Old May 02, 2011, 07:43 AM
Dodga is offline
Find More Posts by Dodga
Joined Apr 2011
Rc genesis
Hi all I'm totally new to this so I really do not nomuch about what parts to buy and how to do it. I recenly bought a genesis rc boat from hobbyking so far the only mods I've done is a turnigy 180a esc and just ordered a octurax640 prop polished and balanced everything else is completely stock. Can anyone give me some tips for getting more power without spending a fortune. also I'm not very good on the technical side of things but I sounds like alot if people really know there stuff on here. I have already received a bit of help of diesel6401 thanks mate. Can anyone help me with some ideas it would be much appreciated
Dodga is offline Find More Posts by Dodga
Old May 02, 2011, 08:08 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
First off welcome, secondly, you have purchased the best ESC out there for the money. It will handle anything youi throw at it in that hull..........so you are good to go there. That ESC allows you to use a higher kv motor, or one that will take 6s and is of a lower kv.
Have you run it yet? It should be pretty fast with the stock motor and that prop.
scorpion1 is offline Find More Posts by scorpion1
Old May 02, 2011, 08:15 AM
Dodga is offline
Joined Apr 2011
Genesis
Yes I've had 2 runs with it on 4s running 2s parallel the stock prop broke so going to try the new octura prop this week hopefully it goes well. This looks like it's going to be very addictive! Not sure what step to take next for speed since my knowledge is basically 0. Atleast I got the right esc hey!
Old May 02, 2011, 09:00 AM
kookie_guy is offline
Find More Posts by kookie_guy
Joined Jun 2007
Go to offshoreelectrics.com
The guys on there have done lots of work with the genesis.
kookie_guy is offline Find More Posts by kookie_guy
Old May 02, 2011, 11:15 AM
mozzyrocks is offline
Find More Posts by mozzyrocks
Australia, VIC, Blackburn North
Joined Feb 2011
If you bought an Octura prop, it won't fit the shaft properly. You will need to do one of two things........
1. Replace the driveline & bushing. OR
2. Buy the little collet adapter from OSE that takes the slop out of the prop fitting on the shaft.
Good luck & welcome to the site.
You know I responded to your PM too. Check out those things & it should answer a few questions.
mozzyrocks is offline Find More Posts by mozzyrocks
Old May 02, 2011, 04:03 PM
HYDROJERRY is offline
Find More Posts by HYDROJERRY
Wave Riding Vehicles
HYDROJERRY's Avatar
Louisburg,North Carolina
Joined Jun 2009
Im on Offshoreelectrics all the time and those guys and me love those hulls,, so i would go there and look around the boat building section and youll probly find something and when looking there also look at the threads marked Fightercat Daytona hulls its the same as the genesis hull...
HYDROJERRY is offline Find More Posts by HYDROJERRY
Old May 02, 2011, 07:43 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Here's Bills Genesis................
HobbyKing-Genesis.wmv (2 min 29 sec)
Old May 02, 2011, 08:20 PM
Dodga is offline
Joined Apr 2011
Wow that looks really quick and it seems to run nice and smooth too. Pitty the GPS was off lol. Do you know what setup he has? Thanks for the replys too guys.
basiclly cause i know stuff all im just trying to get some good ideas on what to do to get it going faster without chanhing to much and spending to much $$$.
Old May 02, 2011, 09:36 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Neu 1521 on 6s lipo.
Old May 02, 2011, 10:10 PM
Dodga is offline
Joined Apr 2011
Thanks scorpion what sort of speed will that get me and if I do that what else will I have to change shafts props and mounts?
Old May 03, 2011, 05:13 AM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Here's a link to my Ginnie mods for you.
http://www.rcgroups.com/forums/showt...1158907&page=9
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing 80 mm Mig 21 Fishbed
Old May 03, 2011, 05:22 AM
osprey21 is offline
Find More Posts by osprey21
osprey21's Avatar
Palma Sola,Fla.
Joined Oct 2006
My Genesis....
05-01 GenFlip.wmv (3 min 37 sec)
osprey21 is offline Find More Posts by osprey21
Old May 03, 2011, 08:14 AM
Joined Feb 2011
Nice.
What's your setup?
Old May 03, 2011, 08:33 AM
Dodga is offline
Joined Apr 2011
Bill you have some really good info on your thread. This might come in handy. definalty tossing up between the neu 1521 and the leopard 4082 1500kv motors. From what i can gather both would be great to use but i think the neu motor is more expensive. anyone know what the speed diffence between both would be. Also would it be the same amount of work installing either one of these motors?
Old May 03, 2011, 09:17 AM
Joined Feb 2011
Calculate the motors RPM (Kv) by the voltage to get your max UNLOADED RPM. Kv x V = Max RPM. My boat motor 2000kv x 22.2V = 44,400rpm unloaded. Turning an Octura 440/3 it probably only gets about 28,000 if that. I know it revved harder with the 437/3, but, didn't seem as fast.
Is there any way to log the motors max RPM while running WOT?
Depending on your setup, ie: prop diameter & pitch, against what the motor is comfortably able to cope with under load can considerably lower the RPM, but, also load your motor too much & fry it.
It's all about a happy medium. What you're happy to pay for & how happy you'll be with that amount of performance. :-)
Look at peoples videos & what ever impresses you the most, use that set up! :-)
The Neu is more expensive, but, I personally think they are a better quality motor.
I've owned a couple & ran them in 1/8 cars & trucks. Very reliable, powerful & well built.
Build Log Genesis rebuild. mozzyrocks Racing Boats - Electric 317 May 19, 2015 05:14 PM
Off Site Fully Loaded 2.4Ghz GENESIS 450PE RTF 6CH RC Helicopter passerbyeus Aircraft - Electric - Helis (FS/W) 0 Apr 26, 2009 11:10 AM
Off Site Fully Loaded 2.4Ghz GENESIS 450PE RTF 6CH RC Helicopter passerbyeus Aircraft - Electric - Helis (FS/W) 0 Apr 25, 2009 01:58 PM
Off Site Fully Loaded 2.4Ghz GENESIS 450PE RTF 6CH RC Helicopter passerbyeus Aircraft - Electric - Helis (FS/W) 1 Apr 21, 2009 02:13 PM
