This thread is privately moderated by leccyflyer, who may elect to delete unwanted replies.
Old May 02, 2011, 06:06 PM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
BC#039 - Pilot Mitsubishi Zero -duplicated by E- machine Twin (DSOTM)
Aircraft Name: Mitsubishi Zero
Manufacturer/Designer: Pilot OK Models
Type: Scale WWII Warbird
Construction: Built-up balsa fuselage, wing and tail
First Flight: Warrington Model Club, 20/10/2007
Wing Span: 49"
Wing area: 441 sq in
AUW:
Power type - Electric
Motor: Twister 25
ESC: Jeti Advance Opto 45
Tank/Battery: Flightpower 3s1P 3300mah
Propeller: APC-E 9x7"
Receiver: Hitec Electron 6
Flight Pack: 800mah 4.8v Sanyo NiCd
Servos: Elevator (wire pushrod) - HS225 Ailerons (wire pushrods) - 2xHS81 Rudder and tailwheel -HS81
Throws -
Undercarriage - fixed
Accessories: None
Covering: Solartex, painted with Humbrol enamels
Current status: In workshop for remotoring
RC Groups Thread http://www.rcgroups.com/forums/showt...hi#post7659636
Duplicated Model NUmber - discovered this morning 26/3/2015
Aircraft Name: E-Twin (DSOTM)
Manufacturer/Designer: Not-known -looks like a Twin Mini Flying Machine
Type: Sports aerobatic twin
Construction: Built-up balsa fuselage, veneered foam wing and sheet balsa tail
First (and last) Flight: Warrington Model Club,
Wing Span: 38.5"
Wing area:
AUW:
Motor: 2xSp400 7.2v
ESC: Jeti 350
Tank/Battery:3s1p 2500 Maxpoly Lipos
Propeller: Graupner 6x3" folder
Receiver: HiTec Mi04
Flight Pack: BEC
Servos: Elevator (wire pushrod) - HS81 Ailerons (wire pushrods) - 2xHS101
Throws -
Undercarriage - None
Accessories: None
Covering: Black Profilm with Dark Side Of The Moon trim
Current status: Written off as destroyed on maiden flight, switched off receiver on hand launching
RC Groups Thread: http://www.rcgroups.com/forums/showt...n#post10779314
leccyflyer is offline Find More Posts by leccyflyer
Last edited by leccyflyer; Mar 26, 2015 at 03:56 AM. Reason: Duplicate Model Number correction
Sold Twin E Starter Laceylou Aircraft - Electric - Airplanes (FS/W) 1 Mar 14, 2011 11:23 PM
