Well here it is finished. But well over 60g-65g. I should have studied up a bit more on 30mm EDF before starting.
The dotted line on the second image is where I'm gonna perform the bellyectomy. I think I'll go ahead and toss it once before I begin surgery for the 'elluvit. Thanks for the guidance, y'all. g |
You may as well see how it goes as is so that you get an idea of what to aim for if you decide to build something different. It's all about experimenting and learning, isn't it? |
Souderton Pa. USA
Joined Mar 2002
Looks good. I've wanted a Salamander since I saw the cave where they built them. Shoot for 2/3 thrust to weight so you don't have to fly full throttle all the time. I'm thinking the 1220 will draw more than the 180's can safely put out but don't know for sure. I'd do aileron elevator or tailerons.
I did a twin 30 biz jet with the dollar store gliders years ago, great cheap airframe. Looks like it can be bashed into more than a biz jet. |
Tried to fly her but too heavy. Attempted to remove some weight by sanding the airframe but still way too much weight to fly.
I'm starting over but his time with quite a bit more knowledge going in. I'm gonna try again with the same components. Just the components weigh in a 51g. I can shorten some wires and remove some heat shrink to recover a few grams but basically the airframe needs to be < 30g. g |
I went to my local Dollar Tree to pick up another glider but they didn't have them. So, since I have a set of free flight plans in PDF for a Rapier L2 motor I'll be attempting to build it instead.
I scaled the plans up 125% to accommodate the fan. The formers will be from Dollar Tree sheet and the fuselage will be covered with 1mm sheeting ripped from the Dollar Tree sheet on a hot wire cutter. The flying surfaces will be cut from the full size sheet. I'm shooting for an empty airframe of 25g to 30g which will give an AUW of ~ 75g - 80g. g |
| Thread Tools | |
| Help! Slope glider made out of Dollar tree foam board? | Foam crasher | Slope | 27 | Feb 27, 2013 09:39 AM |
| Discussion black vs white dollar tree foam | unbroken23 | Foamies (Scratchbuilt) | 11 | Jul 23, 2012 12:04 PM |
| For Sale Dollar Tree foam glider, NIP 4.00 shipped CONUS | nemoskull | Aircraft - Electric - Micro & Indoor Airplanes | 8 | Apr 04, 2011 12:34 AM |
| Build Log dollar tree 60in aero glider | haogodent2 | Foamies (Scratchbuilt) | 2 | Aug 11, 2010 11:31 AM |
