Old May 02, 2011, 06:13 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
Build Log
24" foamy B17 build log.
i am planning a 4 engined plane. i am figuring on using 7mm motors turning GWS 2510, getting about 12g thrust each. looking at a 24" ws b17. what do you all think? am i smoking something?
nemoskull is offline Find More Posts by nemoskull
Old May 02, 2011, 06:29 PM
gklein is online now
Find More Posts by gklein
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
Well, I just finished a 24 inch span, two engine Skyvan, using two Champ gear boxes and smaller 4025 props (for clearance). (http://www.rcgroups.com/forums/showthread.php?t=1404259)
The AUW is 85 grams and the power was marginal. Measured thrust was only 43 grams. I have just tonight switched to cut-down 5030 three bladed props, cut to a 4 1/8 diameter. Thrust now measures 53 grams. I anticipate that this will serve my needs. My experience has always been that thrust needs to be over 50% of the model weight for successful flying. With other factors also being an influence, i.e. type of wing, wing loading, need for breaking free of ground (my issue with the skyvan), etc. My gut says that you may need to get a little more thrust or the ever popular - build lighter!
gklein is online now Find More Posts by gklein
Old May 02, 2011, 11:02 PM
Baratacus is offline
Find More Posts by Baratacus
Post Digger
Baratacus's Avatar
San Diego, CA
Joined Oct 2005
direct drive 7mm motors? have you considered brushless? a 7mm pager weighs 2.7 grams and puts out 12 grams of thrust with a 2510 prop. With the 2gram outrunner using the 2510 prop You can get about 20grams of thrust per motor. You would need 4 of the 1 gram esc's but the total weight of four BL motors and four BL esc's is the same as four 7mm pager motors and one brushed esc. You just get about 30 grams more thrust. Might be able to do some ROG take offs with that kind of output.
Baratacus is offline Find More Posts by Baratacus
Old May 02, 2011, 11:11 PM
nemoskull's Avatar
Joined Sep 2009
yes, but i can get the whole system for 20 dollars. i would be looking at 50 dollars for the same. one day, but probly not today.
Old May 02, 2011, 11:30 PM
Afraidtoregister is offline
Find More Posts by Afraidtoregister
Looking4Grass in AZ
Afraidtoregister's Avatar
United States, AZ, Mesa
Joined Feb 2011
I think if you use much less foam than that Skyvan had, you'll be able to pull it off. Roll some 2mm foam maybe?
Afraidtoregister is offline Find More Posts by Afraidtoregister
Old May 02, 2011, 11:43 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
if you make the wing and fuselage out of eps foam, it will weigh probably 4-5 grams for the fuse and 3-4 for the wings, then use some 2mm depron or foam plates for the tail and it'l be light, real light.
i think its do-able but your going to need to watch the current in the brick, 4 of those motors would likely be to much for the brick. unless it was the new twin brick, it should work.
derk is offline Find More Posts by derk
Old May 03, 2011, 12:20 AM
buratino is offline
Find More Posts by buratino
Singapore
Joined Nov 2007
If you are using Aero Ace props for 7mm motor it will have 16-17g thrust and motor much cooler than with GWS 2510 prop
buratino is offline Find More Posts by buratino
Old May 03, 2011, 03:40 AM
nemoskull's Avatar
Joined Sep 2009
derk, i was going to use a 3 amp brushed ESC or the ar6400T i have. i havent done the weights yet, so i reay have no idea what i have left for the airframe.
burantio: do you have any hard data? if i could get even 12 g out of them, then i could scale down the plane.
Old May 03, 2011, 06:38 AM
buratino is offline
Singapore
Joined Nov 2007
You can check this out
http://www.rcgroups.com/forums/showthread.php?t=1413355
First I also don't think it possible so I did the test myself and got the same result.
Old May 03, 2011, 08:58 AM
nemoskull's Avatar
Joined Sep 2009
hmmmm...... very intresting. i have a 7mm motor at and and some old AH props. i will have to see.
Old May 03, 2011, 11:26 AM
Post Digger
Baratacus's Avatar
San Diego, CA
Joined Oct 2005
wow that's impressive! Looks like All4smallrc was getting 14g thrust, which is still better than 12. The amp draw is probably lower as well. when you start multiplying it x4 things add up in a hurry.
Old May 03, 2011, 12:19 PM
richos is offline
Find More Posts by richos
richos's Avatar
United Kingdom, England, Wells
Joined Mar 2008
Err . Why not 4 x PKZ3916 Micro J-3 Cub Main Motors 6mm and 4 x Micro Cub Complete Gearboxs PKZ3928 .
The micro Cub 6mm motor and gearbox puts out allmost 20g thrust
4 x 20g = 80g thrust is that enough thrust for you????
richos is offline Find More Posts by richos
Old May 03, 2011, 12:32 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The cub motor/gearbox/prop makes over 20g of thrust, but that's with a 4" prop.
With a direct drive 2.5" prop, a 6mm motor probably isn't going to generate 20g of thrust.
They should make 12g - 15g, though and have the best Power to weight ratio if weight is important.
If $ cost is important, the cheapest set up is the $2.25 Playmate/Albatros 7mm motors. These should make good direct drive motor with a 2.5" prop.
UNGN is offline Find More Posts by UNGN
Old May 03, 2011, 12:42 PM
speedemo is offline
Find More Posts by speedemo
speedemo's Avatar
Munich, Germany
Joined Jun 2009
You must also consider which 7mm motor you want to use. The hottest 7mm (1.7ohm, SS Blue?, JS or Walkera) will give you 14g-16g thrust on a AH prop@1,1A-1,2A current draw. All others will obviously be less thrust, but also less Amps.
A DD 6mm will give you considerably less I think, 5g-8g would be my best guess.
speedemo is offline Find More Posts by speedemo
Old May 03, 2011, 12:50 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The J-3 motor is pretty hot for a 6mm. It probably can make as much DD thrust as most old school 7mm's.
The Albatros 7mm motor likely makes as much thrust as an "SS Blue".
Nobody has really tested these new motors vs. the old motors, but from the weight of the planes they will fly, they are making more power than most of similar motors in the archives of RCG.
Discussion Thoughts on eflite leader 480 Joe in Dublin Sport Planes 1177 Jun 18, 2016 10:01 AM
Discussion Thoughts on the UM F4u Corsair? bunger Scratchbuilt Indoor and Micro Models 2 Mar 09, 2011 01:23 PM
Question Largest Plane on plantraco .4 gram acts? nemoskull Scratchbuilt Indoor and Micro Models 3 Mar 08, 2011 12:59 AM
Discussion Free Direct drive props for 4,6,7mm motors Bob Blackburn Scratchbuilt Indoor and Micro Models 10 Dec 16, 2006 05:33 PM
18 gram 22.7mm CD-rom ryanl2006 Power Systems 13 Nov 01, 2004 07:36 PM
