Old Oct 17, 2001, 02:10 AM
bmess is offline
Find More Posts by bmess
Joined Oct 2001
how to tell if a motor can pull a certain plane
Without the help of motocalc, how do you tell if a motor (glow or electric) can pull a certain plane? Would you use static thrust measurements, rpm, etc?
bmess is offline Find More Posts by bmess
Old Oct 17, 2001, 04:25 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Why make it complicated ? If for some reason you don't want to use the proper tools like MotoCalc just look at what people are currently using in similar size/type planes.
No single measurement will tell you very much.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Oct 17, 2001, 11:17 AM
bmess is offline
Joined Oct 2001
I own Motocalc and have used it successfully with my electrics. I am now trying out some .049 and .07 glow engines on my 400 models. I guess its just trial and error then.
Discussion Axe EZ - How to Tell if Motor is Burned Out? Lon33 Coaxial Helicopters 6 Dec 28, 2007 01:30 AM
how to tell if Tango is 15k or30k rpm motor Konrad Kontronik 7 May 04, 2005 07:28 PM
how to tell if mybrushless motor is dying asjeep Power Systems 7 May 13, 2004 05:25 PM
How do you tell how many amps you can pull out of a li-poly battery? Kyle2baseball Batteries and Chargers 2 Feb 04, 2004 11:54 PM
how to tell if a motor can pull a certain plane bmess Fuel Plane Talk 2 Oct 17, 2001 02:55 AM
