Old Aug 19, 2003, 12:58 AM
kgmorris is offline
Find More Posts by kgmorris
Ken
kgmorris's Avatar
Arlington, Texas, United States
Joined Sep 2002
B-36 B-52
Gary Jones came to Lockheed Martin (Ft. Worth, TX) with a B-36 and B-52. Both flew great. Very impressive Gary!
kgmorris is offline Find More Posts by kgmorris
Old Aug 19, 2003, 01:02 AM
kgmorris is offline
Ken
kgmorris's Avatar
Joined Sep 2002
B-52
B-52
Old Aug 19, 2003, 01:04 AM
kgmorris is offline
Ken
kgmorris's Avatar
Joined Sep 2002
B-52
B-52 Low pass at Lockheed Martin.
Old Aug 19, 2003, 01:08 AM
kgmorris is offline
Ken
kgmorris's Avatar
Joined Sep 2002
B-36
B-36 fly by at Martin.
Old Aug 19, 2003, 01:26 AM
denverone is offline
Find More Posts by denverone
Boone, Iowa, United States
Joined Feb 2002
Is the B-52 a pusher or is there some ducted fans. Just curious as the plane looks great.
denverone is offline Find More Posts by denverone
Old Aug 19, 2003, 02:42 AM
kgmorris is offline
Ken
kgmorris's Avatar
Joined Sep 2002
Pusher
The B-52 is a pusher with the motor located about mid fuselage and a drive shaft running to the prop. I think the rest of the A/C is built with fan fold. The picture is of poor quality. You can only zoom so much.
Fly Low and Slow, Ken
Old Aug 19, 2003, 07:41 AM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
very impressive. dimensions?
Robbie d is offline Find More Posts by Robbie d
Old Aug 19, 2003, 01:33 PM
Paul Willenborg is offline
Find More Posts by Paul Willenborg
Registered Lifeform
Paul Willenborg's Avatar
Little Rock,AR,USA
Joined Jun 1999
ThomasB told me about the B-52, what a hoot! It looks wonderful in the photos and Tom says the wings flex just like the real thing. I may have to try a B-47 the same way- one of my favorite planes.
Paul
Paul Willenborg is offline Find More Posts by Paul Willenborg
Old Aug 19, 2003, 09:28 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Gary's B-52 was incredibly cool. All fan fold foam, with a wingspan of 36" It is pushed along very nicely by a single GWS DD motor and the regular 3x2 prop. The motor is mounted close to the wing trailing edge, inside the fuse, with a carbon fiber rod drive shaft to the tailcone.
Interestingly enough, his B-36 has a 52" wingspan and his B-52 has a 36" wingspan.
I wish I had time to build a TU-95 Bear with 4X N-20 DD to chase Gary with...
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Aug 20, 2003, 08:20 AM
Robbie d is offline
Crazy Cessna Owner
Robbie d's Avatar
Joined May 2001
now that would be cool
Old Dec 30, 2008, 09:46 AM
Wilit run? 353 is offline
Find More Posts by Wilit run? 353
No such thing as overpowered
Wilit run? 353's Avatar
Suffolk, England
Joined Sep 2008
I am soon to get a B-36 and a B-52G plan to build it from
https://shop.traplet.com/product.aspx?c=997
https://shop.traplet.com/product.aspx?c=1020
does anyone have any info on these plans
Wilit run? 353 is offline Find More Posts by Wilit run? 353
Old Dec 30, 2008, 02:54 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Another ancient thread brought back to life.....
If you do some deep searching in this Scale Forum, I think you will find at least one person has posted in here in R/C groups that built from the Traplet B-36 plan you link to. That B-36 construction article was pretty good in the magazine with the plan. I suggest getting that you chase down that down as well. Look for B-36 threads in here in the 2001-2004 time frame.
(OK, I searched for you and rediscovered the fact that the designer of the B-36 plan above is active in the forum here. you might try contacting Boomerang1 directly.)
I do not recall anyone from RC Groups ever building the 8 x KP-44 B-52 by Chris Golds, which is the other plan. I would certainly try a search on R/C Groups anyway and focus on the EDf forums. I predict you will not find much here in the Scale forum on that particular model.. Your best bet for more info about this model would be to locate the back issue of Quiet and Electric Flight International, which had the construction article by the great Chris Golds.
Amazingly, Chris Golds has built a huge number of B-52 models. A large one for .40 glow ducted fan power, one or two for TD .020 homebrew fans, this one for the KP 44mm EDF unit and about 1.5 builds of the big B-52 plan for 8 Minifan 480s. (It crashed on the first flight, so he had to build about another half of a B-52 to get it in the air again.) I think there is one or two more that I have forgotten about as well.
Chris' email is chrisgolds@connectfree.co.uk
As a last resort, you could write him about the B-52.
Old Dec 30, 2008, 05:23 PM
Boomerang1 is offline
Find More Posts by Boomerang1
You made that out of trees?
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
I'm the designer of the B-36. It's now 13 years old & still going strong.
What do you need to know? - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Dec 31, 2008, 03:50 AM
Suffolk, England
Joined Sep 2008
thanks Thomas B for all the help you suplyed.
Boomerang1 I just wanted to know how easy it is to build. do you have a build thread?
also; how are the retracts made, are they home made or can you buy them?
does it have flaps?
and finnaly is it nice to fly?
so many questions right now. when I start building there will be even more
thanks
willit
Old Dec 31, 2008, 04:58 PM
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
Hi Willit, it's not an especially easy model to build. Wings & tail are conventional built up construction but the fuselage requires some foam skills & it's covered in brown paper PVA. There is also a lot of it! Traplet sells the mouldings. Sorry, no build thread, it was built a long time ago.
The retracts are cheap, simple mechanical units.
http://www3.towerhobbies.com/cgi-bin...?&I=LXL406&P=0
You have to fit new legs over the piano wire legs to carry the extra wheels, I found this easy & simple to do. I modified the nose leg to retract forwards, not backwards, easy, just pull them apart & reverse a few parts.
No, it does not have flaps, I have never thought 'I wish I had fitted flaps' & they ad more complication & weight. I'm not 'anti flap', just not needed in this case.
Nice to fly? That depends on what you expect. Really easy to take off & land (suits a smooth strip because of the little wheels), climb rate is not stunning with the original speed 400/nicad battery setup but is as you would expect of a big bomber, approaches have to be made flat as it glides like a sailplane (yes it will thermal). It's not especially directionally stable & wafts about a bit in wind. It's very easy to fly but will drop a wing if you do dumb things like turn really tight & slow .
Videos are here: http://users.bigpond.net.au/BAC/B-36_video_page_.html
John.
B-52 Update flailing Scale Kit/Scratch Built 25 Mar 22, 2010 04:47 AM
Edf B-52? efarmer Electric Ducted Fan Jet Talk 95 Nov 21, 2009 05:54 AM
B-52 Nowell York Electric Ducted Fan Jet Talk 5 Jan 06, 2003 07:32 PM
B-52..50! dorysch1 Electric Ducted Fan Jet Talk 14 Dec 03, 2001 10:29 PM
eBay B-52 plans gutboy17 Electric Ducted Fan Jet Talk 3 May 23, 2001 02:08 AM
