C 3S1P 11.1V
Battery 9v block
A/V Rx Airwave 5.8GHz A/V Receiver (210mA)
Monitor Fat Shark Base RCV922 Goggles (230mA)
Endurance ∼5h
Old May 05, 2011, 03:57 PM
Mechnan is offline
Joined Apr 2011
and the video and audio signals i just wired one to one
Old May 05, 2011, 03:59 PM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Willing to bet its something simple. Either something isn't plugged in all the way, the switch on the Fatsharks isn't in the right position, or something doesn't have power.
Could it be channel selection?
Blue Chip is offline Find More Posts by Blue Chip
Old May 05, 2011, 04:23 PM
Mechnan is offline
Joined Apr 2011
what switch on the fat shark?
no i switched thru all the channels so it cant be that
Old May 06, 2011, 04:40 PM
Mechnan is offline
Joined Apr 2011
ok so it cant be the camera or the fat sharks because if i connect the camera directly to the fat shark i get a clear and solid video signal in the goggles.
the problem must be either between the GoPro and the video transmitter, between the video- transmitter and receiver or between the video receiver and the Fat Shark or in either the transmitter or the receiver itself.
hope you can see something i cant... :-(
Help! Brushless motor not working please help! R/C_dude Racing Boats - Electric 14 Apr 22, 2010 09:12 AM
Discussion Sensors not working. Help please. DominicM Eagle Tree Systems 10 Jan 06, 2009 09:54 AM
Discussion 3DFoamy Downloads not working-help please Mikey C. Foamies (Scratchbuilt) 5 Oct 16, 2008 10:18 AM
Discussion gyrotor not working - help please!! hgee Micro Ready-to-Fly 2 Jun 05, 2007 12:52 PM
piccoboard not working with hitec 6ch please help kevinO Micro Helis 3 Mar 20, 2004 01:15 PM
