Old May 02, 2011, 09:21 PM
superevan is offline
Find More Posts by superevan
superevan's Avatar
United States, TX, Austin
Joined Aug 2007
Simple HH Gyro for Yaw Sensing
I'm currently in the process of creating a diy head tracking system mimicking the setup seen here (http://www.starlino.com/rc_transmitt...lerometer.html). However I've run into a bit of a roadblock and could use some collective help.
In the link above you'll see he's using an accelerometer to calculate X and Y values that get converted and sent to the servos via the rx/tx. What I need is to sense the yaw, rotational movement of my head which the accelerometer doesn't do.
I've thought about using a rate gyro but that wouldn't do position sensing and would only dampen the movement, as it should.
So my big question is what's a good, simple way to either sense rotational position or convert the rate gyro signal to a crude heading hold?
Any help is greatly appreciated. I've combed the web for a simple solution.
superevan is offline Find More Posts by superevan
Old May 03, 2011, 10:25 AM
HugePanic is offline
Find More Posts by HugePanic
German Engineering.......
HugePanic's Avatar
Auxsburg
Joined Dec 2007
WII Motion Plus --> 15/$ works easy with arduino
HugePanic is offline Find More Posts by HugePanic
Discussion Diy hh - yaw rate demand gyro shoutchen DIY Electronics 73 Aug 05, 2011 08:19 AM
Discussion Turnigy 9x and Esky HH Gyro problems conezone Electric Heli Talk 2 Apr 01, 2011 04:24 PM
Video Honey Bee FP /w HH Gyro (simple hovering) cohort Electric Heli Talk 3 Apr 26, 2007 03:57 PM
Question Real simple HH gyro question sharky47 Electric Heli Talk 4 May 24, 2006 01:18 PM
HH vs. Yaw Rate Gyro (newbie question) Grimtooth Electric Heli Talk 3 Jul 01, 2004 03:22 PM
