Old May 01, 2011, 10:57 AM
dan1987 is offline
Find More Posts by dan1987
Joined Apr 2011
Question
joysway offshore warrior
hi guys just wondering if any of u have owned one and if u had any problems and also whats the biggest size lipo that will fit. had 2 offshore warrior lites and both had radio problems just had a mind of its own hopefully wont get that with this 1 as its 2.4 but any help would be awesome
thanks dan
dan1987 is offline Find More Posts by dan1987
Old Jul 16, 2011, 05:35 PM
cvctiger is offline
Find More Posts by cvctiger
Fast Cal
United States, CA, SF
Joined Jul 2011
Tips and tricks for you and everyone else
thanks dan
I have bought Venom 2200mah 11.1 50C packs for this it runs quicker and is a little heavier making the boat a little bit more stable. I still prop walk on the water which leads me to the next tip to suggest is to put a Dubro 1/8" collar with set screw on the flex cable between the motor collet and the flex cable shaft. This way you do not lose your flex cable. I learned the hard way and lost 2 flex cables with prop and prop dog before I did this. make sure all set screws for the cable and the prop dog are threadlocked and the flex cable is lubed after every 3-5 runs. Also cut up a pool noodle and put a piece in the nose and glue a piece to the canopy as well. The final tip is to reinforce the canopy screw hole by epoxying a metal washer to that hole. Now go have fun and tear up the water and good luck.
cvctiger is offline Find More Posts by cvctiger
Question Joysway magic vee robadob Racing Boats - Electric 13 Feb 07, 2012 07:22 AM
Discussion RC Program for Warrior Transition Battalion at Fort Riley Kansas nagayama13 Beginner Training Area (Aircraft-Electric) 19 Dec 20, 2011 05:50 PM
New Product 68inch Offshore Racing hull. UK Only NickR Racing Boats - Internal Combustion 0 Mar 04, 2011 07:14 AM
Discussion Joysway Discovery Merkava Sailboats 3 Feb 21, 2011 08:08 AM
Question joysway boat what do ya think ferral Racing Boats - Electric 50 Mar 26, 2010 06:48 AM
