How do you know the motor is overheating ? Unless it seizes or you have a handheld temp gauge the only way to tell is to look at the plug--if electrode &/or base shows any whitesh color---it is running too hot---retard spark &/or richen mixture.
Are you sure you have no fuel problems, IE lines kinked, an air leak, a tank or piping w/in problem ? The problem you are describing (if I interpret your wording) would be typical of an air leak or fuel restriction somewhere if the aformentioned suspects are OK. After re-thinking this, 9k seems a good RPM so maybe not as overpropped as I initially thought--not sure about mixture----40:1 non synthetic may be OK if rod has needle brgs top & bottom ---if at all bushed---35:1 is safer especially if running too hot. Pennzoil For Aircooled Engines is best possible oil for all conditions--bar non Here's a Zinger multiblade prop guide that I've had pretty good luck with. 2, 3 & 4 BLADED CONVERSION CHART The conversion for a three and four bladed propeller is a simple task if you know what two bladed propeller you use on a given Engine. For example, on a three bladed propeller you would drop the diameter and keep the pitch. On a four bladed, you would drop the diameter and the pitch. For instance if you had a two bladed 24-10 propeller and you wanted a three bladed you would use a 22-10 and so on. -------------------------------------------------------------------------------- 2BL 3BL 4BL 10-6 9-6 11-8 10-8 10-6 12-8 11-8 11-6 12-10 11-10 11-8 13-10 12-10 12-8 14-10 13-10 13-8 14-8 13-8 13-6 15-8 14-8 14-6 15-10 14-10 14-8 16-10 15-10 15-8 18-10 16-10 16-8 20-10 18-10 18-8 22-10 20-10 20-8 |
Joined Mar 2008
No No , If you read the Original Post , He's using a 14/7 Three Blade ! That IS too much prop for the RCGF15 . It was Me who Originally suggested (In post #2) that he use a 14/6 Two Blade instead of the three blader hes using
| Thread Tools | |
| For Sale RCGF 20CC Gas Engine Version 2, 2.6 HP | freeplansguy | Aircraft - Fuel - Engines and Accessories (FS/W) | 1 | Apr 23, 2011 10:21 AM |
| Sold NIB RCGF 15cc engine with pitts muffler. $249 shipped in the US. | 5478Jimmy | Aircraft - Fuel - Engines and Accessories (FS/W) | 3 | Jan 29, 2011 10:47 AM |
| Sold RCGF 15cc Gas Engine | Dynomike | Aircraft - Fuel - Engines and Accessories (FS/W) | 1 | Dec 23, 2010 08:15 AM |
| Discussion New Engine From Rcgf 15cc | rcgfusa | Hot Online Deals | 43 | Dec 03, 2009 01:53 PM |
