Old Jun 20, 2011, 12:36 AM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Went out to the shop after my last post and put the model on the thrust stand. The ESC that came out with the 40mm had a JSC connector and the one that went in with the 30mm is identical to the other ESC, but with a Deans micro connector.
I mention this because I was unable to test with the 2S 350mah battery used in previous tests due to the different connector type.
I had a similar battery on hand, a Polyquest 400mah 2S1P 20C battery that was used for this series of tests. So, the data shouldn't be too far off from previous tests.
The model once again only made 30g of thrust.
Out comes the Xacto knife and the forward portion of the nacelle is removed.
I remount the model on the test stand, connect the battery and throttle up...90g thrust.
I chop the throttle and zero the scale. I apply full throttle and again 90+ grams of thrust.
After another two or three times running up to full throttle the thrust number begins to drop but is attributable to the battery's not containing a full charge.
I cleared the portion of the nacelle that was removed of all irregular surfaces/obstructions that were disrupting the intake of air and re-attached it with Titebond.
I'll charge the battery and re-test in the morning and post the results.
I'm really delighted to have built the thrust stand. It is an invaluable tool to have on hand. And best of all it was free, built from lumber discarded by the neighbors, and salvaged, and hardware on hand.
g
giuseppi is offline Find More Posts by giuseppi
Old Jun 20, 2011, 02:09 AM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Interesting findings.
The thrust stand is really a good idea for those wanting to tinker with different fans/motors and combinations, etc - I am lacking one in my inventory of tools.
Slaanesh is offline Find More Posts by Slaanesh
Old Jun 20, 2011, 12:38 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
This morning I put together a 2S 180mah pack with the last two singles I have. I mounted the plane on the test stand with the 180mah connected and got readings ~ 50g.
The 400 mah pack that was used yesterday was still charging. With the pack still in the plane and plane in hand, I throttled up to see how it felt. It pulled some so I thought what the heck, walked out to the yard, and gave it a couple of tosses.
50g static thrust was not enough to lift an AUW of ~ 116g. On the second toss it hit on the nose pretty hard and pushed it in a bit. It also broke the servo tray loose so that is gluing.
I'm on hold temporarily before any more testing can be done.
I am encouraged in that the 240mah cells that are on the way should be close to the weight of the 180mah cells. So, a 3S 240mah pack should be about a perfect fit weighing ~ 18g and an AUW @ ~ 123g.
g
Old Jun 20, 2011, 04:47 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Got the servo tray all healed and resumed testing.
Put the 2S 400mah 20c battery in the fuselage closed it up, mounted it on the thrust stand and the highest reading I get is 61g with mostly high 50g. Probably took five readings.
Out comes the razor saw and off with the front end of the nacelle...again. Back on the stand and...85g - 87g thrust. Did it this way four or five times with all mid to high 80g readings.
And to be sure not just any tube attached to the front of the fan has the same effect, I taped the inner cardboard tube from a roll of toilet paper (40mm ID) to it and got a 92g reading.
The front of the nacelle is an oval 28mm wide X 32mm high. The way the fan is mounted in the nacelle from the front of the fan housing to the front of the nacelle is 57mm (2-1/4")
I really want to retain the shape of the nacelle so next, after the glue dries I'm going to do some experimenting with intake ducting. I'm not sure if it's the oval or the drastic change from an oval to a 40mm circle.
Any ideas, anybody?
g
Old Jun 20, 2011, 05:45 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Can you grab a photo of it please Giuseppi?
NitroCharged is offline Find More Posts by NitroCharged
Old Jun 20, 2011, 07:42 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
I was hopin' you hadn't forgotten about me!
Here are a few pics. You can see the cut marks where the front section was removed ahead of the fan in the side views. That hump and taper toward the front are what I'm hoping to retain but what are causing all the problems. I think I see cheater holes in my future.
What do you recommend, Oh Wise One?
g
Old Jun 20, 2011, 09:27 PM
Onna Vakkation is offline
Find More Posts by Onna Vakkation
United States, PA, Grove City
Joined Jan 2011
Originally Posted by giuseppi View Post
Hey, Bill. Nice Heinkel. Yeah, the dollar glider started it off then I couldn't find 'em for $1.00 anymore. So' it's become a different animal entirely.
What are yours' dimensions, power system etc.
I did some more surgery on mine this morning. I cut out the 40mm fan and replaced it with the just built 30mm. The glue is setting up now.
I have some single 240mah 20C batteries on the way from China. I'm gonna build a couple 3S packs. Maybe even a 4S.
g
The HE162 is around 22"span, 4oz AUW, with a Feigao powered EDF30 fan. It was done back when I had to cut out the 10mm hub, install my own hub, and then use GWS heli tail adapters to mount the rotor. I actually built 6 of those fans, and could knock one out in an hour, after building a few of them. Folks have it easy with these PNP 30mm fans now.
The 5866kv seemed to work the best on 3s lipo in the EDF30, which is what my other 3 EDF30 jets have. The 162 has the 7000kv I believe, or maybe it is 7500, either way being the highest kv that they made. It was a new motor release at the time, so it was an experiment to see if I could gain thrust. It runs fine on a small 3cell, but the small amount of gain was not worth the additional load on the tiny little 3s-300 Full River lipo. The batt got hot in it, while it was fine in my Vampire with a 5866kv fan. With the lipos out now, it's not a problem, but I only few it a few times, so as to not cook the precious little battery back then.
On thing I can tell you about the little 162 is that it is a nice flyer. The only oddity is giving a bit of an upward toss on launch, just like my Starmax 162, as the high fan pushes it downward until it gets up to speed.
Edit: Come to think of it, I think the wing was from a Cox FW190.
Onna Vakkation is offline Find More Posts by Onna Vakkation
Old Jun 20, 2011, 09:54 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Really good stuff there, Bill.
g
Old Jun 20, 2011, 10:47 PM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
I like the idea of using the Xacto blade tube for a motor housing however I was wondering if it is necessary?
For example, the DP32 EDF has the stators glued directly to motor itself.
I believe the Kyosho DF45 does something similar with a custom 20mm motor that has the stators built into the actual motor.
With no housing, the motor gets the best cooling possible.
Anyone see anything wrong with doing this? Apart from the motor heating up and the glue becoming loose.
Old Jun 21, 2011, 11:54 AM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
I'm no expert and can find no problem at all with it.
You could use J-B Weld, a 2 part adhesive, which has a temperature threshold up to 500 F :
http://jbweld.net/products/jbweld.php
g
Old Jun 21, 2011, 04:12 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Giuseppi, I think the main problem is your motor is not strong enough (too small for the job). From what I see, it chokes the moment it encounters any resistance.
Old Jun 21, 2011, 04:48 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Well, I'll find out soon enough, I guess, when this arrives.
AEO 10200KV Brushless Motor 30mm Ducted Fan EDF OM138
Old Jun 21, 2011, 05:57 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Are you saying that it won't work because I don't want to trim the front of the nacelle or, even if circumcised it won't work.
g
Old Jun 21, 2011, 07:45 PM
Joined Jan 2011
It was necessary back when you wanted a 12mm Feigao inrunner powered 30mm fan, and the only 30mm fan housing available was the GWS EDF30 housing, made for a 10mm inrunner. There was also an expensive ourtunner retrofit kit, that used a bushing and twisted copper wire. You have it easy today with these off the shelf PNP fans. I built 4 jets with the setup, all still in flying order.
BTW, the beauty of the inrunners is that they run well from a single Castle ESC. The 262 has a single TBird6, and the A10 a single P10. I've at least 10 planes that run 2 inrunners from 1 Castle ESC.
Bill
Old Jun 21, 2011, 09:01 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
giuseppi
Make sure your intake is smooth. No radical changes in area from the intake to the fan blades. The fan needs clean air that is not turbulent.
Attachment is not mine. It was posted here several years ago. If you know who drew it please tell me so I can give proper credit.
mcross is offline Find More Posts by mcross
Help! Slope glider made out of Dollar tree foam board? Foam crasher Slope 27 Feb 27, 2013 09:39 AM
Discussion black vs white dollar tree foam unbroken23 Foamies (Scratchbuilt) 11 Jul 23, 2012 12:04 PM
For Sale Dollar Tree foam glider, NIP 4.00 shipped CONUS nemoskull Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Apr 04, 2011 12:34 AM
Build Log dollar tree 60in aero glider haogodent2 Foamies (Scratchbuilt) 2 Aug 11, 2010 11:31 AM
