Old May 02, 2011, 05:35 AM
tomcor is online now
Find More Posts by tomcor
Battery Powered==(*)==
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
Hobby King Pearl EPO Glider Thread
Has anyone ordered one of these? Looks like a good price. Real close in size to the Kinetic 800. Use your own parts.
http://www.hobbyking.com/hobbyking/s...dProduct=16023
tomcor is online now Find More Posts by tomcor
Old May 03, 2011, 02:24 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Last month I was considering this, mini swift or the Kinetic 800. I ended up getting a PNF Decathlon. FWIW the Kinetic 800 looks better and the control surfaces are bigger in the pictures.
ridge_racer is offline Find More Posts by ridge_racer
Old May 03, 2011, 02:47 PM
wippo76 is offline
Find More Posts by wippo76
Netherlands
Joined Dec 2010
i ordered one a few weeks ago
but still stuck at the dutch customs the dont beleive the price
i will try a AX1806 2500kv with a 5X5 folding prop and 2s 610mah rhino and a 10A rctimer esc
soon as i am flying this baby i will give you an update
wippo76 is offline Find More Posts by wippo76
Old May 13, 2011, 03:07 PM
ronaldf is offline
Find More Posts by ronaldf
ronaldf's Avatar
Oakhurst, CA
Joined May 2006
Mine came in yesterday. I'm quite impressed. I started fitting things together and found the quality very good. The wings are held together with strong magnets along with the canopy. The canopy magnets may be a little too strong! Its hard to remove. A tab of tape at the rear will help. The instructions call for 5gm servos but the HobbyKing 3.7 servos fit perfectly. My only complaint is with the included folding prop. It's quality is very good but the shaft size is 2mm. The AX 1806 motor that would be a perfect motor for the Pearl has a 3mm shaft. I'm going to try the HobbyKing 1811-2000 motor. The mounting adapter fits the firewall holes perfectly. The 1811 is a little short so mounting spacers will be needed. I have ordered a Turnigy 2211 from HK but will try the 1811 until the 2211 gets here.
The control surfaces are not cut out so this could be used as a chuck glider! The hinge indentations are there. Once I cut the ends free, I'll see if the hinge areas are of good quality. If not, I've got hinges!
Here is a video of wippo76's Pearl 780
Pearl EPO Glider 2s and 3s.mp4 (3 min 41 sec)
ronaldf is offline Find More Posts by ronaldf
Old May 26, 2011, 10:22 AM
wippo76 is offline
Netherlands
Joined Dec 2010
i fly the pearl now a few weeks
it flies really nice
mostly on 3 cell 500mah and with the ax1806 2500kv.
really nice motor, fits perfect
i used epoxy to mount the motor
its really fast
only thing to mention
i did glue the wings together
on 3s they will go off
pearl very nice plane for the money
Sent from my GT-I9000 using Tapatalk
Old May 27, 2011, 11:13 AM
ronaldf is offline
ronaldf's Avatar
Oakhurst, CA
Joined May 2006
Wippo76
The instructions specify the COG to be 3 cm from the front edge of the wing. Using that, the plane seems to be nose heavy on a test glide. My flying weight is 182 gms using a 1811, 500 mah 2S, and 3.7 gm servos. Are you using the 3 cm COG?
Old May 28, 2011, 02:21 AM
ronaldf is offline
ronaldf's Avatar
Oakhurst, CA
Joined May 2006
Originally Posted by ronaldf View Post
Wippo76
I did some more test glides. There was a light breeze and the Pearl floated beautifully so the COG seems to be right on at 3 cm.
Old Jul 08, 2011, 01:41 PM
han_zo is offline
Find More Posts by han_zo
Chicago - I mean the city (not the burbs)
Joined Feb 2007
Could anyone note the chord on this little bugger? Thanks!
han_zo is offline Find More Posts by han_zo
Old Jul 16, 2011, 02:26 AM
Lammergier is offline
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
the ailerons look more like flaps where they are located. Do they work well that far inboard.
Lammergier is offline Find More Posts by Lammergier
Old Oct 07, 2011, 02:17 PM
sbarce is offline
Find More Posts by sbarce
Joined Nov 2009
I received mine! Hope I can build it this weekend. looks very well and extremely well packed.
sbarce is offline Find More Posts by sbarce
Old Nov 15, 2011, 04:45 PM
ffranck is offline
Find More Posts by ffranck
ffranck's Avatar
Oslo, Norway
Joined Jan 2011
Hello,
This a a very cool and cheap little glider!
I found the response of the aileron quite ok, combined with the rudder it controls very well. Maybe the elevator is a bit small for my tastes (or I should increase the throw a bit).
Anyway, I have experimented with different batteries, added a landing gear to take off and land on gravel and even fitted small cam on it and it always flies and glides very well.
Here is a video I made with it:
Aerial Video from Pearl Glider (3 min 31 sec)
The only problem I have is that there is no vents to cool the electronics, it is fine on a 2S lipo but if using a 3S lipo I have to remove the canopy. I tried cutting some vents but I think they are too small.
Franck
ffranck is offline Find More Posts by ffranck
Old Nov 25, 2011, 01:13 AM
ffranck is offline
ffranck's Avatar
Oslo, Norway
Joined Jan 2011
Here is one more video:
Aerial video over Sognsvann (Oslo) (3 min 5 sec)
Old Jun 03, 2012, 08:39 PM
gadgetpete is offline
Find More Posts by gadgetpete
Joined Aug 2010
Did anybody find the perfect motor servo battery combo for this glider?
gadgetpete is offline Find More Posts by gadgetpete
Old Jun 18, 2012, 01:33 AM
wippo76 is offline
Netherlands
Joined Dec 2010
Best lipo for this plane is zippy 500mah 3s
Esc 10a
Motor http://www.hobbyking.com/hobbyking/s...idProduct=5432
Prop 4.75x4.75
Old Aug 19, 2012, 07:39 AM
NoniKid1 is offline
Find More Posts by NoniKid1
Joined Apr 2012
What actually comes in the box? It says that it includes hardware, building tools, folding prop with prop adapter & spinner. What exactly are those hardware and building tools?
I'm new to ARF so bear with me.
I fly a RTF Cessna 182
NoniKid1 is offline Find More Posts by NoniKid1
Mini-Review Phoenix 2000 EPO Composite by Hobby King Katabatic Electric Sailplanes 19 Jun 08, 2014 12:56 AM
Discussion Hobby King EPO ParkJet ARF "Floats like a kitten" trees Pusher Prop Jet Models 252 Oct 21, 2012 09:10 PM
New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO Cheetah401 Micro Ready-to-Fly 9 Apr 18, 2011 04:11 PM
New Product Hobby King 2.3M EPO EP Ventus PNF Doubletap Electric Sailplanes 1 Apr 05, 2011 10:00 PM
Discussion Hobby King 61" EPO P-51? BEELZEBOB Electric Warbirds 2 Jan 21, 2011 05:22 PM
