Old May 01, 2011, 08:25 AM
rcta15 is offline
Find More Posts by rcta15
rcta15's Avatar
United Kingdom, England, Portsmouth
Joined Jan 2009
Help!
wing to fuselage ratio?
is there a size of wing to the size of the fueslage ratio if so what is it?
ie if wing is 60inch the length of the fuse should be ?????
many thanks RCT
rcta15 is offline Find More Posts by rcta15
Old May 01, 2011, 08:34 AM
goldguy is online now
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
For a conventional high, mid or low wing design, like a trainer, sport or aerobatic model, the length of the fuse should be 75% of the wing span, and of that measurement the nose moment should be 20% and the tail 40%........approximately!
Note..........the nose moment is from the prop to the LE and the tail from the TE to the rudder hinge line.
goldguy is online now Find More Posts by goldguy
Old May 01, 2011, 08:39 AM
rcta15 is offline
rcta15's Avatar
Joined Jan 2009
thanks that helps loads RCT
Old May 01, 2011, 08:46 AM
flyin' fool
goldguy's Avatar
Joined Jul 2003
Also, it's best to have the wing and horz. stab on opposite sides of the motor's thrust line.
Old May 01, 2011, 09:36 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
The late Chuck Cunningham published a great design series in the now defunct RC Modeler Magazine. Good basic design info including ratios of flying surfaces, stab sizes etc. They're still available as free downloads here:
http://www.rcmplans.com/index.php?main_page=page&id=17
Azarr
Azarr is offline Find More Posts by Azarr
Old May 01, 2011, 10:27 AM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
The one by Ken Willard, 'Basic R/C Design Parameter' there might be worth looking at as well while your there.
Quick61 is offline Find More Posts by Quick61
Old May 01, 2011, 11:50 AM
hankg is offline
Find More Posts by hankg
Lost but making good time
Joined Nov 2008
rcta,
A few I've used:
Regards,
Hankg
hankg is offline Find More Posts by hankg
Old May 02, 2011, 09:27 AM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Here's a good link RCT: http://www.chrisspad.com/planes/main...paddesign.html
It's about design SPAD aircraft, but there is a LOT of good info there regarding sizing the wing, fuselage and tail feathers. Good stuff.
JohnsPop is offline Find More Posts by JohnsPop
Old May 02, 2011, 10:39 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
But all that goes out the window when you make experimental Foamies ...
Seen many Strange Foamies here that didn't fit any of the standard calculations .. Yet flew... Just keep an open mind and do a lot of test gliding ...
gpw is offline Find More Posts by gpw
Old May 05, 2011, 01:07 AM
JohnsPop is offline
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
I didn't see any mention of "strange" or "experimental" by the OP but I hear ya. :-)
Old May 06, 2011, 03:15 PM
rcta15 is offline
rcta15's Avatar
Joined Jan 2009
many thanks to all that have replied.
RCT
Old Jan 01, 2016, 04:06 PM
Dreder is offline
Find More Posts by Dreder
Joined Jan 2016
is it the same for gliders?
Dreder is offline Find More Posts by Dreder
Old Jan 02, 2016, 08:37 AM
Wicher Donga is offline
Find More Posts by Wicher Donga
Wicher Donga's Avatar
Joined Oct 2015
I always use this program. https://www.birds-eye-view.nl/shop/p...gn-calculator/
It not only give you the right dimensions from all surfaces and fuselage parts but it also calculates the CG, wingload, and give you advise about the motor you need. I designed a few planes with this software and they all fly directly perfect.
Here you can see the last build.
SLOW CUB 1100 IN THE MIST (9 min 51 sec)
The guys from Birds-eye-view.nl also give how to build courses. You learn how to build and design your own plane.
Hope this is what you was looking for.
Wicher Donga is offline Find More Posts by Wicher Donga
Old Mar 20, 2016, 02:21 PM
rslegge is offline
Find More Posts by rslegge
rslegge
Joined Jun 2008
Sweet flying
Beautiful terrain and a very sweet flying plane, looks like a soothing experience.
rslegge is offline Find More Posts by rslegge
Discussion How high of an aspect ratio is practical for 7.5" chord wing? geocrasher Slope 5 Apr 28, 2011 05:38 PM
Sold E-Flite Habu 32 Fuselage and right wing custombuiltrc Aircraft - Electric - Jets (FS/W) 1 Apr 16, 2011 06:05 PM
Sold DuBro Wing and Fuselage Rack holla Aircraft - General - Miscellaneous (FS/W) 2 Apr 15, 2011 07:13 PM
Discussion What is the real gear ratio? DanL RC Tanks 5 Mar 22, 2011 08:16 PM
Help! Request for twisty wing plane span and aspect ratio (or wing area) data Sled Driver Slope 17 Oct 28, 2006 11:44 AM
